How to install the halo led projector headlight
Discussion in 'Lighting' started by usmctaco, Jan 23, 2009.
  1. Jul 28, 2009 at 4:42 PM
    #21
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    -I have these same head lights. Make sure you throw some electrical tape around the 3 little LED lights. They vibrate out of their hole, bang around and the bulbs break! Plus if your out muddin' and this happens, its a direct hole into the head lamp and mud will get in there and RUIN YOUR LIFE! I know cause it happened to me :( They look good though!
  2. Jul 28, 2009 at 10:39 PM
    #22
    #Reistlehr-
    #Reistlehr- AngryTacoma
    Parsippany, NJ
    09 Magnetic Grey Double Cab Long Bed SR5
    anyone else having issue adjusting the headlights? Installed, tehyre a pain in the ass to get to the gear screws to rotate to adjust the lights.. omg.. mine are waaayy off.
  3. Sep 13, 2009 at 3:00 PM
    #23
    can_i_has_tacoma?
    can_i_has_tacoma? New Member
    SR5 Sport
    where can I get those eyelids?? thats a nice clean look; nice truck
  4. Sep 14, 2009 at 1:38 AM
    #24
    Fo_SheeZy
    Fo_SheeZy Active Member
    Brian
    Johnson City, TN
    08 Urban 4Runner
    http://www.cardomain.com/ride/3108855
    They look good, but how bad is the beam pattern?
  5. May 5, 2011 at 8:55 PM
    #25
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    sub for weekend [project
  6. Jul 28, 2011 at 4:51 PM
    #26
    stmpjmpr
    Jimmy
    subd again
  7. Jul 28, 2011 at 5:06 PM
    #27
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Front end looks good.
  8. Feb 3, 2012 at 3:25 PM
    #28
    Amarino70
    Amarino70 New Member
    Tony
    Neworleans
    White with blk trim 08
    Basic looking to make her hot very hot
    Trying to install halo/led what wire is positive on truck light
  9. Sep 25, 2012 at 11:09 PM
    #29
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    Always buy PlugNplay.
  10. Mar 19, 2017 at 7:44 PM
    #30
    lancewood
    lancewood Active Member
    lance
    British Columbia Canada
    09 tocoma 2.7L access cab 4×4
    So what wire of the two on the parking lamp did you connect the positive to? And where did you connect the negative wire?
  11. May 4, 2017 at 9:30 AM
    #31
    bartholomew07
    bartholomew07 Active Member
    Jake
    Colorado
    07 DCSB Sport 4x4 6 spd
    @lancewood
    Did you ever figure out which is positive and negative? On my running lights I have one green wire and one white wire with a black stripe and I don't know which is which been searching all morning!
  12. May 10, 2017 at 5:55 PM
    #32
    lancewood
    lance
    I connected the led and helos to the marker light. That way you can trun on and off when you like
  13. Aug 17, 2018 at 4:44 PM
    #33
    GentlemanGinger
    GentlemanGinger Member
    That parking light is also your blinker..... does that mean your led lights blink with the blinker? I have similar headlights but worried to wire the led for that reason
  14. Aug 17, 2018 at 5:24 PM
    #34
    bartholomew07
    Jake
    Colorado
    @GentlemanGinger
    On my headlights there are three pigtails on the lights, one from the leds, one from the blinker and one from the halos. The leds do not blink with the blinker. I’m away for the weekend. Can you post a pic of your wires? I’m away for the weekend so I can’t look at mine now but I’ll try to help when I get back. I also have the wiring diagram for the 05-09 second gen if you think that would help.
  15. Aug 17, 2018 at 5:29 PM
    #35
    GentlemanGinger
    So I’m looking at 2 wires. I’ve checked with volt meter probes and one is obviously ground and the other is constant current until I put on the blinker. I really don’t want to have blinking halos
  16. Aug 17, 2018 at 6:45 PM
    #36
    bartholomew07
    Jake
    Colorado
    What I did was I tapped my halos and leds into my parking lights, which should be separate from your blinkers. That way you can turn on your halos/ leds as running lights and also they will come on by default when you headlights are on
    @GentlemanGinger
  17. Aug 19, 2018 at 6:36 PM
    #37
    GentlemanGinger
    That worked perfectly
  18. Sep 12, 2018 at 12:17 PM
    #38
    wmchenry02
    wmchenry02 Well-Known Member
    Wil
    2007 Tacoma
    When you attached the wires to the parking lamps were they the same color going in to both? Or how is that done?
