new bulb or lense
Old 11-01-2010, 06:50 PM   #1
dustinclm [OP] dustinclm is offline
dustinclm is one of the sharper tools in the sheddustinclm is one of the sharper tools in the sheddustinclm is one of the sharper tools in the sheddustinclm is one of the sharper tools in the sheddustinclm is one of the sharper tools in the sheddustinclm is one of the sharper tools in the sheddustinclm is one of the sharper tools in the sheddustinclm is one of the sharper tools in the sheddustinclm is one of the sharper tools in the sheddustinclm is one of the sharper tools in the sheddustinclm is one of the sharper tools in the shed
dustinclm's Avatar
dustinclm's Tacoma Gallery
new headlights or lense cleaning??
Noticed tonight that when my lights are on while driving at night they are hardly noticable. the lenses have some haze but not much, i can still see the light bulb but its not perfectly clear. i have never changed the headlights and its a 2001 so should i change the bulbs or try and clean the lenses?
Old 11-01-2010, 07:11 PM   #2
dustinclm's Avatar
i used the turtle wax less than a year ago, the lights have gotten more and more dim and now its time to do something because i can hardly tell when i have them on
wouldnt they dim over time? the truck has daytime lights so they are constantly on and like i said, i think they are just dimming from being old because they are no brighter than the light that is emitted from the truck just being on. ALSO does anyone know how to make the lights not be on constantly?
Old 11-01-2010, 07:25 PM   #3
Leadgolem is one of the sharper tools in the shedLeadgolem is one of the sharper tools in the shedLeadgolem is one of the sharper tools in the shedLeadgolem is one of the sharper tools in the shedLeadgolem is one of the sharper tools in the shedLeadgolem is one of the sharper tools in the shedLeadgolem is one of the sharper tools in the shedLeadgolem is one of the sharper tools in the shedLeadgolem is one of the sharper tools in the shedLeadgolem is one of the sharper tools in the shedLeadgolem is one of the sharper tools in the shed
Leadgolem's Avatar
Leadgolem's Tacoma Gallery
First I'd replace the bulb with piaa's intense white h4. http://www.piaa.com/Bulbs/Bulbs-H4.html
Then I'd polish the lenses. They have got to have some breakdown of the plastic by now. http://www.allpar.com/fix/headlights.html
Since you have dtrl, I'd probably do something like this too.
http://www.ttora.com/wiki/index.php/...Running_Lights
Old 11-01-2010, 07:36 PM   #4
dustinclm's Avatar
yeah there is some breakdown but nothing to where it would be blocking my lights. i guess ill be replacing them this week.
Old 11-01-2010, 07:56 PM   #5
yosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shedyosh2000 is one of the sharper tools in the shed
yosh2000's Avatar
yosh2000's Tacoma Gallery
i, and many others, would recommend you change the bulbs out w/ philips x-treme vision bulbs. all those colored bulbs will actually give less output (lumens). then, get a 3m multistep headlight cleaner from walmart. the 3m kit is superior to other headlight kits in that it comes w/ not only a drill attachment, but also multi grades of sandpaper adn a polishing compound to finish off the lights. it does an amazing job, i got rid of rock pits in my fogs w/ the kit in less than an hour!!
Old 11-01-2010, 08:41 PM   #6
Leadgolem's Avatar
Hey, those bulbs are pretty sweet. I think I'll get me a pair.
Old 11-27-2010, 04:49 AM   #7
Mod Mod is offline
Mod is one of the sharper tools in the shedMod is one of the sharper tools in the shedMod is one of the sharper tools in the shedMod is one of the sharper tools in the shedMod is one of the sharper tools in the shedMod is one of the sharper tools in the shedMod is one of the sharper tools in the shedMod is one of the sharper tools in the shedMod is one of the sharper tools in the shedMod is one of the sharper tools in the shedMod is one of the sharper tools in the shed
Mod's Tacoma Gallery
Headlight Cleaning: WARNING!!
Original headlights were a bit yellow after years, so I decided to get the 3M kit and polish them up a bit. A word to the wise. DO NOT,,I REPEAT,,DO NOT use a air powered die grinder with the cleaning kit. Use a elec drill.
A air powered tool it waay to high speed for the sandpaper disks,,creates to much instant heat and smears the plastic dust that gets filed off right back onto the plastic. A new way to plastic weld,,if you will. the brown goober in the corner is what is left after a couple hrs of sanding, wiping, blowing off the disk, repeat, repeat, repeat. On my way this morning to the paint store to get some more disks because I still have some whirls and swirls left on the lense,,,Blahhh. It is probably so thin now that any pebbel will blast right thru it.
Old 11-27-2010, 01:02 PM   #8
Leadgolem's Avatar
Hmm, good to know. When your done polishing make sure to hit the lenses with a uv protective clear coat. Otherwise they will yellow again, and much faster without the factory uv coating.
Old 11-27-2010, 07:01 PM   #9
Mod Mod is offline
I put some stuff called Wolfgang sealant back on,,supposedly good stuff.
The body shop man told me that the UV coating is what turns yellow,,so now thats off of there. he said that just a regular car wax would work fine also for a coating.
They did turn out just fine, and much brighter.
Old 11-28-2010, 08:01 PM   #10
Leadgolem's Avatar
Plastic's photo decay. The plastic reacts with the UV light and breaks down. So a UV protective coating is SOP for any clear plastic being used outside. Being clear the uv rays penetrate much farther into the material and cause a much higher level of damage. Not really an issue with opaque plastics, as only the outer layer of the material is ever affected.
Plastics can last for thousands of years in a landfill because they aren't exposed to the light. UV light is one of the few things that will actually break down plastics at all.
DRL melting lense 808trdsport 2nd Gen. Tacomas 17 06-06-2013 11:11 PM
Cigarette light bulb and ashtrey bulb size mwoods 1st Gen. Tacomas 7 11-29-2012 03:15 PM
KC daylighter lense? Shooter25 Off-Roading & Trails 2 10-02-2011 01:15 PM
Gauge cluster Lense Melonfarmer 1st Gen. Tacomas 2 03-20-2010 10:10 PM
Fog Lense and OIl Tacoma2009 2nd Gen. Tacomas 2 11-01-2009 12:56 PM
