2012 retrofit!
Discussion in 'Lighting' started by knine00, Jan 6, 2012.
  1. Jan 6, 2012 at 2:10 PM
    knine00
    knine00 [OP] Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    I just received my new mini D2S retrofit kit for my 2012 tacoma. I was told that you need to modify the adaptor because it doesnt allow the projector to be level. I was wondering if someone has taking on this task with there 2012 can give me some guidance. Here are some pics and as you can tell the first pic in the middle of the light you can see the top of the projector line is not level. Is this what I need to correct? Also is the shroud suppose to sit flush with the reflector or is there suppose to be a gap like in pics two? Thanks everyone
  2. Jan 6, 2012 at 5:14 PM
    Commanderwiggin
    Commanderwiggin Well-Known Member
    Calgary
    12 Tacoma D/C 4x4 TRD Sport 6MT Supercharged
    There is a gap with mine...looks off but if you don't want it you need to do an FXR style install.
    The notch or step is supposed to be there...however the rotation is off...several ways to do this...easiest is to shave the little notch in the alignment washer and rotate it to the correct spot (test fit your headlight)...then make sure it doesn't move...glue it and then it won't go anywhere...easiest way.
  3. Jan 7, 2012 at 8:01 AM
    knine00
    Hudsonville, Mi
    Stock for now
    Where did you glue it so it wont rotate?
  4. Jan 7, 2012 at 9:33 AM
    Commanderwiggin
    Calgary
    I used epoxy all around the adapter plate and first nut...don't forget to feed the wires through before you glue it like I almost did lol.
  5. Jan 8, 2012 at 7:30 AM
    knine00
    Hudsonville, Mi
    Stock for now
    Need some help! Which one all black and chrome reflector/shroud?
  6. Feb 9, 2012 at 11:57 PM
    boostfed
    boostfed Well-Known Member
    STOCK!
    i'm in the same predicament!!!! i was thinking of just painting the shroud... both look good though, haha! the black looks mean!
  7. Feb 13, 2012 at 12:28 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    hmm, that is tough, I have the same truck soooo post more pics!
  8. Feb 13, 2012 at 12:28 AM
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    I like the chrome with black surround
  9. Feb 16, 2012 at 3:43 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    why does everyone get the d2s and not the H1's?
  10. Feb 17, 2012 at 3:49 AM
    knine00
    Hudsonville, Mi
    Stock for now
    Ds2 are more of a plug n play. DS2 don't require any cutting of the head light reflector and is much easier to align. The H1's require percise cutting and take a lot of time to align!
  11. Feb 17, 2012 at 6:54 PM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    I've always read that both the D2S and H1 are plug and play and require no cutting.
  12. Feb 22, 2012 at 9:00 AM
    stattonmw
    stattonmw Well-Known Member
    Statton
    Redmond, WA
    2014 DCLB Tacoma TRDsport
    5" RCD Lift TOYO ATII Extreame 295/70R18 XD Addict wheels Factory toyota side steps TRD exhaust
    Im sorry... but this isnt the case at all. The mini d2s and mini h1 are almost identical with the exception that they use different bulbs in the projector.
    The mini d2s was designed after the mini h1 to be able to accomidate a d2s bulb so that you could use higher end bulbs (such as philips) with this being said the light output and cut of on the h1 is way better since the projector was originally designed for it.
    Now, if you look at the fx-r that requires a lot more work and "precise cutting" Just wanted to clearify.
  13. Feb 22, 2012 at 9:05 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    x2
    Way cleaner, more depth. All black looks worse IMO. (Never thought I'd say that)
