Go Back   Tacoma World Forums > Off-Topic > Garage / Workshop
Drilling SS need tips please
Old 06-01-2012, 05:35 AM   #1
Airun [OP] Airun is offline
Airun is one of the sharper tools in the shedAirun is one of the sharper tools in the shedAirun is one of the sharper tools in the shedAirun is one of the sharper tools in the shedAirun is one of the sharper tools in the shedAirun is one of the sharper tools in the shedAirun is one of the sharper tools in the shedAirun is one of the sharper tools in the shedAirun is one of the sharper tools in the shedAirun is one of the sharper tools in the shedAirun is one of the sharper tools in the shed
Airun's Avatar
Airun's Tacoma Gallery
Smile Drilling SS need tips please
Need tips on drilling holes in stainless steel saw blade for my rear tine tiller converted to wire trencher.
Basically I have a 14" fire and rescue blade that needs 4, 3/8" holes for the hub/collar to mount up (I'll get pics up later).
Anyway I'd tried this years ago with regular drill bits and it was a joke.
I know I need low rpms and some oil. What I don't know is exactly what kind of bit is best????titanium, carbide etc.
Please help any recommendations appreciated.
Old 06-01-2012, 05:51 AM   #2
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
I hate machining SS. I would start with pilot holes and work your way up to the 3/8" bit.
The cutting speed is 30-50 so using this formula:
This is for HSS bits
(CS X 4)/drill size = RPM
So a .250" HSS bit should be run at
(40X4)/.25 = 640 RPM
(50X4)/.25 = 800 RPM
.375"
(40X4)/.375 = 427 RPM
(50x4)/.375 = 533 RPM
With carbide you can generally go twice as fast but seeing how this is SS I would not recommend it. SS work hardens very quickly if not machined properly.
Go slow and easy, plunge and retract, and use plenty of oil.
Old 06-01-2012, 05:56 AM   #3
:POOPCORN:
98tacoma27's Avatar
Marines:
TiN coating helps preserve the bit too.
Old 06-01-2012, 06:26 AM   #4
Cypherian is one of the sharper tools in the shedCypherian is one of the sharper tools in the shedCypherian is one of the sharper tools in the shedCypherian is one of the sharper tools in the shedCypherian is one of the sharper tools in the shedCypherian is one of the sharper tools in the shedCypherian is one of the sharper tools in the shedCypherian is one of the sharper tools in the shedCypherian is one of the sharper tools in the shedCypherian is one of the sharper tools in the shedCypherian is one of the sharper tools in the shed
Cypherian's Avatar
Air Force: 2A773 Retired
Cypherian's Tacoma Gallery
Hey,
135 Deg Split Tip Cobalt bits work well with lube the coatings that come on them are fine for extending the life of the bit but thats all they really do. For stepping to a 3/8ths hole I would go 1/8, 5/32, 3/16, 1/4, 5/16, 3/8 here is a link to a speed and feed calc for you. http://www.ttp-hard-drills.com/drilling-speed.html This is all with out knowing exactly what that blade is made of I looked there are several dozen variations lol. I have used the above method drilling may types and grades of stainless but every alloy is DIFFERENT. 98tacoma is very correct it takes a millisecond to work harden Stainless and then your done unless you happen to have some really expensive industrial diamond bits one of which might run you 60 bucks plus. You want to use a cutting oil not just regular motor oil btw.
Cypher
Old 06-01-2012, 04:56 PM   #5
Airun's Avatar
Sweet guys thanks for the tips!
Old 06-01-2012, 04:59 PM   #6
Pelfreybilt Off-Road
Socalduckslayer is one of the sharper tools in the shedSocalduckslayer is one of the sharper tools in the shedSocalduckslayer is one of the sharper tools in the shedSocalduckslayer is one of the sharper tools in the shedSocalduckslayer is one of the sharper tools in the shedSocalduckslayer is one of the sharper tools in the shedSocalduckslayer is one of the sharper tools in the shedSocalduckslayer is one of the sharper tools in the shedSocalduckslayer is one of the sharper tools in the shedSocalduckslayer is one of the sharper tools in the shedSocalduckslayer is one of the sharper tools in the shed
Socalduckslayer's Avatar
Socalduckslayer's Tacoma Gallery
Dont use carbide unless everytihg is really stable. Cobalt should be fine, like others said, do it in steps. Only concern is that it may be a treated stainless since its a type of blade. Common 300 series stainless should be ok but if its a form of precipitation hardened stainless it could get pretty tough.
Old 06-01-2012, 05:59 PM   #7
Airun's Avatar
Slowly but surely (hopefully).
Old 06-01-2012, 06:55 PM   #8
Rich91710's Avatar
Rich91710's Tacoma Gallery
OMFG.... you didn't say you were doing it with a hand drill! I assumed you were using a press.
Wow... That's going to take some time and a LOT of oil... I have a hard time getting enough pressure on a hand drill to go through SS.
Old 06-01-2012, 07:13 PM   #9
Airun's Avatar
Oh yeah I know better, but my drill press and two others locally are all too small a radius for a 14" blade to set on so I figured F it, I'll just go slow and use an ass load of oil and see what happens. I've actually made good progress . I'm probably 10-20% along after 45 min of work LMFAO. Definitely sacrificing several bits to appease the gods of cutting mayhem.
Old 06-02-2012, 07:37 AM   #10
Cypherian's Avatar
How did you make out?
Old 06-02-2012, 07:59 AM   #11
Airun's Avatar
Just getting ready to hit it again in a couple hours.
Old 06-02-2012, 12:20 PM   #12
Airun's Avatar
Smile
Got a set of cobalt bits and finished up. Went surprisingly well. Probably another 45 minutes of work.
Thanks again guys
Tire & Wheel Tips: Simple tips to get the most out of your new look. genxer36 Wheels & Tires 9 02-04-2015 08:25 PM
Off shore drilling.....when?! THExBUSxDRIVER Off-Topic Discussion 40 02-23-2011 02:59 PM
NO DRILLING ELMOTM Audio & Video 15 02-10-2011 04:27 PM
roof rack with no drilling? kinkrider101 2nd Gen. Tacomas 12 10-21-2010 10:40 PM
Drilling muffler polkbassin Performance and Tuning 16 01-03-2009 10:33 PM
