My Badge Blacking Process
Discussion in 'Detailing' started by badguybuster, Apr 7, 2009.
  1. Apr 7, 2009 at 8:32 AM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    O.K. this is my first real write up so bear with me. If I screw up, just humor me. So, I decided I wanted to black out the badges on my silver Tacoma, the chrome just doesn't work for me. If you follow my process, you will need a few tools. Now, I read all the previous write-ups and used some of their tricks and a couple of my own.
    1.-Get your tools: Fishing line (i used 6lbs test, but more on that later), plastic putty knife, paint of your choice ( I used a combo of Krylon Fusion, Krylon Indoor/Outdoor, and Rustoleum Clear Coat. You will also need some type of adhesive (I used Loke-Tite Heavy Duty mounting tape), a utility knife, cleaning solvent (I used plain car wash) and a clean area to work. I level is also a handy tool to have.
    2. Take the fishing line (3 equal lengths) Tie a knot at each end, then twist until tight (I found this to be stronger and it cuts faster). Using a sawing motion, slowly remove the badges. Now, some folks used a hair dryer but I did not find it necessary (it is 45 degrees in my garage). It is a slow process but take your time and don't rush, you don't want to damage the badges. When you are done, it will look similar to the following pics.
    3. Clean your badges, make sure to remove all the grime and old wax out of the little nooks and crannies so your paint is all level. Use your putty knife to clean all the adhesive residue off your truck, work slow and easy so as not to damage your paint. Then use your cleaning solution to remove any dirt or remaining gunk.
    4. To begin painting your badges, I laid mine on a large piece of cardboard and applied the first coat of Krylon Fusion (no adhesive is needed it has a molecular bond). I waited 15 minutes and applied a second coat. (Here is a good trick: Rotate the badges 90 degrees prior to every coat, to ensure you cover ALL the corners). I waited 30 minutes and applied a coat of the Krylon Indoor/Outdoor (the Fusion did not like sticking to the corners so this covered that area). I waited another 30 minutes and applied another coat of the Fusion. I then let it dry for another hour and applied the Rustoleum Clear Kote (2 coats about 30 minutes apart). Now, you probably don't have to wait so long between coats but I was being cautious since this is my first time doing this. Now, I kind of goofed the after pics show the badges when the adhesive already trimmed. SORRY.
    5. To re-attach your badges you first have to attach the adhesive tape. I rolled out a piece and placed the badge on it and snipped it off, then laid a book on it to ensure a tight grip. Then using your utility knife, trim around all the letters. (This process took about 3 hours) The reason for doing this is so that there is no adhesive showing under the letters, since it would attract dirt like a magnet. This is very tedious and a bit stressful but you will get through it.
    6. Now that you are ready to re-attach your badges, make sure your truck is VERY clean where you intend to re-apply them. PRIOR TO APPLYING THEM, DOUBLE CHECK FOR ANY SPOTS THAT NEED TOUCHED UP. I used a level to ensure they were correctly placed. Once on the truck, press on them for about 60 seconds to ensure a good bond. You will notice that even when I used a level that my V6 has a very slight tilt but once that Loke Tite is set......it is set!
    Well, there you go. For what its worth, I had a good time doing it. If you have any questions please ask. It is highly likely that I forgot to put something in here. Thanks for reading.
  2. Apr 7, 2009 at 7:13 PM
    badguybuster
    Michael
    Thanks. I am pretty happy with it. I am bucking for rep points. Whoo hoo
  3. Apr 7, 2009 at 7:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    looks good man!
  4. Apr 8, 2009 at 10:44 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Looks awesome! I've been meaning to do mine but was waiting for a write-up as such :)
  5. Apr 8, 2009 at 11:23 AM
    badguybuster
    Michael
    Hey, whoever gave me the rep points... Thanks, that is awesome.
    I am considering taking a shot at doing a How To on painting the engine cover. After seeing the ones some TW members have, I want it. I am going to try to do it with Krylon Fusion. We'll see.
  6. Apr 8, 2009 at 11:43 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    moar pics!!
  7. Apr 26, 2009 at 11:02 PM
    life11
    life11 Well-Known Member
    Tempe, AZ
    lifted 04 base V6
    Fabtech 3 inch lift, full magnaflow exhaust, 32 Inch toyo tires, 18 inch rims.
    i love tha step by step pics!
    great job
  8. Apr 26, 2009 at 11:08 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Nice Work, looks great! :thumbsup:
    I read somewhere to put making tape around the badges before you remove them, might ensure a more accurate placement.
    X2
    lets see the whole truck with it!
  9. Sep 9, 2012 at 3:36 PM
    yota828
    yota828 Member
    LENOIR,NC
    03 Tacoma
    20% tint on front 5% on the rest, clear corners, half clear half red tail lights, painted grille and emblem, 3in ome coils(883), pro comp struts/shocks, toytec aal
    looks good man. how do yall think the bedliner spray wld do?
