Grill painting advice
Discussion in 'Detailing' started by CTchambers040, Mar 26, 2015.
  1. Mar 26, 2015 at 5:20 AM
    CTchambers040
    CTchambers040 [OP] Member
    Alabama
    1998 SR5 4wd
    I'm going to have a free weekend coming up and have been wanting to paint my grill on my '98. I'm not completely painting illiterate but I need some help on what kind of paint and primer that will be best for diy. Any suggestions are greatly appreciated and also any advice on the steps of sanding etc. that will help me achieve the best results. Thanks!
  2. Mar 26, 2015 at 8:45 AM
    CTchambers040
    Alabama
    1998 SR5 4wd
    Also the grill has a chrome surround and is starting to peel a little bit on the top under the hood if that helps.
  3. Mar 26, 2015 at 9:09 AM
    WhatThePhuc
    WhatThePhuc Active Member
    Johnathan
    Oklahoma
    2000 Tacoma PreRunner SR5 V6
    The i repainted my grill and bumper, I stripped all the chrome on the grill off with a box cutter, then primed with rustoleum painters touch, painted with krylon fusion. No chips or anything so far and its been about 3 months.
    I also painted my bumper valence and chrome ends. Again, krylon and rustoleum on the valence, but plastidip on the ends b/c I wanted to be able to take it off if Ididn't like it. Hope this helps! :D
  4. Mar 26, 2015 at 9:33 AM
    CTchambers040
    Alabama
    1998 SR5 4wd
    Thank you! Your truck is pretty close to what I want mine to look like eventually and your front end looks sick! What kind of finish was the krylon fusion, gloss? Also did you clear coat your bumper, valence and grill?
  5. Mar 26, 2015 at 9:35 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I sanded down my grille and bumper then primed it then hit it with a flat black, pics are in my build
    don't plasti-dip it tho
  6. Mar 26, 2015 at 10:02 AM
    CTchambers040
    Alabama
    1998 SR5 4wd
    Thanks Josh! I've heard more bad about plasti-dip than good so I'm pretty iffy about it. Your build looks like it's going quite well. What grit sandpaper did you use and also did you use the same process on the bumper and chrome ends as you did on the grill? I've never had any experience painting chrome is why I'm asking all these questions hah.
  7. Mar 26, 2015 at 10:23 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Ha good, it holds mud/dirt for me for some reason and it looks so bad. Thanks is slowly picking up.
    Uh can't remember but don't think it was very small, just something rough enough to take the paint off. I plasti-dipped them first so it may be different from yours but yeah same process.
  8. Mar 27, 2015 at 4:04 PM
    WhatThePhuc
    Johnathan
    Oklahoma
    Hah thanks man! I used the krylon fusion satin and was about to clear but decided not to cause it looked good to me. IMO if i would've used gloss it would've been way too glossy...
  9. Mar 27, 2015 at 4:12 PM
    WhatThePhuc
    Johnathan
    Oklahoma
    Im jelly of your satoshi.... :drool:
  10. Mar 27, 2015 at 8:27 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Haha thanks man! Bought it with the truck :thumbsup:
  11. Mar 27, 2015 at 10:11 PM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
