Go Back   Tacoma World Forums > Off-Topic > Garage / Workshop
Surface Rust Fix? (Estwing hammer / hatchet)
Old 10-20-2013, 10:24 AM   #21
wileyC is one of the sharper tools in the shedwileyC is one of the sharper tools in the shedwileyC is one of the sharper tools in the shedwileyC is one of the sharper tools in the shedwileyC is one of the sharper tools in the shedwileyC is one of the sharper tools in the shedwileyC is one of the sharper tools in the shedwileyC is one of the sharper tools in the shedwileyC is one of the sharper tools in the shedwileyC is one of the sharper tools in the shedwileyC is one of the sharper tools in the shed
wileyC's Avatar
wileyC's Tacoma Gallery
Originally Posted by Pugga View Post
Fine sand paper or even steel wool to remove the rust, then you can clear coat it if you feel the need, or paint it. Either that or keep it oiled but I wouldn't use engine oil as mentioned above (although it will work). I'd use something like a 3 in 1 oil or gun oil if you have that.
this.
...i'd try using wd-40 and some fine steel wool to get rid of the rust, ...i'd try to stay away from sandpaper, especially the courser stuff that was mentioned earlier in the thread...
...i've been using rem-oil (comes in a spray can) to wipe down/coat my tools after using, ...especially wood rasps, as these seem to gather rust quickly if not cleaned (brushed out), ..i coat them w/ rem-oil after use...
Surface rust spot (2011) usafwx 2nd Gen. Tacomas 7 06-05-2013 10:22 AM
Frame surface rust Redsoxnation Detailing 17 06-08-2011 01:12 PM
Surface rust the1pingman 2nd Gen. Tacomas 8 09-03-2007 03:35 PM
