2009 fog light mod
Old 01-07-2009, 05:05 AM   #1
cajun1_us [OP] cajun1_us is offline
cajun1_us is on a distinguished road
cajun1_us's Tacoma Gallery
2009 fog light mod
Does anyone know if the fog light mod to turn fog lights on anytime works the same on the 2009.
Old 01-07-2009, 05:25 AM   #2
Mayor of TW
Delmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shed
Delmarva's Avatar
Army: Vet
Delmarva's Tacoma Gallery
It should as i wouldn't see any major changes in that area. The mod is cheap enough to try. If it doesn't work, you've wasted only 5 bucks...
Let us know how it turns out if you do it.
Old 01-07-2009, 05:55 AM   #3
I had it on my 07. So I already have the wire. I'm ordering an 09 this week.
Old 03-05-2009, 05:36 AM   #5
Hornet18 is on a distinguished road
Hornet18's Tacoma Gallery
Just got my '09 PreRunner, checked the foglight relay and found one less pin than on my '07 when I did the mod. Not sure how to do the mod on the '09 now and would appreciate any help.
Old 03-06-2009, 03:43 PM   #6
DNahas is on a distinguished road
DNahas's Avatar
DNahas's Tacoma Gallery
I just did mine on an 09 and found this thread searching for a problem.
I did the Mod. The directions did not explan EXACT what blade on the relay to use, so I assume its the one running parallel with the bumper and closer to the rear of the truck.
Now the problem. I can turn the fogs on and off anytime. Its now seems the dealer option DRL (Daytime running lights) functionality has moved from the inner marker bulbs to the headlights. So what I lost control of is the headlight bulbs now seem to always be on, but more dim than regular low beam.
Old 03-06-2009, 03:52 PM   #7
Lieutenant Dan.
DeeKay21's Avatar
Firefighter: Lieutenant
DeeKay21's Tacoma Gallery
Cool
Hmmmm, that's really weird. I have an 06' and did the Fog mod a few months ago and just installed the factory DTRL relay last week and works perfect. I'm not sure why it changed over to your headlights?
Old 03-06-2009, 06:14 PM   #8
DNahas's Avatar
with the parts being slightly different does anyone have a 2009 electrical FSM?
Old 03-06-2009, 07:23 PM   #9
My other ride has 18,400HP!!!!!!
rmb_crew is one of the sharper tools in the shedrmb_crew is one of the sharper tools in the shedrmb_crew is one of the sharper tools in the shedrmb_crew is one of the sharper tools in the shedrmb_crew is one of the sharper tools in the shedrmb_crew is one of the sharper tools in the shedrmb_crew is one of the sharper tools in the shedrmb_crew is one of the sharper tools in the shedrmb_crew is one of the sharper tools in the shedrmb_crew is one of the sharper tools in the shedrmb_crew is one of the sharper tools in the shed
rmb_crew's Avatar
Navy:
rmb_crew's Tacoma Gallery
You could try in here and see if it has the info you need.
http://www.customtacos.com/tech/files/05FSM/repair.html
Old 03-07-2009, 07:21 AM   #10
DNahas's Avatar
Never mind, I traced the problem back to an ID 10 T error with the operator. To embarrassed to provide the details of that error code..
It works great on a 2009, provided you read the directions.
FWIT, I would still like to find a copy of the 09 FSM so I can find the connection for the backup camera below the dash.
Fog Light Mod. 2004Taco 1st Gen. Tacomas 193 09-20-2014 08:32 PM
Fog lights not working after fog light anytime mod bobfm10350 2nd Gen. Tacomas 7 06-01-2014 06:33 PM
Fog Light Relay 2009 jrdbrn 2nd Gen. Tacomas 3 05-09-2011 08:10 PM
Fog light/blinker relocation mod....Got light mods? lets see sir1123 1st Gen. Tacomas 2 01-11-2011 04:39 PM
2009 Fog Light Assembly VORTMAX_99 2nd Gen. Tacomas 3 02-03-2010 07:15 PM
