2012 headlight removal help
Old 05-04-2012, 02:52 PM   #1
TNDrew [OP] TNDrew is offline
TNDrew is one of the sharper tools in the shedTNDrew is one of the sharper tools in the shedTNDrew is one of the sharper tools in the shedTNDrew is one of the sharper tools in the shedTNDrew is one of the sharper tools in the shedTNDrew is one of the sharper tools in the shedTNDrew is one of the sharper tools in the shedTNDrew is one of the sharper tools in the shedTNDrew is one of the sharper tools in the shedTNDrew is one of the sharper tools in the shedTNDrew is one of the sharper tools in the shed
TNDrew's Avatar
TNDrew's Tacoma Gallery
Question 2012 headlight removal help
hey guys i am starting the bhlm today. well the removing the headlights part of it.. thanks to kine i got the grill off and 3 three bolts holding the headlight in out, but I can't get the headlight itself to come out. What am i doing wrong... It is loose and ready to come out at every place but the bottom outside corner on both sides. please help!!
Old 05-21-2012, 06:39 PM   #3
knine00 is one of the sharper tools in the shedknine00 is one of the sharper tools in the shedknine00 is one of the sharper tools in the shedknine00 is one of the sharper tools in the shedknine00 is one of the sharper tools in the shedknine00 is one of the sharper tools in the shedknine00 is one of the sharper tools in the shedknine00 is one of the sharper tools in the shedknine00 is one of the sharper tools in the shedknine00 is one of the sharper tools in the shedknine00 is one of the sharper tools in the shed
Air Force: 4th Fighter Wing
knine00's Tacoma Gallery
Did you get it?
Old 10-09-2012, 07:34 PM   #4
DLat27 has a spectacular aura aboutDLat27 has a spectacular aura aboutDLat27 has a spectacular aura about
Law Enforcement:
DLat27's Tacoma Gallery
how did u make out with this?
Old 10-09-2012, 07:39 PM   #5
JayEMS is on a distinguished road
JayEMS's Avatar
JayEMS's Tacoma Gallery
there is one pain-in-the-ass bolt that is way up inside the fender that holds the light in. You can actually reach the bolt with a small ratchet if you lay under the front and reach way up inside.
Old 08-10-2014, 04:24 PM   #7
PhD, DVM, MPH, MS, MMA, Esq, XYZ, 123, blahblah
DrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shed
DrFunker's Avatar
Name: Dr. (I just play one on TV)
DrFunker's Tacoma Gallery
Originally Posted by thereverend View Post
Bringing this because I'm about to punch babies. I've watched all the vids I can find. Got all the bolts out, the headlight is totally loose. Tried the twist and pull but the bottom longish tab keeps hanging on the bumper cover! This is a '14 but everything looks like the vid with the '13. I just don't know what I'm doing wrong! PLEASE HELP
Thanks,
Adam
going back out to try some more
Oh Reverend, the kids...please don't hurt the kids.
Have you seen this thread:
http://www.tacomaworld.com/forum/lig...oval-pics.html
I bookmarked it for later ref.
Hope it helps. Be gentle with the babies.
Old 08-10-2014, 04:28 PM   #8
Red
Large's Tacoma Gallery
The 12+ headlights are a pain in the ass to remove with the stock bumper on. You have to twist, rotate and wiggle until you get it free while still trying not to scratch the lens up. Good luck bud.
Old 08-13-2014, 04:00 AM   #10
hoenah808 will become famous soon enough
hoenah808's Tacoma Gallery
best way ive found was..
lets say driver side light.
pull the headlight towards you to clear the bottom left tab.
tilt the headlight inwards, bottom end inwards
pull towards the left and out to clear the headlight tab where the bottom bolt gets bolted to
then pull outwards while still slightly tilting top end in
once the bottom is out pull the top end out. may need some forcing
the last part gets sketchy, you may scratch your bumper so put a rag on it, your headlight will most likely get scratched on the top part that sits inside the engine bay not the lense at all tho
2012 headlight/grill removal knine00 Lighting 40 12-30-2014 03:56 AM
Headlight Removal, pics Chris(NJ) 2nd Gen. Tacomas 188 05-05-2014 08:12 AM
headlight removal wcm608 2nd Gen. Tacomas 4 05-23-2010 12:47 PM
Headlight Removal Help WolfeTaco 1st Gen. Tacomas 18 10-21-2009 11:13 PM
headlight Removal help deadbolt Technical Chat 4 10-22-2008 11:10 AM
