Access LE Install on a 09 Tacoma
Discussion in 'Detailing' started by 95SLE, Jan 3, 2010.
  1. Jan 3, 2010 at 7:19 AM
    95SLE
    95SLE [OP] Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I did a lot of searching and never found a thread about the Access LE install on a Tacoma so I thought a thread would be in order.
    I will start by saying that one person can do the install but two would be ideal. I am satisfied with the product as it fits my requirements. For some you might want to consider another one of the Access products. With the LE you get a top of the line unlocking system and a tailgate seal that does not work too well with the Tacoma. The Access site, http://www.agricover.com/index.php , also has a clamp with cargo hooks listed but these are not needed or included with the LE for a 2005+ Tacoma. I had to call Customer Service twice and both times Randy was very helpful.
    You really need to read the instructions and pay attention to the instruction insert for the Tacoma. Unpack the tonneau cover and take inventory of all the parts.
    Remove one of the bed side rails to start the install. One tip is that the longer bolts, supplied with the cover, use a smaller thorax drive so be careful and do not strip the bolt head. Once you begin the actual install of the side rail I found it easier to start with the middle bolt and work towards the end bolts. This is where having a friend to help would be ideal.
    Next up is the install of the front weather seal to the top of the bed.
    Then we add the front tension dials to the cover and then bolt to the side rails.
    Unroll the tonneau cover and it snaps right into the rear of the side rails with a nice tight fit.
    The last item to install is the rear tailgate gasket that comes with the Access LE. I decided to install the gasket to the vertical surface of the tailgate and not the lower horizontal surface. When I tried to install the gasket as one piece the bend at the bottom was constantly being hit by the lower edge of the tailgate. If I tried to install the horizontal seal then the gasket was above the surface plane of the truck bed. I use the truck as a garden center hauler so I felt that one good load of top soil, sand, rock or mulch then the seal would be trashed.
    If any member has the tailgate gasket installed and hauls garden center items I would like you input for the longevity of the gasket.
    If you have a question concerning the install go ahead and ask and I will answer and take additional pictures if needed.
  2. May 18, 2010 at 12:18 PM
    Scorn
    Scorn Well-Known Member
    Indiana
    TRS Sport Dbl Cab
    I am just about to order this cover how do you like it? Was it an easy install and is it worth the extra $40.
  3. May 18, 2010 at 12:28 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I am still liking it a lot. Never any wetness in the bed and it held up outside in the snow this winter. I keep it clean with Aerospace 303.
    It is a breeze to unroll and get out of the way for trips to the garden center.
    The only con is the side rail tie downs will not fit but I did not use them anyway.
  4. Nov 20, 2010 at 1:20 PM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    why don't the tie downs fit after the cover was installed it looks like the cover leaves the rail system wide open? Is it the brackets for the cover are to low to fit the tie downs in?
  5. Nov 21, 2010 at 4:37 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    The way the the metal brackets, that have the velcro strips, are bent do not allow the larger base of the stock tie down rings to fit into the stock rail. I believe the smaller optional tie down rings will fit.
    I am still like the cover after a year of use. I have not had any issues even when hauling rock and mulch.
  6. Mar 22, 2011 at 9:32 AM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
  7. Mar 22, 2011 at 9:40 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    TY
    I keep the cover clean and protected with 303 Aerospace Protectant after every other wash. Still looks brand new.
  8. Mar 22, 2011 at 9:45 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I hope they have changed the adhesive on the Bed Seal, it did not stay put when I had a toneau cover. Looks great Access has one of the nicest covers on the market.
  9. Mar 22, 2011 at 10:41 AM
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    First, thanks for the write up. Great job!
    I was going to get this tonneau but now I have reservations that the rail tie-downs will not work.
  10. Mar 22, 2011 at 10:51 AM
    maestroz2
    maestroz2 Well-Known Member
    Dave
    Erie, PA
    2010 DoubleCab Pyrite Mica TRD Sport SB
    TRD Skid Plate, Toyota Bed Mat, WeatherTech window visors, WeatherTech Floor mats, Access LE Bed Cover, Rocky Mounts Bike mounts, Astrostart 2-way Remote Start, TRD bronze beadlock wheels, Factory roof rack.
    I installed this same cover last year. My tie downs still work. the cover does everything I need it to.
    I did not put the tailgate gasket in and it still keeps the snow/water out for the most part.
    One thing i did was replace the bolts that come with the cover for the bed channels. The ones that came with the cover started to rust and was worried I wouldn't be able to get them out very easy later on.
  11. Mar 22, 2011 at 10:52 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    The stock tie downs will not work. However the smaller tie downs work to perfection. ;)
  12. Mar 22, 2011 at 10:33 PM
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    Hey, nice write up, but I have to disagree with you about the stock cleats not working with the Access LE. I have the same cover and they work fine. I originally took off the end caps of the tonneau rail and slid them on, but have later discovered that you don't even have to do that. Look for the slotted tabs in the cleat track and you can put the cleat in the track there. The height of the tonneu cover rails clears the cleats just fine.
    http://www.cardomain.com/ride/2241706/2006-toyota-tacoma-xtra-cab/page-2
  13. Mar 23, 2011 at 2:50 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I did not try that approach. I will try it after I get back from the gym this morning.
    Well i am back from the gym and tried it. It worked great. Thank you for telling me how to install the regular size bed cleat. PER for you.
  14. Mar 25, 2011 at 9:21 PM
    novataco
    NOLA
    06 Sport V6 auto
    No problem. Now you have a nice assortment of cleats to work with.:cheers:
  15. Mar 25, 2011 at 9:37 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Glad this has re-posted because I forgot to "thank you" the first time when I used this post! So, THANK YOU! Also, my large tie-downs work as well. Slid the end cap off.
  16. Mar 26, 2011 at 3:38 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Already added the 4 original cleats into the rails. An increased versitility for securing loads in the truck.
  17. Mar 29, 2011 at 5:04 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    I have this cover also and like it.Been on since 09 and it still looks like new.Use the full size cleats with mine as well with no problems.
  18. May 21, 2012 at 10:44 AM
    novataco
    NOLA
    06 Sport V6 auto
    Hey, looking at your cargo net set-up, I bet you could attach it to two of these
    http://www.homedepot.com/h_d1/N-5yc...053&langId=-1&keyword=cargo+bar&storeId=10051
    and have a movable solid cargo divider. Might be a little pain to move two cargo bars, but it would not budge when you have something heavy like a propane tank, or lots of groceries or whatnot. Where did you get that net?
  19. May 21, 2012 at 4:19 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Since i posted that photo I have found out that the stock tie down clamps in the bed rail will work so that is an error on my part.
    The cargo net is there to hold the groceries in place against the tailgate. My Tacoma does do duty as a grocery getter on Sunday mornings after church. :cool:
  20. May 24, 2012 at 8:23 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Tom,,, How much for the yellow hard hat????:rolleyes:
