Tricks to remove 3M Tape
Discussion in 'Detailing' started by LTE, Feb 15, 2012.
  1. Feb 15, 2012 at 2:52 PM
    LTE
    LTE [OP] NRA Benefactor Member
    in my own little world
    07 SR5II; Longbed; FLyzeyes LED
    window tint, step bars, Flyzeye LED interior console light
    One of my vent visors needed new tape, so I removed it and been working on getting the left over 3M tape off. I've been using a blowdryer to help make it soft. Any other tricks you guys know?
  2. Feb 15, 2012 at 2:56 PM
    OffroadToy
    Like your doing... heat it up, then goo-gone or wd40 and a plastic scraper.
  3. Feb 15, 2012 at 4:22 PM
    LTE
    That's exactly what I've been doing. Just not the Goo Gone. I think that might remove paint.
  4. Feb 15, 2012 at 5:00 PM
    OffroadToy
    I think you'll be fine but test it out on a hidden area first.
  5. Feb 15, 2012 at 5:05 PM
    03DBLCABTACO
    03DBLCABTACO Well-Known Member
    Dan
    Tomball TX
    Cavalry Blue 2019 TRD OFF-ROAD 4X4
    3m makes a product that is like an eraser wheel. I use it at the shop in my makita drill to remove bodyside moulding tape. Just be careful not to spin it too fast as it can burn the paint.
  6. Feb 15, 2012 at 11:18 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    wd 40 is amazing. spray, rub gone!
  7. Feb 16, 2012 at 11:57 AM
    Madjik_Man
    Colorado Front Range
    This ^
    I ended up using that on the residual adhesive left over from my vent visors
    ^ This.
    Used it for debadging my truck.
    Direct sun + Goo-gone + thumbnail + elbow grease = clean paint
  8. Feb 16, 2012 at 12:04 PM
    2010TxTaco
    2010TxTaco Well-Known Member
    justin
    Victoria, TX/Gulf Coast
    Black/SR5/4x4/long bed/double cab
    When I bought it, Leer camper shell, N-Fab nerf bars, Westin bull bar. So far I've put K&N air filter and Jet Performance throttle body spacer, lights behind grill, snorkel, custom grill, and weather tech floor mats. Axe and shovel w/bed mounts, high lift jack w/bed mount, and Brute force fab rear bumper.
    I would try WD40 and then rubbing alcohol that's like 70% or higher
  9. Feb 16, 2012 at 4:27 PM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    De-Solv-it. Smells good too.
  10. Feb 16, 2012 at 4:30 PM
    tacoman355
    tacoman355 WORD!?!
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
    i get this stuff from my work. works like a champ and smells like oranges. used it when i debadged. pretty expensive if you have to buy it though, lol.
    http://www.jmsonline.net/mmm-76394.htm
