-   -   How To: Remove and disassemble side view mirrors (http://www.tacomaworld.com/forum/detailing/268400-how-remove-disassemble-side-view-mirrors.html)
PepsiManKolt 03-15-2013 12:33 PM
I know not everyone likes the look of painted side mirrors but for those of you that do here is a good step-by-step for how to do just that. It took me about 10 to take this apart and put back together. Good luck.
Tools needed:
10mm extended socket or short with an extension
Small flat head screw driver
Ratchet
T-25 bit
PH3 bit
Driver
http://i23.photobucket.com/albums/b3...psc4632e73.jpg
Remove interior side view mirror cover by pulling away from the door:
http://i23.photobucket.com/albums/b3...pse37406bd.jpg
Use flat head to reveal two Philips head screws in the door panel:
http://i23.photobucket.com/albums/b3...pse73e6703.jpg
http://i23.photobucket.com/albums/b3...ps9602d4f0.jpg
Remove electronic panel by pulling up on the front then forward and up:
http://i23.photobucket.com/albums/b3...ps7014809e.jpg
http://i23.photobucket.com/albums/b3...psf82627ad.jpg
Remove plastic clip by pushing in on the center then pulling it out:
http://i23.photobucket.com/albums/b3...ps7400a267.jpg
Unplug wiring harness and adapter from side view mirror:
http://i23.photobucket.com/albums/b3...ps2d8ab920.jpg
http://i23.photobucket.com/albums/b3...psf97b7d05.jpg
Use flat head at the bottom of the mirror class to release two clips then pull mirror down and out:
http://i23.photobucket.com/albums/b3...ps037e8ef7.jpg
Use 10mm socket and rachet to remove the 3 bolts holding mirror to the door:
Use Philips head to remove one screw holding plastic protector in place:
http://i23.photobucket.com/albums/b3...pscd5b6e5d.jpg
http://i23.photobucket.com/albums/b3...ps3382dcbf.jpg
Use flat head to remove plastic cover at the bottom of the mirror then remove 3 T-25 bolts:
http://i23.photobucket.com/albums/b3...psfe17bbf6.jpg
http://i23.photobucket.com/albums/b3...ps084e0673.jpg
Separate base from cover carefully and remove one T-25 bolt holding the metal piece in place:
http://i23.photobucket.com/albums/b3...ps9aa449b4.jpg
http://i23.photobucket.com/albums/b3...psb88a50a5.jpg
Use Philips head to remove 1 screw at the bottom of the cover:
http://i23.photobucket.com/albums/b3...ps11efcf60.jpg
Use Philips head to remove 3 screws inside the cover and remove mechanism:
http://i23.photobucket.com/albums/b3...pse0000632.jpg
http://i23.photobucket.com/albums/b3...psbf66fe26.jpg
DONE!
Repeat steps on driver side for the same results.
Follow steps in reverse to assemble everything.
MTopp 03-11-2014 07:10 PM
Great info! I know its old, but I wanted to bump it so others can use this useful information
PepsiManKolt 03-11-2014 07:18 PM
Hey, out of 569 view, if I can help one person, that's good enough for me lol
Glad the information could help. :thumbsup:
Ernesto4 04-15-2014 01:56 PM
Might not really be related to your post but I just wondering can the actual glass mirror part be purchased separately? Is there a part number for that part? Thanks
tacowhisperer 10-10-2014 04:45 PM
this thread helped me a lot! thank you! i needed to know how you disconnect the mirror part from the shell on my 1st gen and boom.. thanks again!!
tacowhisperer 10-10-2014 04:47 PM
ernesto4 i had your same problem and no one will sell it separate so i found an oem complete one at the junk yard for 30 bucks!! woo hoo!!!
