Go Back   Tacoma World Forums > Vendors > ICON Vehicle Dynamics
Icon 2.0 RR rear shocks
Old 05-20-2014, 08:28 AM   #2
Direct Representative
ICONRep is one of the sharper tools in the shedICONRep is one of the sharper tools in the shedICONRep is one of the sharper tools in the shedICONRep is one of the sharper tools in the shedICONRep is one of the sharper tools in the shedICONRep is one of the sharper tools in the shedICONRep is one of the sharper tools in the shedICONRep is one of the sharper tools in the shedICONRep is one of the sharper tools in the shedICONRep is one of the sharper tools in the shedICONRep is one of the sharper tools in the shed
ICONRep's Avatar
ICONRep's Tacoma Gallery
Originally Posted by Dark Knight View Post
For the rear remote reservoir brackets, drill a hole in the frame to mount?
Seems the only way besides the shock body reservoir clamps.
2.0 or 2.5 basically have the same instruction. Key to make sure there is a little bit of slack so under articulation the hose and fitting are not pulled on at all. The bracket can be mounted with the bolt on top or bottom, it really does not matter. I prefer the bottom so it does not show as much when looking in the fender well.
1. Fasten the reservoir mounting bracket to the center of the reservoir with the provided hose clamps. The hose clamps must be mounted outside the edge of the reservoir sticker to avoid crushing the reservoir and causing internal damage.
2. Hold the reservoir and mounting bracket against the frame, keep some slack in the hose, and mark the location of the hole on the frame.
3. Move the reservoir and mount away from the frame and drill an 11/32” hole in the spot that you just marked.
4. Deburr the hole, place the reservoir and mount back against the frame, and install the split washer and self-tapping bolt.
FS: Icon 2.0 RR rear shocks, defined shackle hanger brace xweslingx 2nd Gen Tacoma Marketplace 8 04-10-2014 01:12 PM
FS: Icon RR rear shocks (SOLD) KeithB 2nd Gen Tacoma Marketplace 10 03-04-2014 07:40 AM
FS: Icon 2.0 RR Rear shocks for Expos/Dakar/2.5" lift SconnieHailer 2nd Gen Tacoma Marketplace 12 11-20-2013 04:31 PM
FOR SALE: Icon Coil-Overs, Icon RR Rear Shocks, Camburg 1.25 UCA's & Bilstien 5100's RJALLDAY702 2nd Gen Tacoma Marketplace 77 08-21-2012 03:16 PM
Icon RR Rear Shocks BFA Suspension 12 05-28-2011 03:50 PM
