how to safely remove paint off cement garage floor
Discussion in 'Garage / Workshop' started by TacomaPrime, Jan 22, 2012.
  1. Jan 24, 2012 at 1:07 PM
    #21
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    i have a 4000 psi dewalt pressure washer, thing is a monster, i put the 0* nozzle on and it blows concrete off my driveway, paint doesnt stand a chance with it
  2. Jan 24, 2012 at 6:35 PM
    #22
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    what kind of paint?.. i'd try spraying some krud kutter, let it sit, keep wet and agitated, that may be able to soften it, then try taking a metal-bristled broom/brush to it...
  3. Feb 20, 2012 at 11:14 AM
    #23
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    You have an obsession with white don't you?
  4. Feb 20, 2012 at 11:18 AM
    #24
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Pressure washer should do the trick, especially if it's not a proper paint. Should come up w/little pressure, IMO. It'll keep the dust down vs sanding, etc. Just cover the drywall if it's down to the floor; tape those cheap $1 plastic drop cloths around and you'll be good. Best to do it on a good and hot dry day too.
  5. Jun 6, 2012 at 7:42 AM
    #25
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Have you tried removing it yet?
  6. Jun 6, 2012 at 8:01 AM
    #26
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    Not yet. I've been busy with some landscaping stuff, and whatnot.
  7. Jun 11, 2012 at 9:23 PM
    #27
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    If you do the pressure washer route you can get a fat looking nozzle that uses the pin type stream but it sprays out in a swirl pattern. You get the cutting of the pinhole nozzle but the coverage of a fan. Works real good.
    I was lucky that my garage was new concrete but I simple greened, scrubbed, power washed, simple greened, scrubbed, rinsed, then started with the rustoleum water based epoxy after the included acid etch. Finished it off with the solvent epoxy clear from rustoleum. It looks great and has been holding up very well.
    When I was moving in I scratched it when the pallet jack hit a pebble so it's not indestructable but it's quite good. Tip for the paint flecks, blow them on. Either put them on the palm of your hand or on a plate/saucer and blow them off. Perfect, even distribution that way.
    If you get it all off and don't want to do the epoxy (or can't if the concrete is too moist) a couple coats of a quality concrete sealer will do a nice job and make the floor resistant to soaking up liquids and staining and also really easy to sweep and clean.
    A wire cup attachment on a grinder should work for removal too.
