Head light problems...
Old 10-13-2008, 10:52 PM   #1
bhtyler10 [OP] bhtyler10 is offline
bhtyler10 is on a distinguished road
bhtyler10's Avatar
bhtyler10's Tacoma Gallery
I got another 3 in suspension lift added to my body lift a while back and put 35's on my truck. I noticed that my head lights on dim, barely shine on the road. Is there a way to redirect them a little lower, or should I get new HID's or something. Just a question?
thanks, tyler
Old 10-13-2008, 11:01 PM   #2
Founder Socaltacomas.com
SocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shed
SocalMan22's Avatar
SocalMan22's Tacoma Gallery
Just noticed you had a first gen thanks humanoid.
Old 10-13-2008, 11:05 PM   #3
bite me
humanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shed
humanoid's Avatar
humanoid's Tacoma Gallery
He's got a 1st gen and I believe that diagram shows it for the 2nd gen., but the process is the same, only instead of a screwdriver you use a socket, but I can't recall the size of the socket though.
Old 10-13-2008, 11:57 PM   #4
bhtyler10's Avatar
wha diagram are you talking about?
Old 10-14-2008, 12:00 AM   #5
bite me
humanoid's Avatar
socalman22 edited his post after I replied. It was a diagram showing how to adjust headlights for a 2005+ Taco.
Old 10-14-2008, 12:01 AM   #6
SocalMan22's Avatar
its back up
Old 10-14-2008, 12:02 AM   #7
Justin626 has much to be proud ofJustin626 has much to be proud ofJustin626 has much to be proud ofJustin626 has much to be proud ofJustin626 has much to be proud ofJustin626 has much to be proud ofJustin626 has much to be proud ofJustin626 has much to be proud of
Justin626's Avatar
Justin626's Tacoma Gallery
Not familiar with 1st gens specifically but headlight assemblies have an adjustment screw/bolt that will change the pitch. Should be able to locate it on the backside of the assembly, probably towards the top and easily acessible.
Old 10-14-2008, 07:21 PM   #8
bajaracer is on a distinguished road
bajaracer's Tacoma Gallery
any diagram as to how to do it on a 1st gen?
Old 10-15-2008, 02:04 AM   #9
Sprayin' Paint like Its my Job
Choco Taco is on a distinguished road
Choco Taco's Avatar
Choco Taco's Tacoma Gallery
shouldn't need a diagram, just pop the hood, and look behind the headlight for either a Torx head screw or hex-head, (dunno what it is on older 1st gens )Park your truck in front of a garage door or wall or something, about ten feet back and turn the adjuster on each light until they both move down to about where you think they should be
Old 10-15-2008, 12:12 PM   #10
ubermx5 is on a distinguished road
ubermx5's Tacoma Gallery
Send a message via AIM to ubermx5
Then test drive..
See what it looks like.
Than ask a friend to drive 3 seconds in front of you on the freeway.
If he is blinded by your light adjust it. If he is not then you are good to go.
Also look at these web site
http://www.automedia.com/Aiming_Head...cr20010801ha/1
This is a PDF http://www.coolbulbs.com/HID-VISUAL-...-PROCEDURE.pdf
http://www.procarcare.com/icarumba/r...ia_lights1.asp
I think this should clear thing sup on how to adjust your lights to be safe and usefull
Old 01-25-2011, 09:44 AM   #11
greddy09sc is on a distinguished road
greddy09sc's Tacoma Gallery
1st gen headlight bulb question
My uncle has a 1st generation Tacoma and his headlights is very dim. I did a search on slimcubby hid's and it will not fit first generation. Correct?
If that's the case then my only other option is to buy a replacement bulb. Anybody recommend a good bright bulb for the 1st gen headlights ?
Thanks.
Old 01-25-2011, 10:23 AM   #12
bite me
humanoid's Avatar
1st gens are separated into 2 categories: 95.5-97 and 98-04. PnP HIDs will not fit 95.5-97 but will fit 98-04. 95.5-97 have the sealed halogen lamps while the 98-04 uses halogen bulbs. What year does your uncle have?
Old 01-25-2011, 02:24 PM   #13
Thanks for your response. My uncle truck is 2000. Guess I should have put the info in the original post
Really? I didn't know that. So do you know where i can get the HID's?
DIY Head Light and Tail Light Videos 4wardvideo 1st Gen. Tacomas 0 11-28-2011 01:19 PM
FS: OEM BHLM Head light and Rear tail light smoked KaliTaco Buy / Sell / Trade 15 01-25-2011 10:23 AM
tail light problems mwoods 1st Gen. Tacomas 3 01-16-2011 12:59 PM
Brake light problems 1zach4 2nd Gen. Tacomas 1 12-17-2010 08:38 AM
Head light went out.. T-rev Lighting 8 06-06-2009 07:57 AM
