LED flashers doubling as break lights??
Old 01-28-2013, 08:58 PM   #81
Thin Blue Line
ProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shed
ProForce's Avatar
ProForce's Tacoma Gallery
Hmm... well now you've got me going back to the original plan, except minutes all the relays and BS all together. This is basically plug and play module for OP needs. I have worked with ShoMe flashers before and love them, just wasn't familiar with this one.
Only concern is this is rated for 6 amps max, 3 per side. With 2 lights per side for a total of 4, don't you think well be pushing the limits pretty close if not exceeding them
Old 01-30-2013, 09:35 AM   #82
Bengland25 [OP] Bengland25 is offline
Never Forget! 343
Bengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud of
Bengland25's Avatar
Firefighter:
Bengland25's Tacoma Gallery
Haha I like this, have multiple guys with experience and knowledge working on this. I know it'll work great, just to figure out now which will be easier and clean.
I am holding off on buying lights right now.
As far as which will be blinking for turn signals, I think it would look awesome to have them do 1&2 do left and 3&4 do right! If we can swing that... If not no worries.
My main goal is to have multi functional lights that are both dust lights and blinkers. If we could find clear lensed LED's with both amber and red that would be cool but probably not necessary or possible from what I've researched. Haven't found a single on that doesn't cost hundreds for that type of light..
Old 01-30-2013, 07:38 PM   #83
Thin Blue Line
ProForce's Avatar
This is any "help" threads dream come true with all this bouning ideas around to find the best option.
OK, so after looking at everything, I think going back to the original design but substituting the ShoMe 11.1005STT as mentioned earlier is the best option. This flasher gives us the option to wire the lights directly into the turn signals without any need for relays, diodes, or crazy wiring schematics.
I did the math on the power ratings for THESE lights that you found earlier. It does not show the wattage of each light, BUT we can assume that each individual LED does not exceed 1w each. That means that each light consumes no more than 10w total. 10watts @ 12 volts = 0.83 amps. So it is safe to assume that each light draws less than 1 amp in total. So our max power consumption will be 2 amps per side, and 4 amps total. This module limits us to 6 amps MAX and 3 amps per side. It calles for a 5 amp fuse so we will make it just fine.
My final recommendation would be to order the following:
-ShoMe Flasher 11.1005STT retails for $48.22 but can be found much cheaper online.
-Two sets of THESE led lights you found on ebay
-A custom on/off switch of your liking from Otrattw.
-A small single momentary push button switch.
-Misc wiring and installation supplies.
Old 01-31-2013, 08:43 AM   #84
Never Forget! 343
Bengland25's Avatar
Firefighter:
No kidding, this is more then I've ever hoped on a "help" thread! So thanks to everyone!
Ok so I will be ordering this stuff if its the final solution. Anything your concerned about with this setup or should it all go smoothly??
Old 01-31-2013, 12:46 PM   #85
Thin Blue Line
ProForce's Avatar
No I'm sure this is it :thumbup:
Old 03-04-2013, 12:52 AM   #87
Thin Blue Line
ProForce's Avatar
Is this still happening?
Old 03-27-2013, 08:09 AM   #89
kd8bao is one of the sharper tools in the shedkd8bao is one of the sharper tools in the shedkd8bao is one of the sharper tools in the shedkd8bao is one of the sharper tools in the shedkd8bao is one of the sharper tools in the shedkd8bao is one of the sharper tools in the shedkd8bao is one of the sharper tools in the shedkd8bao is one of the sharper tools in the shedkd8bao is one of the sharper tools in the shedkd8bao is one of the sharper tools in the shedkd8bao is one of the sharper tools in the shed
kd8bao's Avatar
EMS:
kd8bao's Tacoma Gallery
Ever get it goin?
Old 03-27-2013, 03:42 PM   #90
Thin Blue Line
ProForce's Avatar
Originally Posted by kd8bao View Post
Ever get it goin?
Waiting on OP.
Old 06-22-2013, 03:27 PM   #92
Never Forget! 343
Bengland25's Avatar
Firefighter:
Waiting on OP.
SOOOOOOO Boss gave me a raise, refinancing my truck and bills are nice and steady.
Still down to do this?? thinking of buying supplies next weekend and possibly installing either the weekend of the 4th or the following weekend.
Sorry I disappeared on this thread, just havent had time or money to do it!
Old 06-23-2013, 04:20 AM   #93
Thin Blue Line
ProForce's Avatar
I thought you died! Glad to know your still around
Let's get this project going
Old 06-23-2013, 05:21 PM   #94
Never Forget! 343
Bengland25's Avatar
Firefighter:
AGREED! lol
so just curious as to if this is the correct Sho Me LED Flasher, as well as making sure these Lights will work just as well if not better then the first ones I found??
Let me know buddy, planning on ordering this coming thursday as well as all my switches
Old 06-26-2013, 06:43 PM   #96
Thin Blue Line
ProForce's Avatar
this:
Old 06-30-2013, 12:26 AM   #100
Thin Blue Line
ProForce's Avatar
Nice! I'm gonna recommend you cut the box and install the lights on your own cuz that's gonna take time and I don't have the resources to cut the box. Once the lights are in I can help you wire it up. It's going to be pretty hard to schedule a time cuz I work 7 days a week now, usually around 70+ hours a week. I don't even have time for the GF so hopefully we can figure something out.
WTB: LED Tail Lights/LED third brake light for a 1997 Taco icemantaco 1st Gen Tacoma Marketplace 0 08-12-2012 08:33 AM
LED Grill Accent or LED Interior lights Logan22 Lighting 7 06-17-2012 12:27 PM
Attn: LED Lighting Enthusiasts - Please Rate Your LED Lights!!! flyzeye designs Product Reviews 6 10-12-2011 12:21 PM
My head light flashers are working my fog lights arnette 2nd Gen. Tacomas 5 01-09-2011 11:51 PM
LED flashers not working.... MadeInMaine Technical Chat 3 12-21-2010 10:23 AM
