2010 Dimmer Wire Location/Confirmation
Old 07-27-2012, 08:45 AM   #1
gov875 [OP] gov875 is offline
WahooTaco
gov875 is a jewel in the roughgov875 is a jewel in the roughgov875 is a jewel in the rough
gov875's Avatar
gov875's Tacoma Gallery
I'm about to wire in a OTRATTW switch and want to have the backlight on it control with the dimmer switch. Looks like I can tap the wire behind the AC controls like people do for the 4x4 Illumination mod and just wanted to confirm the color wires for this mod. I'm seeing that the GREEN wire is 12V and the GREEN w/ WHITE STRIPE is the GROUND. Can anyone confirm this? If it matters i have the non-jbl set up...
THANKS!
Old 07-31-2012, 11:04 PM   #7
joes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shed
joes06tacoma's Tacoma Gallery
http://www.ncttora.com/fsm/05+/data/.../h/em01d10.pdf
Looks like you're right, as long as a 2010 is the same as an 05.
Solid green is positive power, on with the tail lights. Green with white is the ground, variable through the dimmer switch on the dash.
Old 08-01-2012, 06:23 AM   #8
WahooTaco
gov875's Avatar
Awesome! I had just discovered the variable ground thing yesterday and started wiring it up. Hopefully this helps some other people looking for that info as well.
Old 12-04-2012, 08:21 AM   #9
Av8er is one of the sharper tools in the shedAv8er is one of the sharper tools in the shedAv8er is one of the sharper tools in the shedAv8er is one of the sharper tools in the shedAv8er is one of the sharper tools in the shedAv8er is one of the sharper tools in the shedAv8er is one of the sharper tools in the shedAv8er is one of the sharper tools in the shedAv8er is one of the sharper tools in the shedAv8er is one of the sharper tools in the shedAv8er is one of the sharper tools in the shed
Av8er's Avatar
Av8er's Tacoma Gallery
Going to be doing the same tap for my Otrattw switch for bed lights. Hoping these wires are the same color in an 09. Nice video reference of what we're attempting on the Flyeyze site.
http://www.flyzeye-designs.com/INSTALLATION.html
Tks flyeyze for the video and yes I'll be purchasing your product soon!
I'll report back if I get it wired up and running correctly from this location.
Old 12-04-2012, 08:28 AM   #10
barlowrs is one of the sharper tools in the shedbarlowrs is one of the sharper tools in the shedbarlowrs is one of the sharper tools in the shedbarlowrs is one of the sharper tools in the shedbarlowrs is one of the sharper tools in the shedbarlowrs is one of the sharper tools in the shedbarlowrs is one of the sharper tools in the shedbarlowrs is one of the sharper tools in the shedbarlowrs is one of the sharper tools in the shedbarlowrs is one of the sharper tools in the shedbarlowrs is one of the sharper tools in the shed
barlowrs's Avatar
barlowrs's Tacoma Gallery
grab a volt meter and check just to be sure...probe the wire you think it is and dim the dimmer, voltage should drop
Speed sensor wire location? CK4500 Technical Chat 1 02-09-2012 10:43 AM
Illumination or Dimmer wire to radio? DataCrypt 1st Gen. Tacomas 0 10-27-2011 06:11 PM
Wire location for seatbelt alarm Drogers Technical Chat 0 07-18-2010 06:42 PM
fog light wire location help tmolina 1st Gen. Tacomas 3 12-26-2009 09:41 PM
IAT wire location hellsrain85 2nd Gen. Tacomas 3 07-29-2008 07:30 PM
