H1 Retrofit on 2013 Pyrite
Discussion in 'Lighting' started by Raoul Duke, Jan 2, 2013.
  1. Jan 2, 2013 at 6:45 PM
    Raoul Duke
    Raoul Duke [OP] Well-Known Member
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    retrofit/bhlm, CB, System, color match grill, debadge, TRD wheels
    Did my Retro, heres a couple pics, I 'll put some more if any one likes, I can answer any questions as well
    [​IMG][​IMG]
  2. Jan 2, 2013 at 6:46 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
  3. Jan 2, 2013 at 6:50 PM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
  4. Jan 2, 2013 at 6:50 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    You're truck looks angry.
  5. Jan 2, 2013 at 6:52 PM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    I know hahaha
    I also have a grill craft MX and im waiting for a paint matched sport grill to arrive, i think it will look good when thats in as well
  6. Jan 2, 2013 at 6:54 PM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
  7. Jan 2, 2013 at 7:00 PM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    Looks great. I was wondering....
    - did you go through TRS?
    - what type of halos did you get (CCFL or LED)
    - what sealer did you use?
    - what did it all run you? Can PM me the answer if you're more comfortable with that.
  8. Jan 2, 2013 at 7:06 PM
    SixLugThug
    SixLugThug Well-Known Member
    Alexander
    Calgary
    09 off road
    Shorty Antenna, Blacked out grill, afe intake, black headlights, 3 inch lift
    looks excellent
  9. Jan 2, 2013 at 7:07 PM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    I've had that idea of doing that with the amber halos. Love the look and it's legal to have on :D
  10. Jan 2, 2013 at 8:45 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    Yeah. Can't decide between amber or white halos.
  11. Jan 2, 2013 at 8:59 PM
    ToyotaKTMracing
    Shay
    West Virginia
    I'll change around what I said before. I would get amber halos and use them as blinkers. I wonder what that would be like. White looks nice too.
  12. Jan 2, 2013 at 9:14 PM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    Ya, bought from TRS on their black friday sale so I got %25 off
    cost me $270 for everything (think I saved about $90 for black friday sale)
    The halos are LED (less breakable for offroading)
    for sealing them I just left the existing stuff on there and added a bead of stuff that I bought from TRS (extra $10 plus is handy to have in the tool box for other projects)
  13. Jan 2, 2013 at 9:15 PM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    I think the Ambers are WAY better suited for toyotas seeing as they already have amber DRL's.... plus its different
  14. Jan 2, 2013 at 9:24 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  15. Jan 16, 2013 at 7:28 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    awesome Raoul!
  16. Jan 22, 2013 at 3:44 PM
    XXFattyHunterXX
    XXFattyHunterXX Well-Known Member
    Westminster, Colorado
    T4R
    Very nice! Just finished my install but don't know where to put the ballast, can I get a picture? Plus where did you connect the halos for it to stay on like that? Pics would help. Thanks
  17. Jan 25, 2013 at 5:39 AM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    I can't really get pictures of the baslasts but on the drivers side i mounted it to the inner fender wall tucked in next to the battery and on the pass. side i mounted it next to the rad on that exposed piece of metal. I used factory holes for both and put a bead of silicone on each ballast to keep them from moving or vibrating
