Blacking Out Headlights, How to
Discussion in 'Lighting' started by spencer_hong, Jul 31, 2007.
  1. Dec 22, 2009 at 9:35 PM
    #221
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    after i resealed them, they started to fog up again. should i just put more sealant around it? tape?
  2. Dec 23, 2009 at 3:09 AM
    #222
    elliott.estes
    elliott.estes Well-Known Member
    sacramento
    07 Black DC TRD Sport
    In Dash Avic-D3 / Blacked out headlights / Satoshi Grille / OME 90000 Front Shocks/ OME n182 Rear Shocks / OME 885 Coils / AAL with TSB's / 10MM lift Enhancer Kit / Light Racing UCA's / BFG AT KO's (285x70x17's) / Procomp 7089 Rims
    when you put them back together did you push them together really tight and did you put electrical tape all the way around the light? I put mine in for 5 minutes at 300 and covered the entire headlight in tape and have not seen any fog in the lights yet.
    As far as sealant, idk where you would get more.. sorry wish I could give you an answer
  3. Dec 23, 2009 at 4:01 AM
    #223
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Tape doesn't do anything. It's not a sealant. The idea of tape was to cover up the ugly silicone.
    Go to your local Nissan dealership and ask for this part, B6553-89915.
    If not, order some from here:
    http://www.mynismo.com/products/?id=5577&rsku=0
  4. Dec 23, 2009 at 6:39 AM
    #224
    05 X-Runner
    05 X-Runner Murdered X
    Brett
    Napa, Nor-Cal. Whine Country U.S.A
    BSP 05 X-Runner, 07 TRD Sport Super White
    HVM C/F X-Runner badge 1 of 6 made,P/C'ed black rims,Blacked out Billet Grill,BLHM,HID's,Tinted tail covers, Fog light mod,BFLM,C2C Black eyelids,,C2C 1.75" Front drop 2" rear,C2C Hoodstruts,URD Shortshifter,URD T-CAI.Custom Coupe shiftball, NST Manifold Spacer.. 07 TRD Sport Super White,De-badged,White headlight Mod,Fog light mod,White tail light mod,C2C white eyelids, C2C hood struts
    I know alot of peeps who have bought there lights on e-bay and had the same problem of them fogging up.
    Jusy seal the crap out of them and you should be fine..
    Here's mine
    And my wife jennie's
  5. Dec 30, 2009 at 4:42 PM
    #225
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    anyone else out there have a small oven. Took the grill off and the lights yesterday only to find out that my ovens too small. I didnt want to take the chance of melting anything because the lights were making contact in a few places with the ovne walls. o well :/
  6. Dec 30, 2009 at 5:19 PM
    #226
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    Get a box big enough for the headlight. Tape off all of the seams if they aren't already. Leave the top open. Put the headlight in (remove all rubbers and bulbs). Tape off the top except for a hole big enough for a heat gun or hair dryer. Blow hot air in there for about 17-20 mins. Then pry them apart per the instructions.
  7. Dec 30, 2009 at 5:34 PM
    #227
    jr114
    Jon
    SoCal
    Truck
    you know maybe ill give that a shot. i did try using a blow dryer but everytime id get one part of the silicon hot enough to move id move onto another part of the light and the first part would reseal.haha.was a never ending circle. so i put a little bit of silicon back around to seal up any holes. but ill give this a try and see what happens.
    just not sure if a box will provide enough insulation
    Hophead1144 likes this.
  8. Dec 30, 2009 at 6:02 PM
    #228
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Put a couple of towels or an old blanket around it, that will help to insulate it.
  9. Feb 9, 2010 at 7:17 PM
    #229
    elliott.estes
    sacramento
    Mine just started to fog up today, I was hoping this would not happen. So does this mean I can wait for the fog to clear up, then pull the head lights out and just reseal them. Or do I need to pull them back apart?
  10. Feb 9, 2010 at 7:21 PM
    #230
    ImpulseRed008
    Susan
    SC
    I'd just get some of the sealant recommended in the write up and seal around the headlight. Probably should take them out to get to all sides.
  11. Feb 14, 2010 at 4:54 PM
    #231
    shredtacoma
    shredtacoma Well-Known Member
    Jace
    SOCAL
    07 Prerunner Debadged with snugtop
    Camburg lift, ProComp rims, Nitto Terragrappler tires, snugtop, Flowmaster exhaust and Airraid intake
    is this mod illegal in california
  12. Feb 14, 2010 at 5:14 PM
    #232
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    ^ YES its Extremely ILLEGAL in Socal . . .:mad:
    Don't Do It, Cause I Got A Fix It Ticket! :(
    Cop Wrote Down.
    "The Truck Is TOO BAD ASS to be on the Road w/those Black Headlights"
    :D
    ~ Finished My New Set set Yesterday for the No Eyelid Look ~
    Came Out Almost Flawless. Crystal Clear Lamp & Blinker.
  13. Feb 14, 2010 at 7:02 PM
    #233
    uglygun
    uglygun Well-Known Member
    As long as you leave the reflectors and turn indicators functional, you wouldn't get a ticket from me.
    And I'm in the progress of doing this mod to a spare set of headlights that I have for my own truck.
  14. Feb 19, 2010 at 7:37 PM
    #234
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    Let me know if you want to get rid of your stockers :D
  15. Feb 20, 2010 at 1:37 PM
    #235
    uglygun
    Actually, since the ones on the truck are brand spanking new(replaced after originals damaged in a collision) there is zero chance I will get rid of them.
    I'm doing the BLHM on a pair of older headlights, one of them has a partially broken tab and some scratches on the surface of the light but nothing that should hinder looks or function.
    I'm not even sure if I'm going to like the BLHM until after I get them installed on the truck.
  16. Feb 21, 2010 at 9:28 PM
    #236
    lostsrfn18
    lostsrfn18 Active Member
    Florida
    06 Double Cab- 6 speed
    LINE-X Paint Job. 6" Fabtech lift. XD 17" revolvers. Nitto Trail Grapplers 35" BHLM, After market Tail Lights, Added backup camera. Kenwood Media Console. 2 x 8" Subwoofers.
    hey guys I'm a new owner of a tacoma, i love this mod but I got a few questions:
    #1 So after I preheat to the 200ish degrees, I turn the oven off, then stick the headlight in for the prescribed time right?
    then remove and the light should peel apart?
    #2 when putting the headlight back together, do I put the clear lens back on and heat the whole thing together in the oven and push it together to seal? OR do I heat both pieces seperately and after the time limit pull them out of the oven and THEN push the pieces together?
    thanks for the help, im excited to get my lights looking sick like yalls!
  17. Feb 22, 2010 at 7:00 AM
    #237
    ImpulseRed008
    Susan
    SC
    Congrats on your new tacoma
    #1 If it doesn't peel apart the first time, just put it back in for a few more minutes. Even with the sealant warm, it can be tough to get apart.
    #2 Assemble the light and put the whole assembly in the oven. You start pushing the pieces together before it goes back in the oven and finish when you take it out.
    Good luck
  18. Feb 23, 2010 at 8:30 AM
    #238
    lostsrfn18
    Florida
  19. Feb 23, 2010 at 9:14 AM
    #239
    elliott.estes
    sacramento
    I just resealed mine at the Sacramento Mod day and so far no more fogging up. Thanks to blackhawk for the sealant!
  20. Feb 24, 2010 at 6:47 AM
    #240
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    can the BHLM be done to a first gen tacoma? I have a 1999 TRD Offroad and was just curious if it was possible
