A bulb to match Philips xtreme color?
Discussion in 'Lighting' started by TexasTacoma37, Mar 21, 2012.
  1. Mar 21, 2012 at 7:00 AM
    TexasTacoma37
    TexasTacoma37 [OP] Well-Known Member
    Hi folks,
    I just ordered some Philip xtreme vision headlight bulbs, due to all the good reviews I've heard on here. It looks like they are going to be somewhere between stock yellowish white and, say a 6000k hid, as far as color goes (as seen in the pic, they have a small portion of the bulb that is tinted, but the rest is white).
    Philips does not make the xtreme vision in h10, for our fog lights. I was wondering if anyone found a bulb that had a similar color to pair with the xtreme vision? My searches on other philips threads showed that many run yellow fogs, but I'm wanting a light color that matches the philips. Any input would be appriciated.
    Thanks.
    Here's a comparison of the philips (drivers side) and the silverstars (passenger side) and you can see the light is not the same color, so those are out.
  2. Mar 21, 2012 at 7:55 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yikes... I got your PM, unfortunately I've always gone yellow with the fogs and never attempted to match the color. Unfortunately, I think you might have a hard time getting them to match exactly. I think you're going to end up with slightly different shades of white. The PIAA Xtreme white bulbs I have now are pretty close to the Philips bulbs, maybe a little whiter and they have a blue hue in the lamp itself (none of the light is blue).
    Here are the PIAA's (The Xtreme White is available in H10 size):
    These are the bulbs:
    http://piaa.com/automotive-bulbs/xtreme_white_plus.html
  3. Mar 21, 2012 at 8:08 AM
    TexasTacoma37
    Thanks Mike I will keep those in mind. I have some cheap "ultra white" bulbs that I had from a while ago that I'm going to try first but I'm betting they will be too blueish.
  4. Mar 21, 2012 at 10:29 AM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    I experienced pretty much the same difference from SS ultras to the phillips extremes using the H7s in my halogen projectors. I'm sure everyone knows that 350-500.00 retro projector HID are more effective and "safe" setups over any 100-200.00 halogen or HID in halogen housing setups so please, let's not crank up that discussion, lol. The Phillips had whiter more useful light on the road than the ss ultras IMO. I am unaware of any H10 halogens for the fogs that would match the PE's. My fogs don't match my projectors but they match my parking lights.
  5. Mar 21, 2012 at 10:47 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Narva Rangepower 50's might do the trick for ya...+ they have several wattage's available.
  6. Mar 21, 2012 at 10:58 AM
    TexasTacoma37
    Thanks for your input.
    Looks like they don't come in h10 either :(
  7. Mar 21, 2012 at 11:00 AM
    XXXX
    sKiP
    05 Prius
    whoops....I have PIA fogs I put them in - sorry.
    forgot my fogs were aftermarket POS overpriced junk (not kidding) :D
  8. Mar 21, 2012 at 11:29 AM
    Superdavert
    Superdavert Well-Known Member
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    MB Legacy wheels 285/70 17 BFG KO2s ProComp 2" leveling kit, Foglight anytime mod, Sockmonkey TRD Sport bedside decals, Extang Trifecta tonneau cover, Toyota bed extender, Aries black nerf bars, Pop & Lock
    I have 9005 headlight bulbs is mine. Plugs directly in. You could get the same brand in that size. It's a little pain in the a** to get them back in the mount. But it works and you get a little more light output.
  9. Mar 21, 2012 at 12:00 PM
    TexasTacoma37
    So you are using the 9005's in the fogs? No issues with water getting in or the lenses melting or anything? I guess I've never compared them side by side.
    The "9" number for the H10 is 9145 from what I've found online.
    And philips doesn't make the xtreme in a 9005, only a 9006. I haven't found anything that confirms those are interchangeable. :notsure:
  10. Mar 21, 2012 at 12:10 PM
    Pugga
    Massachusetts
  11. Mar 21, 2012 at 12:32 PM
    Superdavert
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    I've only had them in there for a couple months. No water and no melting so far. It actually tightened up like the stock bulbs after I got the "teeth" in where they lock into. The "teeth" are slightly different. I got the idea from a member on this sight. I also did this on my mustang and had no problems.
    By"teeth" I mean the notch looking things on the bulb. There might be a name for them. Idk.
  12. Mar 21, 2012 at 12:34 PM
    TexasTacoma37
    I've found a couple of other threads that indicate a 9005 can be used in the h10 slot, but as noted above the philips don't come in a 9005, only a 9006. A google search has revealed the 9006's do not fit in the h10 housings.
    I found these blubs that at least seem to have the same "partially tinted" glass. They may be worth a shot.
    http://www.amazon.com/Nokya-Magnum-..._8?s=automotive&ie=UTF8&qid=1332358275&sr=1-8
  13. Mar 21, 2012 at 8:24 PM
    TexasTacoma37
  14. Mar 22, 2012 at 6:01 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Seen good things posted about the Nokya bulbs but no actual experience with them. My fogs are hideously unsafe 35w 5000k HIDs & they match my sad ccfl GEN 2 halos & parking lights but not the H7 PE's. :p At least I'm not blinding everyone with my burry ass cutoff in my cheap ass halogen projectors tho :D They suck only slightly less than the oems, only different.
  15. Mar 23, 2012 at 12:07 AM
    KDogg311
    KDogg311 Well-Known Member
    K H I E M ™
    So Cali 626 ³²³ 818
    Gen² Impulse Red Access Cab
    Avid Offroad light bar (Black), Avid Step bar (Black), TRD skid plate (Black), BHLM w/yellow signals, Pioneer Avic-x930bt, OEM fogs w/ yellow H10, Magnaflow muffler, aFe drop in filter, Toyota Neoprene "Tacoma" seat covers, Shorty antenna, Tint, Removed secondary filter, LED interior lights, LED reverse, Bedlinered rear bumper, color match grill, Black emblems, Red rear signals, Bed mat, OEM bike mounts
    yeah i didnt even bother tryin to match ...
    i just went with some yellow nokia yellow bulbs
  16. Mar 23, 2012 at 2:46 AM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    so which are better the phillips or the silverstars?
  17. Mar 23, 2012 at 9:45 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I have had the Phillips Extreme for the past few months and they put off much more light than stock. I also like the color compared to the Silverstars, more of a warm color instead of the white.
  18. Mar 23, 2012 at 10:28 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    +2 on the PE preference over the SS's.........(H7 low beam)
  19. Mar 25, 2012 at 1:40 PM
    TexasTacoma37
    Got the Philips bulbs in and I really like them. Much brighter than stock, without the worry I had before that I was blinding people with my hids.
    As for the color, I noted earlier that I purchased some cheap "super white xenon" halogen bulbs to try out. The color is pretty close to the Philips, close enough to make me happy. The cheap bulbs light output is terrible, but I've never relied on the fogs for much lighting anyway.
    Here is a link to the bulbs that do a decent job of matching the Philips color, they are at the top of the page and are the "5500-6000k super white" ones.
    http://autolumination.com/headlights.htm
  20. Mar 25, 2012 at 6:28 PM
    TexasTacoma37
    Here's a picture of the match. You can see that the fogs are just slightly less yellowy, if that's a word.
