Headlight adjustment on a 2nd gen
Discussion in 'Lighting' started by Nixinus, Oct 27, 2012.
  1. Oct 27, 2012 at 8:36 AM
    Nixinus
    Nixinus [OP] Well-Known Member
    Oregon
    2010 4x4
    The link to the headlight adjustment for a 2nd gen (posted on ttora) is broken. Anyone have the file they can send me?
  2. Oct 27, 2012 at 8:09 PM
    Nixinus
    Oregon
    2010 4x4
    Thanks guys! I'll check them out when I get to a computer.
  3. Nov 5, 2012 at 3:03 PM
    rodney
    rodney Well-Known Member
    Toyota Sienna Mommyvan & Ford 2fitty
    *nevermind* re-posted for future help of others:
    ADJUSTMENT
    If your factory head lights are pointing rather high, you can adjust them. Also, usually after installing an HID kit, you would most likely have to do some aiming, as well.
    To adjust the height, use a long philips head screw driver to adjust it. The adjustment knob for the height is the one on the bottom closest to the fender (referring to the driver's side head light). To adjust up, you would turn your screw driver clockwise. To adjust down, turn the screw driver counter-clock wise.
    To adjust the headlights from left to right, you would take off the black plastic cover off of the adjustment knob that is placed right in the middle of your headlight. You would adjust it the same way as the height adjustment knob.
  4. Sep 18, 2013 at 12:49 PM
    tonytsai0429
    tonytsai0429 Well-Known Member
    SoCal
    Racy Inferno
    hi Rodney, could you possibly post the picture again, i have a 2013 trying to find out which knob is which..thanks!
  5. Sep 24, 2013 at 9:59 AM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    OK, I found the screw under the black plastic cover but not the one that controls up and down. Where the heck is it?
  6. Sep 26, 2013 at 12:02 PM
    tonytsai0429
    SoCal
    Racy Inferno
    I actually found it, for up and down, it didn't look like it was using screw driver, so, i used the 8 mm rivet socket for adjustment. tight spot for adjusting...
    is there any horizontal adjustment for the 2013?
    kodiakisland, let me know if you need any help, take a photo and see if you can elaborate the area
  7. Jan 15, 2014 at 10:23 AM
    skiomax
    skiomax Pro skier
    Ottawa, Ontario
    2013 Tacoma TDR Sport DC
    Extang cover Thule roof rack pop & Lock Short antena Weathertech floor liner TRD skid plate Leather Seat package
    can you post a picture for the 2013 for the adjutment up and down? I can't find the screw... thanks
  8. Jan 16, 2014 at 12:00 PM
    tonytsai0429
    SoCal
    Racy Inferno
    here are couple pictures , one on each side of light, for your reference (I'm using a silver/metal utensile to point out the screw/nut)
  9. Jul 7, 2014 at 12:26 PM
    woof359
    woof359 Well-Known Member
    a) Adjust the aim vertically:
    Adjust the headlight aim into the specified range by turning aiming screw A with a screwdriver[​IMG]
  10. Jul 7, 2014 at 12:27 PM
    woof359
  11. Aug 10, 2017 at 9:11 PM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    Need to do this... hmm
  12. Dec 22, 2019 at 4:44 PM
    Red Buck
    Red Buck Member
    Bellevue, WA
    2009 Dbl Cab TRD
    Here is a diagram of where the up/down adjustment is. On my 2011 there is a slot formed by two plastic ribs above the nut with the 8mm head. A philip'shead screwdriver fits down this slot and into the nothches of the adjustment head. The counter clockwise turn to lower the light is for the screwdriver (the adjustment head will turn clockwise). If you use an 8 mm socket to turn the adjustment head twist it in a clockwise direction to lower the headlight beam. Head light Adjustment.jpg
  13. Aug 30, 2023 at 8:14 PM
    otherphone
    otherphone Well-Known Member
    MA
    09 tacoma sport
    OME2.5lift w/medium leafs
    How many twists are allowed? I just put in some BROCK headlights from Partsgeek for $130 and it seems like the adjustment screws on both are just decorations .
  14. Sep 5, 2023 at 4:16 PM
    crashnburn80
    crashnburn80 Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Not uncommon for adjustment screws on aftermarket assemblies not to work, or break when turned too many times so that they no longer work. I'd definitely recommend OEM.
    otherphone[QUOTED] likes this.
