need help electrical experts
Discussion in 'Lighting' started by PLC721, Oct 18, 2012.
  1. Oct 18, 2012 at 6:00 PM
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    So my parking/corner lights no longer work when turn on, i wired my morimoto xb halos into them, same as i had the prior ccfl angel eyes. now heres the catch, when i lock my truck, they light up?
    any ideas as to why they won't work?
  2. Oct 18, 2012 at 6:09 PM
    memario1214
    Colton
    Missoula, MT
    Hooked up to a relay?
  3. Oct 18, 2012 at 6:10 PM
    PLC721
    Patrick
    Chandler, Az
    no all i did was splice the led's into the stock parking light harness, they don't pull enough load to overload it
  4. Oct 18, 2012 at 9:16 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Reverse the polarity on the halos?
    That's all I've got.
  5. Oct 19, 2012 at 12:28 PM
    PLC721
    Patrick
    Chandler, Az
    Tried that :(
    Also the rear running lights don't work
  6. Oct 19, 2012 at 12:38 PM
    memario1214
    Colton
    Missoula, MT
    I know I could fix it if I was there looking at it... But the answer isn't jumping out at me right now. :(
    Wait, your corner lights turn on when you lock?
  7. Oct 19, 2012 at 12:40 PM
    PLC721
    Patrick
    Chandler, Az
    Yes they do, I'm wondering if I blew a fuse playing with them?
  8. Oct 19, 2012 at 12:42 PM
    memario1214
    Colton
    Missoula, MT
    Okay okay... First, check your fuses. Second, did you wire it so that the corner lights flash with lock? Because mine sure don't do that and I haven't seen any other that does. The fog is beginning to clear on this end
  9. Oct 19, 2012 at 12:46 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Me thinks you blew the running light fuse if your tails aren't working either. Not sure about the lock button but if Memario is correct and they shouldn't come on when you hit the button, then you cross wired something.
  10. Oct 19, 2012 at 1:22 PM
    PLC721
    Patrick
    Chandler, Az
    Mine have always flashed when I locked my truck. Lol since the day I got it
  11. Oct 19, 2012 at 1:23 PM
    memario1214
    Colton
    Missoula, MT
    Dafuq? Check your fuses yet?
  12. Oct 19, 2012 at 1:28 PM
    PLC721
    Patrick
    Chandler, Az
    No but I do have the VIP alarm system if that has anything to do with my parking lights flashing lol
  13. Oct 19, 2012 at 1:33 PM
    Pugga
    Massachusetts
    I'd check your fuses. The alarm thing might explain why the lights still flash when you lock the doors using the fob. The power to flash the lights might be coming from a different power source or different relay due to the alarm.
  14. Oct 19, 2012 at 1:40 PM
    PLC721
    Patrick
    Chandler, Az
    Hate to be that guy, but do any of you know which fuse it would be?
  15. Oct 19, 2012 at 1:47 PM
    Pugga
    Massachusetts
    I'll look when I get to my truck, I blew that one several times when I hooked up to trailers with shitty wiring :eek:
    It's a 10A in the under hood fuse box if that helps narrow it down!
  16. Oct 19, 2012 at 1:53 PM
    PLC721
    Patrick
    Chandler, Az
    Sweet that helps! I'll look after work!
  17. Oct 19, 2012 at 4:14 PM
    PLC721
    Patrick
    Chandler, Az
    it was the tail lamp fuse underneath the dash
  18. Oct 19, 2012 at 4:17 PM
    PLC721
    Patrick
    Chandler, Az
  19. Oct 19, 2012 at 8:54 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Looks awesome!
