LED's in Map light. Some issues
Discussion in 'Lighting' started by adio, Sep 2, 2012.
  1. Sep 2, 2012 at 11:18 PM
    adio
    adio [OP] Well-Known Member
    HI
    2015 INFERNO TRD PRO
    just installed LED's on the map lights. works great. comes on when unlocking via key fob, and turns off when turning the key to ACC. but one issue that I found was when it faded to off, there was a slight hint that the LED's are still being powered(hopefully that makes sense). here's a pic, you can see slightly even though it's pretty dim. what do you guys think is wrong?
  2. Sep 2, 2012 at 11:40 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Possibly because they require so little current to turn on, they may not be fully shutting off the SCR in the control module.
    Check them with the key off, lights off, door closed... just like you leave the truck at night... and see if they're still on.
  3. Sep 2, 2012 at 11:43 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    i have a first gen, so YMMV, but i had to solder resistors to my LEDs to make them work without the key. Used a 100 ohm 1/2 watt for each LED and it worked perfectly. again, this was for my first gen, but it could be worth looking into...
  4. Sep 2, 2012 at 11:47 PM
    adio
    HI
    "SCR", I'm lost on that one haha
    yes that too. they are on even though the truck is off. the only way to keep them off is when I move the switch on the dome to off. it kind of sucks that I can't leave the switch to door. know what I mean
  5. Sep 2, 2012 at 11:51 PM
    adio
    HI
    I haven't thought about that one. I thought all LED's are plug and play :confused:
  6. Sep 2, 2012 at 11:58 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    i guess the lower current draw freaks out the ecu or whatever supplies the power and it doesn't pull enough current to light up completely. it's the same idea with people getting "hyper-flash" with LED turn signals -- wire in a resistor inline to bring the resistance back to normal filament bulb and it behaves.
  7. Sep 3, 2012 at 12:12 AM
    adio
    HI
    I'm sorry man, but I'm kinda of lost now haha. sorry I'm not much of a electrician buff. I'm just trying to find out why the LED's are still drawing power even though their not on. sorry again if I'm not getting what you guys are trying to explain.
  8. Sep 3, 2012 at 11:47 AM
    adio
    HI
    does anyone else know the problem is? any help is greatly appreciated
  9. Sep 3, 2012 at 4:39 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    sorry, i think i misread-- i though you were having problems with them turning on... not staying on. not sure what's going on in your situation... :confused:
  10. Sep 3, 2012 at 6:20 PM
    adio
    HI
    it's all good bro. I'm still trying to figure it out myself but no luck. I bought the LED's locally, so I'm not really sure if quality gets to do anything with it drawing power.
  11. Sep 5, 2012 at 7:50 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Western Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod
