UCA
Discussion in 'Detailing' started by esse10, Nov 18, 2012.
  1. Nov 18, 2012 at 9:30 AM
    esse10
    esse10 [OP] Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    Hi fellow Tacoma world mates, I have been reading several threads and posting around here about Upper controal arms ball joints with no luck.
    here is my question,
    Does anybody know if you can replace the upper ball joints in a 2nd generation Tacoma and if there is a step by step diy thread on that.
    thanks
  2. Nov 18, 2012 at 9:37 AM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
  3. Nov 19, 2012 at 6:12 AM
    esse10
    Texas
    hey thanks I was wondering why there was not enough talk about replacing just the ball joints and everybody is just talking about replacing the whole control arms instead. I don't do any Off-roading or Lift my truck up so I think keeping the original hardware is sufficiant for just pave roads...:D ***Somebody Please chime in on why I would need to replace a perfectly good part(UCA) and spend 600 plus dollars when I can just replace the $40 dollar ball joint. ***
  4. Dec 23, 2012 at 9:31 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    IMO, you dont need to replace UCA's unless you have a lift. My understanding is new UCA's on a lifted truck help the truck get realigned to factory specs for a "new truck" ride while having the lift you want on it, and it also allows the suspension to fully flex as comparted to being "stopped short" by factory UCA with aftermarket suspension. Just my 2 cents
  5. Dec 23, 2012 at 9:37 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Yea man if you just drive on the road there is no need to upgrade to a beefy control with a uniball or something. Toyota made them just fine for street driving. If you wear out your ball joints after thousands and thousands of miles then just replace it. Think about what you are going to use your truck for then go from there. Save money for other things.
