Fog Light Retrofit
Discussion in 'Lighting' started by Pugga, Nov 14, 2011.
  1. Dec 17, 2011 at 8:10 PM
    #81
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Very nice! I've got the same issue, the cut off sort of curls up at the sides. I agree with you about the Blazer, they're a good product for the money!
  2. Dec 19, 2011 at 5:01 AM
    #82
    Pugga
    Massachusetts
    How do you guys get night shots? My camera sucks and I can't get a decent shot to show the light output. Should I just tape over the flash and just post the crappy pictures?
  3. Dec 19, 2011 at 1:56 PM
    #83
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
    I just used my phone camera for those shots. The flash was going off that’swhy the light looks less yellowish than they really are. I would turn off ordisable the flash and see if that improves the picture.
  4. Dec 19, 2011 at 3:27 PM
    #84
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    i used my fone. sometimes i change the settings to 'Fireworks' LOL....
  5. Dec 21, 2011 at 7:30 PM
    #85
    shweller
    Corona
    Okay I got the 5000K bulbs in with the wire down. I am happy with the results. I prefer it over the 3000K. The only thing I dont like is that the cut off line is not as sharp as with the 3000k, not sure why...:confused:
  6. Dec 22, 2011 at 5:04 AM
    #86
    Pugga
    Massachusetts
    Interesting... I'm trying to talk my dad into letting me install a set of these on his truck and I'd use the 4300K or 5000K. That's weird that the cutoff was affected by the bulb color.
  7. Dec 22, 2011 at 5:06 AM
    #87
    Texio
    Texio Well-Known Member
    Austin, TX
    11 4WD DBCab SB
    Thank you for the proper use of "affected" vs "effected"... Nowadays it always brings a tear to my eyes when someone actually uses it correctly! :D
  8. Dec 22, 2011 at 7:56 AM
    #88
    Pugga
    Massachusetts
    I aim to please :thumbsup:
  9. Dec 22, 2011 at 8:10 AM
    #89
    AsianAnts
    AnT
    your edjukated
  10. Dec 22, 2011 at 9:55 AM
    #90
    shweller
    Corona
    If you look at the right side of the beam it gets blurred against the wall.Not sure if the reflector bowl in the fog light has anything to do with it. Overall, I am impressed with the blazers. Definitely good bang for your buck! I am going to try to find a better wall to mess around with to make some more adjustments…
  11. Dec 22, 2011 at 10:04 AM
    #91
    Pugga
    Massachusetts
    I don't think it's the reflector bowl because my cutoff blurs at the sides also (and I don't have any reflector bowl left to reflect light). I think it's just the relatively cheaper projector. The higher end projectors would (should) have a cleaner cut off, wider beam and no blurring at the cutoff.
  12. Dec 22, 2011 at 10:21 AM
    #92
    shweller
    Corona
    I agree, I am going to chalk it up as they aren’t perfectand let it go… I am having secondthoughts about not using the relay harness. I was having some issues withflickering on start up. I did the anytime fog mod, so not where that circuitgets its power from. I am going to do an auxiliary power block to tap into forpower on all my ballasts. Anyone have any tips on doing this. I eventually wantto get a winch so might as well start preparing. God I hate mods they take allof my money...
  13. Dec 22, 2011 at 10:37 AM
    #93
    Pugga
    Massachusetts
    I get one bright flicker, then about a fraction of a second later they brighten up, is that what you're getting? It's not enough for me to want to rewire them, I think the stock wiring is sufficient. When you do the fog light anytime mod, you're pulling power from a different place to trip the relay, the fog lights themselves get power from the same place they always have. I don't see a difference between pulling power from the fuse panel power bus or directly from the battery because the battery charges the fuse panel anyways.
    For a secondary fuse block, Blue Sea makes a nice fuse block. Make sure your alternator/battery can handle the extra load.
  14. Dec 22, 2011 at 10:55 AM
    #94
    shweller
    Corona
    It would flicker for about 3-5 seconds. What you say is correct about thepower supply and I agree. I just want to melt any wires that’s all... They allseem like 18-20 gauge wiring. I have the towing package from the factory sofrom what I understand it has a heavier duty alternator and battery. Any writeup on how to power the block up?
  15. Dec 22, 2011 at 5:49 PM
    #95
    Pugga
    Massachusetts
    I hear ya. They should pull less power than stock once they're up and running. There's a large initial draw (not sure how much of a spike there really is) but after that they settle down to 35 watts. Larger wire couldn't hurt though!
    As far as wiring up another power block, I'd pull straight from the battery. I'd try to find another battery attachment that would take the stock wire and another large gauge wire. Make sure you have a good ground for your power block also. No write up though, and I haven't done it myself. That's just how I'd go about it.
  16. Dec 23, 2011 at 6:22 AM
    #96
    shweller
    Corona
    Any updates on your retro? I will probably ground back to the battery off of the fuse block. I found this write up that help give an idea of what to do, so I will probably go this route. Just have to make sure that the fuse panel I get has a negative bus on it just in case so I can ground to as well as get power.
  17. Dec 23, 2011 at 10:54 AM
    #97
    Pugga
    Massachusetts
    Yeah, my retro is up and running, I just need to upload night shots! I'll get some pics of them installed on the truck. I just got the heat sinks a few days ago and need to put them on also. Been busy with the holidays and long work hours. I haven't done the fog light anytime mod yet either, that'll happen next week.
    Updated second post with more pics. Will update 3rd post with light output pics later tonight when it gets dark.
  18. Dec 23, 2011 at 3:51 PM
    #98
    Pugga
    Massachusetts
    Updated with light output shots :yay:
  19. Dec 23, 2011 at 4:12 PM
    #99
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
  20. Dec 23, 2011 at 4:14 PM
    #100
    Pugga
    Massachusetts
    They are. They still come on green but seem to go to yellow quicker and quicker the more I run them. Now it only takes about 1 minute before they're yellow. Originally it took a lot longer. They look sooo good, I keep finding myself staring at that cutoff when I'm driving :eek:
