Any plumbers? Shower help
Discussion in 'Garage / Workshop' started by rondog, Mar 11, 2012.
  1. Mar 11, 2012 at 11:51 AM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    So my shower has always been super hard to turn off and even with it "off" It would still drip a little. I replaced both broaches as well as the circle square thing behind the broach.....after all that the shit still leaks...it seems it's leaking even more now, wtf! Is it possible I have the wrong broach installed? I got the same exact one I replaced.
  2. Mar 11, 2012 at 12:03 PM
    Stew
    Stew Well-Known Member
    Stew
    Greenville, NC
    White 04 Single Cab 2.7 4x4
    2.5in ^, debadged, fog light mod, deck plate, line-x, tool box
    not a plumber but I maintain an apartment complex so I might can help. I'm not familiar with the term broach related to faucets though I assume you're talking about the diverter, and since you said both I assume you have a two handle faucet and not a single handle correct?
    First things first what brand is it and what model?
    http://www.faucetpartsplus.com/category_s/28.htm
    If you can find it on there, each type has a different number of parts. Its clearly not sealing right, did you check with your finger and a flashlight while you had it apart to see that there was nothing foreign in the pipe or make sure it had no dents or dings where water could pass. I know it sounds strange and with it so isolated seems impossible but I've seen many things happen inside pipes I would've never imagined could happen. If its always been hard to turn something could've been installed wrong you may want to try taking the parts out you put in and moving them around to see if they fit better another way.
  3. Mar 12, 2012 at 10:43 AM
    rondog
    Ronnie
    Escondido/San Diego
    thanks for the reply stew. I think broach is the size of the valve stem..pretty sure I just meant valve stem like the one below. It is a two handle shower.
    The second piece I replaced that goes behind the stem is in this picture (the small piece in the middle)
    I figured it was the cold water valve only because the water that was dripping was cold. I started there and after removing the stem, I noticed the piece behind it in the above picture was no longer seated in the threads. I removed it and when I pulled it out, it was broken. Brand new piece separated from the threads. Picked a new one up this morning and bam, no more leaks. I am just surprised that it broke so easily. I may have tightened it too much the first time.
  4. Mar 12, 2012 at 10:53 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    PM Brutalguyracing
    He's a turd burglar
  5. Mar 12, 2012 at 10:55 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Is he a plumber or a pipe-fitter? :D
  6. Mar 12, 2012 at 10:58 AM
    XXXX
    sKiP
    05 Prius
    Not sure how NY classifies them.
    Here your a plumber or a steam fitter.
  7. Mar 12, 2012 at 11:00 AM
    scocar
    scocar hypotenoper
    Again, congrats. :crapstorm:
  8. Mar 12, 2012 at 11:01 AM
    Pugga
    Massachusetts
    Just a union joke, a pipe fitter only deals with clean pipe, a plumber is the one you call when your toilet backs up :D
  9. Mar 12, 2012 at 11:01 AM
    XXXX
    sKiP
    05 Prius
    Fuck you asshole
  10. Mar 12, 2012 at 11:02 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    If you replaced the stem then it should not leak, Sounds like you got it solved, replacing the whole assembly is so cheap. Anymore so I just replace everything if I cannot re adjust the valve stem to keep it from leaking anymore. I am not a plumber but I have owned 3 homes and have done my own maintenance.
    What's the difference between a doctor and a plumber?
    A doctor washes his hands AFTER he has gone potty, but a plumber washes his hands BEFORE he goes potty.
    - provided by David Zuckerman of A All Types Plumbing, Utah
    Some humor that is so true.
  11. Mar 12, 2012 at 11:02 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    It's possible that you can have the wrong stem. Even though they look the same they could be slightly off or use different o-rings. I'm not a plumber, but I work in the plumbing wholesale field. We sell plumbers the parts to fix your stuff. This is where we buy our parts from that we sell to them. It should help you match up what you have and make sure you have the correct replacement. Do you know who makes the one you bought?
    http://www.kissler.com/Downloads/Faucet%20Stems%20_B.pdf
  12. Mar 12, 2012 at 11:18 AM
    rondog
    Ronnie
    Escondido/San Diego
    It wasn't the wrong valve stem, in fact it wasn't the stem at all. It was the piece that goes behind the stem. I bought two of these little guys and 2 new stems which is why I was baffled as to why it was leaking since I had just put all new stuff in..turns out the brass pieces I bought was broken and thats why it was leaking...pics below of what it should look like and where it broke
  13. Mar 12, 2012 at 11:20 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    :eek:
  14. Mar 12, 2012 at 11:22 AM
    rondog
    Ronnie
    Escondido/San Diego
  15. Mar 12, 2012 at 11:35 AM
    Bryan139
    NJ
    '09 Sport
    That's awesome you got it fixed cuz there's about 60 pages of stems to choose from.
  16. Mar 12, 2012 at 11:36 AM
    rondog
    Ronnie
    Escondido/San Diego
    I got the stems at lowes..they had maybe 20 to choose from. I just got the same one I had previously
  17. Mar 12, 2012 at 5:37 PM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    It's called a seat btw. The brass is soft and doesn't like to be over tightened. Not all plumbers get dirty. That's why I am a commercial plumber. All new clean pipe. New buildings are where it's at. Screw chasing turds and dealing with peoples dirty clogged pipes, for the birds. Fitters usually deal with steam or the guys that assemble the piping for refineries and the piping you would see in a beer manufacturing plant, etc.... Glad you got it fingered out. ;)
  18. Mar 12, 2012 at 6:56 PM
    Stew
    Stew
    Greenville, NC
    Glad you got it figured out
  19. Jun 28, 2018 at 5:35 AM
    Goose8651
    Goose8651 Well-Known Member
    DFW
    2013 Double Cab
    Sorry this is an old thread bump, but hoping someone can help me out as it is related i think. I am somewhat running into the same problem with my home. I have a three handle shower tub that I believe I need to purchase a new stem and seat. The middle handle which diverts the water from either my faucet or showerhead is extremely hard to close to shut water off on either device. Currently, if I have the shower head on, the faucet will still leak water and I have to close that handle extremely tight and water still will come out of the faucet. So, due to that, reason I think I need a new stem/seat.
    My plan was to try to take apart the handle and remove the stem tonight. Was going to go to a local hardware store after work on Friday and grab a new stem and seat since I will have the part. My question is that since I am planning to only take apart the center handle/valve, do I technically need to turn off my water? Unfortunately, due to my work schedule, I cannot remove and replace the stem in one day. Was hoping to remove the stem tonight (Thursday), purchase the part on Friday afternoon, and then either install it Friday night or on Saturday once I am off work. Do not want to keep my water off from Thursday night all the way through Saturday while I am getting my parts. I have another tub so can take showers and what not no problem. I attached a photo hopefully explaining what I am needing a little bit better. Any help is greatly appreciated.
