Really Tough Water Spots - Please help - w/pics
Discussion in 'Detailing' started by NickM, Nov 23, 2013.
  1. Nov 23, 2013 at 6:46 PM
    NickM
    NickM [OP] Well-Known Member
    Nick
    DE
    SR5 V6 4X4
    Yakima Roof Racks
    Hey guys, My 2011 is looking rough with these gnar water spots. I lived in NC where they started. I nor live in Delaware and it continues. I was on city with a softener at my old house. now i'm on well with water treatment and softener. I always dry the car after washing but i'm thinking this may be rain deposits? I tried vinegar and Zymol HD cleanse hoping it would help - nope. I wax about 2x a year. The windows are bad to but i use a razor blade on them and it does the trick. obviously the razor trick can't be done with the paint. Anyone know of an awesome product or technique? These pics were taken tonight after full hd cleanse and wax - Meguiars NXT
  2. Nov 23, 2013 at 6:50 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    Have you tried a clay bar?
  3. Nov 23, 2013 at 7:01 PM
    NickM
    Nick
    DE
    SR5 V6 4X4
    Yakima Roof Racks
    I tried a clay bar on half the hood. after i saw no improvement i decided against the labor afterwards
  4. Nov 23, 2013 at 7:03 PM
    Colt562
    Colt562 Well-Known Member
    Brett
    SoCal
    13' TRD Sport 4x4
    Icon Stage 3 Lift Kit...Dakars
    The only thing that has worked for me is vinegar. But since you already used it, not really sure. Let me see if I can find anything to help you out.
  5. Nov 23, 2013 at 7:05 PM
    OffroadToy
    If the clar bar won't touch it might try vinager, clr, or lime-away... check the instructions for use on painted surfaces though. I know on my aluminum boat clr works great... wipes off hard water spots better than anything else i've tried over the years. After the clr i go over it with mothers detail spray and it shines like a mirror. Another thing to try out... Meguirers scratch and swirl remover.
  6. Nov 23, 2013 at 7:06 PM
    NickM
    Nick
    DE
    SR5 V6 4X4
    Yakima Roof Racks
    Yeah, the HD Cleanse claims it removes hard water and acid rain stains but these have been there a while and i know i can do it if i get a grit wax and high speed buffer but I'm nervous about burning the paint since I'm not experienced.
  7. Nov 23, 2013 at 7:07 PM
    NickM
    Nick
    DE
    SR5 V6 4X4
    Yakima Roof Racks
    Awesome idea, never even thought about Lime away or CLR
  8. Nov 23, 2013 at 8:50 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    You might have to wet sand them out. Sometimes stuff like that eats into the clear coat a bit so you need to actually remove some clear to correct it. Bird shit is reallllllyyyyy bad for doing that.
  9. Nov 23, 2013 at 10:13 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    I would polish with a porter cable or flex 3401 before you jump to wet sand. Polishing will probably get them out.
  10. Nov 23, 2013 at 10:22 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Have a detailer friend that has a bottle of something that basically says "hard water spot remover". I'll see if I can get the brand name or whatever for it, but I've seen it clean that right up.
  11. Nov 24, 2013 at 5:14 PM
    NickM
    Nick
    DE
    SR5 V6 4X4
    Yakima Roof Racks
    Maybe i'll give it a high speed power buff. I will also search for the hard spot remover. on sanding use like 2000 grit? not so sure about that...
  12. Nov 24, 2013 at 5:18 PM
    InSight Retrofits
    InSight Retrofits Closed
    Try meguiars ultimate compound.
    I detail cars with it and it removes water spots, rust stains, scratched and discoloration.
    Love it! Made my girlfriends old 99 saturn look like brand new and same with a 2006 fusion I did.
    My water is also stupid, if I don't dry my truck I can litterally go outside and see salt/chlorine whatever it is crystals where the water dried. I used to live out in the country with a well and never had more than a few water spots. Now I live in the city and every spot there was a drip of water has a water stain.
  13. Nov 24, 2013 at 5:54 PM
    ace96
    Western KY
    Sanding should be the last resort. Shouldn't need a high speed buffer, a dual action should fine.
  14. Nov 24, 2013 at 6:00 PM
    !TacoTaco!
    !TacoTaco! TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
    Sub'd, I have a dull hood so I am hoping some of the suggestions you guys have made will help me out too.
  15. Nov 25, 2013 at 10:02 AM
    InSight Retrofits
    Meguiars ultimate compound
    before
    After- it's a 1999 saturn!
    Here is a car I started for a customer, showing him the product at work. Sun baked hood? Not anymore- I did the spot in the middle just with meguiars ultimate compound and a microfiber cloth
  16. Nov 25, 2013 at 10:03 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I assume you could use this to get hard water spots off windows?
  17. Nov 25, 2013 at 6:40 PM
    NickM
    Nick
    DE
    SR5 V6 4X4
    Yakima Roof Racks
    I will try clr or lime-a- way on windows first. Same spots so if it works there it should work on paint. I will be careful on paint. I will also try the Meguires compound. Post some pics this wee
  18. Nov 26, 2013 at 3:06 PM
    Mrallank
    Mrallank Active Member
    Im surprised that the clay bar didn't work. If the swirl remover doesn't get it then a mild compound will. you don't need a buffer just polish it in with a pad.
  19. Nov 26, 2013 at 3:35 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    a progressive polish with a good buffer'll get out those spots. looks like theyve etched into the clear coat, so a clay bar wouldn't be much help
  20. Nov 28, 2013 at 3:21 PM
    OffroadToy
