Can I hose off my front door?
Discussion in 'Garage / Workshop' started by drewskie, Mar 21, 2013.
  1. Mar 21, 2013 at 12:02 AM
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    And windows for that matter?
    I try to keep the outside of the house clean, but wiping everything down takes forever and seems to come back the next day.There's a black soot-like film everywhere. I hosed everything down a few times and that works 100 times better, but I'm sure its bad for the wooden surfaces, and may get water into the wall. How bad is hosing down the front porch, and door?
    Do you guys have a better way? Besides just ignoring it?
  2. Mar 21, 2013 at 12:25 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    I take my pressure washer to both front and back porch never had an issue and i have an older house
  3. Mar 21, 2013 at 7:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I would assume any & all wooden surfaces are painted or stained..... and in good shape. It really shouldn't matter hosing them down. The surfaces are outside and exposed to rain anyway.... and the paint/stain should be the proper paint for outside exposure. You can buy cleansers at Lowes/Home Depot to spray on the surfaces first and hose off.
    Try an area that's out of sight and run a TEST. It all depends on a lot of factors - the type of wood, the type of stain/pain, the age of the wood, the age of the paint/stain. etc.
    I use a combination of pressure washer & cleansers on the house (alluminum & wood siding). We have T111 siding with stain. We power washed a section of it and it turned a different color (it had faded). We knew.... it was time for a new stain job. We just re-stained it this past summer.
  4. Mar 21, 2013 at 7:33 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Should be fine , try not to trap bulk water in any of the glazing stops in your windows or doors though , water freezing in there is a primary cause of thermo-pane failure
  5. Mar 22, 2013 at 1:23 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Personally I wouldn't take a hose to a entry wood door but anything else I would including windows.
  6. Jun 19, 2013 at 12:17 PM
    Marc702
    Marc702 Well-Known Member
    Marc
    Las Vegas
    DC/PRERUNNER
    Just hosed off my front door this morning. Follow up with a little wipe down. No big deal.
  7. Jun 19, 2013 at 12:19 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If it's the exterior side, why not? It gets wet during every rain storm, what's a hose going to do to it?
  8. Jun 19, 2013 at 12:23 PM
    Marc702
    Marc
    Las Vegas
    DC/PRERUNNER
    That's a damn good point right there.
  9. Jun 19, 2013 at 12:32 PM
    OZ-T
    Peter North
    British Columbia
    ^^ ding ding ding
  10. Jun 19, 2013 at 12:34 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Just use a little common sense here and you should be good with a garden hose.
  11. Jun 19, 2013 at 1:28 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    X2. If you get water inside your house, then you now know that your door seal needs repairing in some way.
  12. Jun 19, 2013 at 5:31 PM
    greatvalue
    greatvalue New Member
    That is true a way to test your seals.
  13. Jun 19, 2013 at 5:33 PM
    OZ-T
    Peter North
    British Columbia
    Inswing doors aren't going to keep water out when you spray them with a hose
  14. Jun 19, 2013 at 5:43 PM
    Southern01Taco
    Sean
    Holden, La
    I thought all doors have a rubber seal around them to keep them fairly air tight. Either on the door frame or the door itself.
  15. Jun 19, 2013 at 5:44 PM
    OZ-T
    Peter North
    British Columbia
    Yep , outswing doors are bullet proof , inswing doors , not so much
  16. Jun 19, 2013 at 5:51 PM
    Southern01Taco
    Sean
    Holden, La
    Oh ok. I didn't know that. Both of the doors on our house are inswing doors, so I assumed they were just as good at sealing.
  17. Jun 19, 2013 at 5:53 PM
    WTFaulkner
    WTFaulkner Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    Id take oz's advice on this one he is a master craftsmen:)
  18. Jun 19, 2013 at 5:55 PM
    OZ-T
    Peter North
    British Columbia
    The big difference is at the sill , inswings generally rely on the sweep to contact the sill in order to make a good seal , this is fairly easily defeated by water directed at it by a hose or even high wind , outswing doors close against the bottom sill allowing for a more robust connection
  19. Jun 19, 2013 at 6:03 PM
    Southern01Taco
    Sean
    Holden, La
    That makes perfect sense. I guess I've never really thought about it before.
  20. Jun 20, 2013 at 10:22 AM
    TailDrag
    TailDrag Well-Known Member
    If you need to pressure wash your exterior glass, be mindful of your spray pattern and PSI. I used to do side work for my girlfriend's uncle's power washing business and windows, especially large(r) can be shattered easier than you'd think. Avoid spraying high pressure, particularly in the middle of the window (should be obvious why), and as others have mentioned, when you hit the corners, move quickly so you're not forcing water places it shouldn't be going.
    I don't power wash my front door, but I will spray it with a garden hose. Even a small pressure washer is too much pressure for an insweep door. I particularly would avoid pressure washing any stained wood front doors unless you need to and you've got the sweep down, lest you remove stain unexpectedly, or burn and chew up your door with the wrong PSI, spray pattern, distance from surface, style of sweep, etc,.
    A quick and easy way to ruin a wood surface, if you're not familiar with how to do it.
