LED tape in camper shell not working
Old 06-18-2012, 04:25 PM   #1
abunch [OP] abunch is offline
abunch is on a distinguished road
abunch's Avatar
abunch's Tacoma Gallery
I picked up some LED tape to replace the dim little light inside my camper. The led strips hardly light up at all after I installed them. When I test them on other circuits they are super bright.
The voltage on the wires in the camper is reading 11 volts, which I think may be the route of the issue.
I really want to avoid running lines all the way back to the battery but I don't see many options.
Any ideas?
Old 06-18-2012, 10:31 PM   #2
joes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shed
joes06tacoma's Tacoma Gallery
Any ideas?
Where are you pulling power from? If there is a light already installed back there it has to be hooked to something. I ran a 14gauge wire all the way from the interior fuse block and used an add-a-fuse to tap in. The ground point is also critical. Sometimes a truck bed is not well grounded. I have encountered this kind of low voltage issue when the bed is mounted on rubber isolators.
Old 06-18-2012, 11:36 PM   #3
505 Member
white toy taco is one of the sharper tools in the shedwhite toy taco is one of the sharper tools in the shedwhite toy taco is one of the sharper tools in the shedwhite toy taco is one of the sharper tools in the shedwhite toy taco is one of the sharper tools in the shedwhite toy taco is one of the sharper tools in the shedwhite toy taco is one of the sharper tools in the shedwhite toy taco is one of the sharper tools in the shedwhite toy taco is one of the sharper tools in the shedwhite toy taco is one of the sharper tools in the shedwhite toy taco is one of the sharper tools in the shed
white toy taco's Avatar
white toy taco's Tacoma Gallery
the best way is to go back to the the battery. i did what ^that guy^ said. heres some pics of my bedlight mod
Old 06-19-2012, 07:59 AM   #4
abunch's Avatar
I ended up running a new line from the battery. I was trying to splice into the existing the light that was in the camper. It pulls power from the trailer and brake light harness. No idea how it was loosing a volt.
The existing circuit required the headlights to be on in order to have power. In the end it is more helpful to be able to run it without the headlights, so I guess the extra effort was worth it.
No i just need to find a flush mount switch.
Old 06-19-2012, 09:00 AM   #5
505 Member
yea all of my lights/cb radio are wired directly to the battery, that way i can have them on whenever i want them. glad everythings working good now. were are you gonna put the switch?
Will a Thule camper shell rack support the weight of the shell for hoisting purposes? bamma 2nd Gen. Tacomas 17 01-21-2015 05:48 PM
LED Tape Bed Illumination mikedaddy Lighting 9 08-19-2012 09:55 PM
using 3m LED tape light for bed lights? OffRoadSigALph Lighting 6 11-22-2011 12:07 PM
Camper Shell/Bed Liner Combo and Securing Shell Question groink 1st Gen. Tacomas 3 04-21-2011 01:37 PM
Camper Shell A/C? For Snugfit Shell canuck16 2nd Gen. Tacomas 10 05-06-2008 11:18 PM
