Super Glue removal
Discussion in 'Detailing' started by Marc M, Jun 30, 2009.
  1. Jun 30, 2009 at 7:26 PM
    Marc M
    Marc M [OP] Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    How do you remove super glue from glass or a painted surface?
    Marc M
  2. Jun 30, 2009 at 7:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for glass.....you can use a razor blade and a lil lacquer thinner....from a painted surface, try soaking it in goo gone or goof off.....put it on a rag and set the rag on it for a while and it may loosen up.
  3. Jun 30, 2009 at 7:41 PM
    Gsquare
    Gsquare The G stands for smooth
    GG
    Lone Star State
    2018 - TRD Off Road 4x4 - Cement / Graphite - DCSB
    ReadyLIFT 3/2 Lift Kit, T-Force TRD Black Satin Spoke Wheels, OEM TRD Red/Black Resin Center Wheel Hub Covers, Toyo P285/70R17 Open Country AT's, SpiderTrax 1.25 F/R Wheel Spacers, Blackout Pkg: Tailgate Letters, Badges and Tailpipe Extension, Qi Wireless Charging, LED Bed Lights, Power Tailgate Lock, Shark Running Boards, Weathertech Floor Mats, U.S. Airforce Decal Drivers Side Rear Window, MESO Gasshole Fuel Cap Holder, OEM Trailer Hitch Cap
    Super glue remover is available at your local hobby shop.
    I got some super glue on the counter top in my kitchen one time and this stuff cleaned it right off, and just before the wifey got home. *whew*
  4. Jun 30, 2009 at 7:47 PM
    Marc M
    Marc
    '06 TRD O/R Dbl-Cab
    I just picked up a 2005 Corolla XRS. Previous owner re-attached the loose vent visors with super glue, and re-attached some little round mirrors on the side mirrors.
    I'll look for the remover. I usually use a razor blade on glass, but mirrors scratch so easily.
    Thanks Guys
    Marc M
  5. Jul 10, 2009 at 11:26 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2 Thats how I debadged my truck...with goo gone and a plastic razorblade, all available at Autozone or Home Depot
  6. Jul 10, 2009 at 11:38 AM
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    All you need is acetone. Sometimes found in nail polish remover. Let it sit on the super glue area for a while. When you come back it'll peel/rub off.
  7. Jul 10, 2009 at 11:41 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Most things that will remove super glue will also remove paint. I would try scraping it off before I used any chemicals.
  8. Jul 10, 2009 at 11:43 AM
    98tacoma27
    Ben
    Not Beech Creek
    Chris should be an expert in this feild.
    :popcorn:
  9. Jul 10, 2009 at 11:45 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    he's too busy licking rocks.
  10. Jul 10, 2009 at 11:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    Still? Well, at least we know he is an expert in the application of super glue.
  11. Jul 10, 2009 at 11:47 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Goof Off 2 works great on paint and plastics. Just make sure you wash and wax the paint after you're done getting the glue off.
    Goof Off 2. That "2" is important. Regular Goof Off is xylene-based and will eat right through most things.
