AR15 Rear sight question
Discussion in 'Guns & Hunting' started by bigburrito, Apr 18, 2011.
  1. Apr 18, 2011 at 10:27 PM
    bigburrito
    bigburrito [OP] Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    Just got a new rear sight and noticed that the large aperture is machined significantly off-center to the right. Basically Im wondering if this is a defect, or normal.
    After researching, internet rumors say its to account for the horizontal shift when switching from small to large aperture.
    Whats the verdict? I know there are some AR savvy folks around here
  2. Apr 19, 2011 at 10:52 AM
    bigburrito
    DuPage County
    '09 TRD OR
    Well I have a call in with Primary Arms (retailer), they have a call in with Daniel Defense (mfg). Primary Arms indicated all the other rear sights they had in stock had the same offset, so they called DD to get more details.
    Either this is part of a rogue batch of bad sights, or an quite the oddly engineered piece.
    Ill update when I get an answer.
  3. Apr 19, 2011 at 10:58 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    im pretty sure you can turn the screw on the side to move the sight left and right........
  4. Apr 19, 2011 at 11:07 AM
    bigburrito
    DuPage County
    '09 TRD OR
    I talked to from Geoff at Primary Arms who heard back from Daniel Defense. The large aperture is off center on the post because the pivot rides on the threaded windage adjustment. Basically when you switch between large/small apertures, there is a slight change in windage due to the pivot on the thread. The offset on the large aperture is to compensate for this. All is well!
    Thanks to Geoff at Primary Arms who had my question answered in no time at all. Highly recommended retailer.
  5. Apr 19, 2011 at 11:07 AM
    bigburrito
    DuPage County
    '09 TRD OR
    Were talking about the offset of the hole in the post, not the offset of the post in the sight.
  6. Apr 19, 2011 at 11:09 AM
    TexasIslandBoy
    Andrew
    South Texas. SPI
    ahh i just saw that it was alittle to the right didnt notice that it was offset on post
  7. Apr 21, 2011 at 6:25 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Glad you talked to them and got confirmation that it's part of the design.
    That's weird though. I just had to go look at my A.R.M.S Inc. rear sight on my Stag 2T and both the large and small aperture are dead middle.
  8. Apr 21, 2011 at 8:00 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    thats good info, thanks for sharing.
