Go Back   Tacoma World Forums > Off-Topic > General Automotive
loose hub? on trailer
Old 07-25-2011, 12:07 PM   #1
113tac [OP] 113tac is online now
113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed
113tac's Avatar
113tac's Tacoma Gallery
Okay guys my family just got a jet ski and it came with a trailer. one of the wheels on the trailer is loose like i can grab it move it sides ways a little bit. idk if that safe to drive on so i was wondering what you guys thought. if it isnt safe(im assuming its not that safe) do you guys know how to tighten the hub?
here are some pictures for reference of the type of trailer/ axle
Old 07-25-2011, 12:22 PM   #2
Dewey7015 is on a distinguished road
Dewey7015's Tacoma Gallery
Hey 113tac,
I think you should take that entire hub apart..dead blow hammer to get the bearing buddy off. Clean all the grease off, and loosen the large nut that is behind the bearing buddy. Basically take it all apart.. there is slop in the bearing. It could just be that the large nut has backed off a bit, or the bearings could be shot.. ($20)..
hope this helps.
D.
Old 07-25-2011, 12:27 PM   #3
braaap
steve o 77's Avatar
steve o 77's Tacoma Gallery
Originally Posted by Dewey7015 View Post
Hey 113tac,
hope this helps.
D.
^^this.
there should also be a cotter pin that must be removed before the nut will come off.
when re assembling, tighten the nut just until there is no slop side to side, and no more. Use a new cotter pin.
Also, make sure you pack the bearing correctly, look it up on youtube if you don't know how.
good luck.
Old 07-25-2011, 12:31 PM   #4
113tac's Avatar
thanks for the info. i will probably check it out soon
Old 07-25-2011, 12:38 PM   #6
113tac's Avatar
would bad bearings cause a rougher ride also?
Old 07-25-2011, 12:49 PM   #8
113tac's Avatar
alright well then im assuming its the bearing then cause the ride isnt that great especially at low speeds
Old 07-25-2011, 10:08 PM   #9
When up to your nose in shit, keep your mouth shut
CorrosiveTendency is one of the sharper tools in the shedCorrosiveTendency is one of the sharper tools in the shedCorrosiveTendency is one of the sharper tools in the shedCorrosiveTendency is one of the sharper tools in the shedCorrosiveTendency is one of the sharper tools in the shedCorrosiveTendency is one of the sharper tools in the shedCorrosiveTendency is one of the sharper tools in the shedCorrosiveTendency is one of the sharper tools in the shedCorrosiveTendency is one of the sharper tools in the shedCorrosiveTendency is one of the sharper tools in the shedCorrosiveTendency is one of the sharper tools in the shed
CorrosiveTendency's Avatar
CorrosiveTendency's Tacoma Gallery
(Wheel on)If there is more than a 1/16th inch or so of side play its probably bad bearing. Pull the wheel and spin the bearings, you will know if they are toast or not by how it feels. Small trailer wheels often have a slight side-play to the wheel on the spindle. Either way, cheap fix if you take care of it before the wheel goes rolling by you on the highway. Seen too many drivers out there who don't check trailer wheels/bearing until its too late.
Old 07-26-2011, 10:23 AM   #10
113tac's Avatar
good info. its more than 1/16th of an inch its maybe closer to 1/4 or 1/2 inch each way. i definitely want to fix it before that happens haha
Old 07-26-2011, 02:16 PM   #11
braaap
steve o 77's Avatar
also just a small tip, whenever towing a trailer on the freeway for long stretches, always pull over every 100 miles or so to check the temp of the hubs. They should stay warm to the touch at most. If they're heating up you either have too much preload or not enough grease.
Old 07-26-2011, 02:52 PM   #12
113tac's Avatar
good to know. i dont think ill be towing that long though. probably at most 30 miles that i can see in my near future haha
Old 07-26-2011, 04:25 PM   #13
braaap
steve o 77's Avatar
cool, good luck with it.
Old 07-26-2011, 04:52 PM   #14
113tac's Avatar
thanks man!
Old 07-26-2011, 05:24 PM   #15
maineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shed
Law Enforcement:
maineah's Tacoma Gallery
Little wheels spin very fast trying to keep up with 15+" Tacoma wheels they take a beating you should pack/inspect at the very least once a year. The bearing buddies are intended to be used to force water out (after a boat launching) and really are not a substitute for a bearing repack.
Loose Outside Mirrors...? Rossi396 2nd Gen. Tacomas 52 02-29-2012 07:16 PM
Loose wires? StormTrooper Lighting 0 11-26-2010 08:28 PM
pics of relocated trailer wire harness & hauling 14ft trailer DueNorth Towing 8 10-03-2010 11:05 AM
Hub Caps (center wheel hub) Lost one - DAMNIT! majorvices 2nd Gen. Tacomas 7 01-09-2009 04:14 PM
Snooze You Loose 4x4x4trd Off-Topic Discussion 28 04-18-2008 02:32 PM
