-   General Automotive (http://www.tacomaworld.com/forum/general-automotive/)
-   -   Body shop fender problem (http://www.tacomaworld.com/forum/general-automotive/275511-body-shop-fender-problem.html)
Fiolo 04-29-2013 01:19 PM
So I took my truck to get a fender replaced an painted at a local body shop and I have a 98 4wd, well when I went to the shop I told them I wanted oem parts and went ahead and got it fixed but when I go to pick it up turns out they put a 2wd fender on which has no flare and now they're trying to say how Toyota could have changed the body line and that they ordered right and getting angry at me for saying they have to change it for the right one , I know clearly its the wrong fender though
KenLyns 04-29-2013 01:29 PM
The fender flare is a separate part. Did the body shop give you a receipt? What's the PN listed? Cross-reference it against RockAuto and see if they gave you the correct fender.
4WD P/Ns: 5381204070 LH, 5381104070 RH. If the last 4 digits are 4061 instead of 4070, then they gave you the 2WD fender.
Flare P/Ns: 7587235900 LH, 7587135900 RH
Note Toyota sells the flare for as much as as the fender (~$200). So if you can't re-use the flare from your old fender, then be prepared to pay.
http://www.villagetoyotaparts.com/im...ze/530608A.jpg
Fiolo 04-29-2013 02:35 PM
Yeah and what I mean about flare is that the 2wd is a flat fender and the 4wd has a little bit of a bulge to it , let me see if I can find an example
Fiolo 04-29-2013 02:51 PM
this is the one that they should have put http://i.ebayimg.com/00/s/NDAwWDYwMA..._id=880000500F
but they put this one
http://www.theautochannel.com/autopa..._new/6098j.qkt
you can tell at first sight that one isn't the same as the other especially looking at it from the front because the 4wd one is fatter basically
PcBuilder14 04-29-2013 02:53 PM
Yup, 2wd fenders are completely different for 4wd fenders. More than just the fender flare.
Just ask Blackdawg, he replaced the whole body of his truck and he had to buy fiberglass fenders to replace the 2wd fenders that came with his junker body that he used.
KenLyns 04-29-2013 02:56 PM
Interesting. Anyway, ask the body shop to show you the paperwork indicating which P/N got ordered. It's possible they ordered the wrong part. It's also possible they ordered the right part, but the got the wrong one delivered.
Fiolo 04-29-2013 02:57 PM
Yeah I saw blackdawgs too and it's the exact same problem , body shop told me to come over again Wednesday and I'm definitely going to bring some proof because I'm not keeping it like this when I paid to get it done correct
PcBuilder14 04-29-2013 03:00 PM
Yeah, could have just been an oversight. But definitely don't let them get away with saying it's the correct part.
Fiolo 04-29-2013 03:02 PM
Yeah probably the only problem is they keep saying it was right and you can even tell its wrong because the bumper is sticking out and the mud guards don't fit correct but I'm gonna take it again Wednesday and hopefully get it fixed the way it should be
