Go Back   Tacoma World Forums > Off-Topic > General Automotive
Horse power Hype
Old 12-06-2011, 09:02 AM   #1
New Mexico Taco is one of the sharper tools in the shedNew Mexico Taco is one of the sharper tools in the shedNew Mexico Taco is one of the sharper tools in the shedNew Mexico Taco is one of the sharper tools in the shedNew Mexico Taco is one of the sharper tools in the shedNew Mexico Taco is one of the sharper tools in the shedNew Mexico Taco is one of the sharper tools in the shedNew Mexico Taco is one of the sharper tools in the shedNew Mexico Taco is one of the sharper tools in the shedNew Mexico Taco is one of the sharper tools in the shedNew Mexico Taco is one of the sharper tools in the shed
New Mexico Taco's Avatar
Air Force: Retired
New Mexico Taco's Tacoma Gallery
Horse power Hype
I am not a mechanical engineer nor do I claim to be one so maybe someone that is can clarify this for me. Ford and Jeep claim all this extra horse power with smaller engines at higher rpms. What about the torque needed to get some work done. I always thought torque counted also.
Old 12-06-2011, 09:13 AM   #2
Say no to Bro
kirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shed
kirkofwimbo's Avatar
kirkofwimbo's Tacoma Gallery
AFAIK this is why the Tacoma did not get the upgraded Dual-VVTi V6 that the 4 runner and FJ get, even though it has less horsepower, it is producing more torque at a lower RPM
Old 12-08-2011, 08:07 PM   #3
iroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shed
iroh's Avatar
iroh's Tacoma Gallery
For the physicist, horsepower = torque x rotational speed. Can't measure horsepower, you can only calculate it from torque measurements.
Horsepower does count in that it is directly related from one side of the transmission to the other. If you increase engine torque, obviously you increase wheel torque. If you give the engine a few more rpm that it can actually make usable torque with (which would calculate to more horsepower), you can also put shorter gearing in the transmission to match the change, and increase wheel torque.
It also depends on where you want your torque to peak. Do you drive at lower rpm pulling trailers all day, do you want the first punch off the line, or do you just hot rod onto the freeway and want all the upper rpm power you can get? Everyone's needs are different.
As for Ford's torque claims... I wouldn't consider jumping 400+ lb-ft by 2000 rpm on a 3.5L V6 a lack thereof.
As for the hype of horsepower, everyone is guilty. Even the 1GR - that 236 hp or whatever Toyota says only happens the millisecond before your rev limiter kicks in. No running over the power peak on this one.
Old 12-08-2011, 08:13 PM   #4
McBride513 is on a distinguished road
McBride513's Tacoma Gallery
Horsepower sells cars, torque wins races
Old 12-08-2011, 08:20 PM   #5
Banned
It is a number race like always.
Old 12-08-2011, 09:15 PM   #6
The TW 1%
ForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shed
Coast Guard: Chief Petty Officer, ITC
ForeRunner's Tacoma Gallery
Tacoma is rated at 236hp and 266lb-ft at 4,000 rpm.
4Runner is rated at 270hp and 278lb-ft at 4,400 rpm
FJ is rated at 260hp and 271lb-ft at 4,400rpm.
I just don't have the specific torque curves on the three engines. I'm curios why the FJ's engine is less than the 4Runner's when they are the same engine. Unless it's with the ECU.
Old 12-08-2011, 10:27 PM   #7
shampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud of
shampoop's Tacoma Gallery
Good low end torque is easy and nothing new. What is new and awesome is adding top end power to vehicles that never had them in the past. For example the average half ton truck needs the good torque of an average v8 to have the power to move large amounts of weight, but when you add lots of top end power to the equation, you then have the power to easily pass people and make it up the mountain pass when loaded down at speed.
Old 12-09-2011, 08:07 AM   #8
Resident Jackass
Krazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shed
Krazie Sj's Avatar
EMS: EMT - Alberta Health Services - Olds
Krazie Sj's Tacoma Gallery
There's also something to be said about overtuning engines and longevity. Specially with trucks. Keep it a little lower and it'll last longer. It's a truck not a race car. I know I'm not going to win any races against a BMW.
But I can park on top of him and prevent him from going anywhere...
Need more Horse Power Rschuck 2nd Gen. Tacomas 10 02-02-2013 08:34 AM
horse power boost yumacpl Towing 8 07-30-2011 09:19 AM
Horse Power dalesrn 2nd Gen. Tacomas 8 06-16-2009 03:52 PM
how much horse power stock? devilsalmostfree 1st Gen. Tacomas 33 02-26-2009 04:56 AM
needing more horse power! devilsalmostfree 1st Gen. Tacomas 6 09-21-2008 05:40 PM
