HID 6000K / 3000K fogs
Discussion in 'Lighting' started by 05tacoSPORT, Aug 21, 2010.
  1. Aug 21, 2010 at 9:17 PM
    05tacoSPORT
    05tacoSPORT [OP] Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    My halo light fog up to the point i got so pissed i took them out and put the factory lights back in. Then i went inside and ordered 6000k Bi-Xenon and 3000k fogs. Now reading about the lights looks like i will blind the piss out of everyone. WTF The bulbs i got are for the factory lights. Do i or Can i use the projector from my POS fishbowl lights and install them in the oem lights? Or will i be ok with running the 6000k in the oem lights. will the bulbs i ordered even fit in the H1 projector. I think i got ahead of myself and got the wrong bulbs.... What is the best way to handle this? Do i work on the halos and reseal them or retro fit projectors in oem light and a BHLM or just put the F in HIDs in and drive.:mad:[​IMG][​IMG]http://www.hidxenonheadlights.com/
  2. Aug 21, 2010 at 9:40 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    one more thing. I did the hi/low beams on at the same time mod. do i need to undo this mod.
  3. Aug 22, 2010 at 6:56 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Depends on your wallet and time.
  4. Aug 22, 2010 at 7:22 AM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    options? Do i need to buy a h4 projector?
  5. Aug 22, 2010 at 10:52 AM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    They do not make an H4 projector. Popular sizes are D2S, D2R, D1S, and H1 (CHEAP). I might be missing a few others.
  6. Aug 22, 2010 at 5:26 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    so I am stuck with the H4 or can i find the projector i want and buy just the bulb / not the entire kit. what would be the best retro kit to get. The halo lights i have use the H1 that are "cheap" so i should stay away?
  7. Aug 30, 2010 at 2:34 AM
    hitaco
    hitaco Active Member
    wahiawa
    07 tacoma
    Dual exhaust flowmasters 40 series, H.I.D. projection kit 6000 black out tint, black wheel mod, dome and map light L.E.D. cool white ^_^
    hey i bought these headlights also n mines fog up really bad :( did you find a way to get rid of the small puff above the cutoff line? and so long as you ordered the H1 bulb, everything will be fine :D
  8. Aug 30, 2010 at 3:57 AM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    Is the bi-xenon kit you bought the H4 lo/hi combo? If it is then I'd say you need to use oem housings since your other lights have seperate lo and hi beam bulbs. And if so, I'd also say undo the lo/hi always on mod too. IDK about taking the aftermarket ones apart and playin around with that. Just re-aim the lights down a bit after installing. Unless you got 55w kit then you should be OK on not blinding people. My gen 2 aftermarket lights are seperate but there is H7 in the lo beam projector and 9005 or 9007 for the bright. I did HID fogs and left the headlights alone.
  9. Aug 30, 2010 at 4:16 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Why not just re seal the projectors?
  10. Aug 30, 2010 at 4:20 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Sounds like if he does that then the HID kit for headlights aren't gonna fit.
  11. Aug 31, 2010 at 3:21 AM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    I picked up the H4 moving hi/lo. And disc. the hi&lo mod. I also moved my lights down alot. I guess i will move them up a little and see if thy piss anyone off. For the old lights i just wanna sell them.
  12. Aug 31, 2010 at 3:38 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Not sure which ones are the "old" ones anymore, lol. Assuming you are using the HID kit in the oems and talking about selling the black'd out gen3 ccfl's?
  13. Sep 2, 2010 at 6:46 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    yup i wanna sell the gen3's Now i have another problem? I installed the new lights and all worked great until today my fog lights dont work. WTF. Could it be the main fuse? Any help on what to look for or were to start. Fuse first then trace the power to the bulbs? Can i use a volt meter and see if i have power at the ballast/bulbs. A few tips please.
  14. Sep 2, 2010 at 6:51 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    I'd start with the ballast ground, then try the fuse and the connections, then the power.
