Windshield repair?
Discussion in 'Detailing' started by Oat, Nov 4, 2011.
  1. Nov 4, 2011 at 11:09 AM
    Oat
    Oat [OP] Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    My uncle is trying to sell his car. The windshield has a streaky look from bad wiper blades. It hasnt come off from hard windex rubbing/car wash. It looks like when your wipers wipe off water and you have that streaking to dry look for 5 seconds, except it is there always.
    Any solution?
  2. Nov 4, 2011 at 11:13 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Try vinegar maybe.
  3. Nov 4, 2011 at 11:13 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    There are some glass polishing compounds you can try. They are basically a really fine grit. You wet the glass, rub the compound in circular patterns and it will clean off any crap that is on the glass that won't come off with cleaners.
