using gas generator in severe weather
Discussion in 'Garage / Workshop' started by mccarroll, Feb 2, 2013.
  1. Feb 2, 2013 at 12:31 PM
    mccarroll
    mccarroll [OP] Well-Known Member
    Newfoundland, Canada
    2012 DC 4X4
    So i just picked up a 5000w gas generator to power the house during outages. My question is what do you put it in when the weather is poor. I have an attached garage, and i know i cannot use it in there. Do I need to build some kind of mini-shed to keep it out of the snow and rain?
  2. Feb 2, 2013 at 12:38 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    Gen Tent portable generator safety canopy....
  3. Feb 2, 2013 at 12:40 PM
    roadking1
    n.j.
  4. Feb 2, 2013 at 12:56 PM
    mccarroll
    2012 DC 4X4
    No offense, but we get 100 kmh winds with snow or rain. That thing looks like it just protects the very top in winds like that. No?
  5. Feb 2, 2013 at 1:07 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Build an open walled roof over it if you're worried about it
  6. Feb 2, 2013 at 1:09 PM
    mccarroll
    2012 DC 4X4
    Just afraid blowing snow would get in everywhere. I need something that breathes and keeps blowing snow out.
  7. Feb 2, 2013 at 2:58 PM
    Sido
    Sido Well-Known Member
    Anchorage
    None
    Could you keep it in the garage and have the garage door open? Or build your own exhaust extension to run the fumes outside?
    The serious generators I've seen have been in their own sturdy, well constructed shelters near the house that are partially dug into the ground. Looks like that may be your only option.
  8. Feb 2, 2013 at 3:03 PM
    OZ-T
    Peter North
    British Columbia
    So this is a portable ?
    How are you hooking up to the house ?
  9. Feb 2, 2013 at 4:03 PM
    roadking1
    n.j.
    the gen tent worked great during a hurricane
  10. Feb 3, 2013 at 4:35 AM
    mccarroll
    2012 DC 4X4
    Yes, running the cord under the garage door to a transfer panel that I am having professionally installed.
  11. Feb 3, 2013 at 4:52 AM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I am in Florida and we use generators during hurricanes. That size is the bare minimum needed to run a few lights and a refrigerator. I kept mine in the garage until the storm passed and then used it to keep my food cold ,run a few lights and a box fan. I want to do what you stated and have a dedicated way to install into electrical service as to not back feed power and keep electrical workers safe when they do get around to repair electrical service.
  12. Feb 3, 2013 at 5:07 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I built something similar to that gen tent, used framing and ply wood and tyveked it, sits on top kind of like a cap, then i use ratchet straps to secure it to the generator.
  13. Feb 3, 2013 at 9:37 AM
    OZ-T
    Peter North
    British Columbia
    Cool
    I have a similar set up
  14. Feb 4, 2013 at 4:22 AM
    mccarroll
    2012 DC 4X4
    I am thinking now that maybe a heavy tarp anchored to a large planter, the deck and a few cinder blocks might be the easiest and best way to do this. My main fear was making the gen get too hot in some sort of box like structure.
  15. Feb 4, 2013 at 5:20 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Run it in the garage and leave the door open. If the wind is blowing that hard, it should circulate the fumes out of the garage. Another option is they make plastic tubes with a fan at the end, the fan needs to be facing out to pull the exhaust fumes away from the generator and force them outside.
    Like this, just smaller.
  16. Feb 4, 2013 at 5:51 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Thats a definite concern especially when using plywood. I should take a picture of mine for you. I couldn't cover the generator completely for that reason. But it keeps it dry for the most part, i was also worried about 80mph winds
  17. Feb 4, 2013 at 6:04 AM
    Pugga
    Massachusetts
    Get fire treated plywood. It will still burn if it gets hot enough but it takes a lot to make it catch. The plywood shouldn't be close enough to catch fire anyways. If you are putting it that close, line the plywood with sheet metal and use something to space the sheet metal off the plywood like 1/4" or so (metal side faces the generator, the air space between the metal and plywood keeps the wood from burning).
  18. Feb 4, 2013 at 6:09 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I am building a shed out by my generator hook up which is about 75 yards from my house but I was also looking at doing an enclosure like this..http://www.nooutage.com/images/GenShed-generator.jpg. Home Depot sells the enclosure for around $250 and then you just have to vent it and get an attic fan and install it. It doesn't show it on this enclosure but I would also pipe out the exhaust.
  19. Feb 4, 2013 at 6:12 AM
    dexterdog
    Oly WA
    2012 F150
    As long as you have it ventilated I wouldn't worry about anything burning up. I put a tarp over mine last year and the only issue I ran into was that the exhaust burned a hole through the tarp.
  20. Feb 4, 2013 at 6:14 AM
    Runn0r
    Runn0r Well-Known Member
    NC
    07 Prerunn0r
    To be honest, I would build a small brick container for it outside that locks....Think about it....huge storm comes, huge power outage...Generator's sold out....Thieves driving around at 3AM.....Hey look! That guy has power! Not to mention the noise of it running could attract thieves.
    Secondly, check out the natural gas/propane conversion kit's. These are awesome because they dont require extreme modification and you can run your gen. off of Gas, NG or LP.
    http://youtu.be/CaJixPkWvR0
    http://www.propanecarbs.com/
