**SOMEONE PLEASE HELP**
Discussion in 'General Automotive' started by Detective_Dan, Apr 9, 2013.
  1. Apr 9, 2013 at 8:14 PM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Jason
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    im putting my stock supercharger pulley back on and this GD allen bolt somehow went from finger tight to superman on roids tight. the allen part is stripped out, not the threads.
    it wouldnt be that difficult to remove other than the fact that i cant get the supercharger snout to stop spinning as im trying to loosen it. ive tried a strap wrench and cannon plug pliers on the snout. i obviously cant throw a pair of vice grips on the snout as that would damage it. i have to get this damn thing out. please somebody throw me an idea that i havnt tried
  2. Apr 9, 2013 at 8:20 PM
    Osugoose
    Osugoose Well-Known Member
    Sean
    Tulsa, OK
    2011 Sport DCLB 4x4
    885x w/ nitro sports,Dakars w/ 182,Katskinz two tone leather
    Hmm....
    Is it tight at the head or at the base? If it's tight at the head you can use a hack saw at the base of the head without getting into the shaft to relieve some of the pressure. Dont go all the through the head, just to level with the thread.
    If you had a strip of leather or rubber you might try to wrap the shaft and then clamp to it. Just some non conventional thoughts.
  3. Apr 9, 2013 at 8:27 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" TuRD PRO replica wheels
    I would first try tapping the bolt to see if it might magically go back to finger tight.
    If not, you might try wrapping an old bicycle tube tight around the shaft a few times then clamping the vise grip on that. It might move a little but the rubber should push against it and add extra pressure.
    I have no idea if that would work, it's just what comes to mind when looking at that.
  4. Apr 9, 2013 at 8:29 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    I hate when this kind of shit happens. Good luck.
  5. Apr 9, 2013 at 8:42 PM
    Detective_Dan
    Jason
    Colorado Springs
  6. Apr 9, 2013 at 8:45 PM
    tn2012taco
    tn2012taco Well-Known Member
    Nathan
    Nashville, TN
    '12 PreRunnin Trooper
    Plasti-dipped wheels, Bilstein 5100's @ 1.75, 1 in. block in rear, CB in center console, 12V outlet in console, weathertechs, N-FAB wheel-to-wheel 3in. tube, Action packer cheap toolbox, Spidertraxx 1.25" spacers, Kensun 5000K in fogs, K&N drop-in filter, foglight anytime mod, Anytime Panty-dropper mod.
    How'd you do it?
  7. Apr 9, 2013 at 8:50 PM
    Bennett707
    Oregon
    by the looks of the threads in that pic, he used some grips.
  8. Apr 9, 2013 at 8:51 PM
    Detective_Dan
    Jason
    Colorado Springs
    Leather belt around the snout with vice grips on the snout and Allen head. Destroyed my buddies thumb on the battery when it let loose lmao
  9. Apr 9, 2013 at 8:55 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Weeee!
    That sinking feeling you get when you strip a really important bolt...
  10. Apr 9, 2013 at 9:02 PM
    Osugoose
    Sean
    Tulsa, OK
    2011 Sport DCLB 4x4
    Glad to hear you got it loose. Sorry about your buddy's hand.
