converting KC back ups/floods to HID
Old 12-04-2012, 03:02 PM   #1
cr500taco [OP] cr500taco is offline
cr500taco will become famous soon enough
cr500taco's Avatar
cr500taco's Tacoma Gallery
I have a couple of halogen KC back up/floods under my rear bumper and I am going to move them to the rear of my cargo basket on the roof of the cab. I am thinking of converting them to HID. Do any of you know how far away the ballasts can be placed?
Old 12-05-2012, 02:20 PM   #2
cr500taco's Avatar
bump
Old 12-05-2012, 10:31 PM   #3
09DBLCAB09 is on a distinguished road
09DBLCAB09's Tacoma Gallery
As far as the wires are on whatever HID kit you decide to order
Old 12-05-2012, 10:32 PM   #4
Typically right around 10" or so
Old 12-05-2012, 10:41 PM   #5
Banned
acdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shed
acdronin's Tacoma Gallery
HID's? Really, how much brighter do you need, I got 2X130 watts in my KC's and jesus, they are plenty bright. I can see clearly behind me even with the tinted windows rolled up. To each his own but it seems a little unnecessary to me
Mine are mounted at the top of my rack
This is from about 40-50 feet back, that's 260 watts
Old 12-05-2012, 10:52 PM   #6
t4daddy is one of the sharper tools in the shedt4daddy is one of the sharper tools in the shedt4daddy is one of the sharper tools in the shedt4daddy is one of the sharper tools in the shedt4daddy is one of the sharper tools in the shedt4daddy is one of the sharper tools in the shedt4daddy is one of the sharper tools in the shedt4daddy is one of the sharper tools in the shedt4daddy is one of the sharper tools in the shedt4daddy is one of the sharper tools in the shedt4daddy is one of the sharper tools in the shed
t4daddy's Avatar
t4daddy's Tacoma Gallery
Typical HIDs are only 35 watts each, so, your prolly brighter than he'd be.
Old 12-05-2012, 11:09 PM   #7
Banned
Watts are power, lumens is light output, depending on which K bulbs he puts in there (6000K) is probably gonna be brighter than mine. My point is, why spend the extra cash, 35 bucks shipped for 2 KC 130 watt bulbs and I can blind people with a quickness.
Old 12-06-2012, 12:26 AM   #9
Banned
This might sound goofy but it's the best wire for this application~Low Voltage outdoor lighting wire, the voltages are the same-12 volts, it's designed to run a couple of hundred and more, it has very thick insulation against the elements as it designed to be run in landscapes, in the elements and wattage wise it will handle 300-400 watts on a single two strand wire run. Technically speaking, our lighting is exactly the same, low volt lighting and (in the case of my dclb), around 35 feet of run depending on how i run the wires.
In my case I ran the single two-strand from the engine bay, down along the frame rails, up between the cab and the bed, did my split there and ran each set tucked under the cap on top of the bed sides, to each of the lumber rack rear uprights and to each of the lights. The only trick was that that wiring didn't fit into the KC's grommets but i bought two rubber stoppers from the local hardware store, drilled them out just enough to stuff the wires through and then modded the stoppers till they fit snug into the KC housings. Mine are flipped upside down so the wires actually come out on the (now) top side of the lights, so far this winter they are totally watertight.
Converting hella 500's to HID and then installing, got a few questions RobbySkateboard Lighting 1 09-20-2012 12:54 PM
General Cost of Converting Fog Lights To HID Logan22 Lighting 11 06-12-2012 08:45 AM
HID Headlights or KC Daylighters Behind Satoshi goufcustom 2nd Gen. Tacomas 8 12-08-2011 05:48 PM
Converting Hella 500 55w Vs. 35w hid mudthedoor Lighting 13 09-29-2011 06:37 PM
KC DAYLIGHTERS HID CONVERSION 97yota4wd Lighting 1 01-31-2011 02:43 PM
