Re use of stock fog lights
Old 02-11-2013, 09:39 AM   #1
Penz83 [OP] Penz83 is offline
Penz83 is on a distinguished road
Penz83's Avatar
Penz83's Tacoma Gallery
I have a new set of lights on the way for my truck. They are blacked out, they also come with smoke fog lights. Re use of stock fog lights-imageuploadedbytapatalk1360604113.246230.jpg
I'm thinking about using my stock fog lights as extra lighting from behind my grill. Can I splice into the fog light circuit and run all 4 without overloading the circuit or should I run a separate circuit?
Old 02-11-2013, 09:45 AM   #2
Longtime Toyman
4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed
4Wheelin4Banger's Avatar
Navy: DDG 996
Location: Ferntucky, NV Halfway between Reno & Falabama
4Wheelin4Banger's Tacoma Gallery
I would run a separate circuit for them. I doubt Toyota planned on the stock one running twice the load.
Old 02-11-2013, 09:45 AM   #3
GO TIGERS!
holyfield19 is one of the sharper tools in the shedholyfield19 is one of the sharper tools in the shedholyfield19 is one of the sharper tools in the shedholyfield19 is one of the sharper tools in the shedholyfield19 is one of the sharper tools in the shedholyfield19 is one of the sharper tools in the shedholyfield19 is one of the sharper tools in the shedholyfield19 is one of the sharper tools in the shedholyfield19 is one of the sharper tools in the shedholyfield19 is one of the sharper tools in the shedholyfield19 is one of the sharper tools in the shed
holyfield19's Avatar
holyfield19's Tacoma Gallery
Just saying from experience: You will want to be sure those headlights are sealed really well before you install them. Take your time and some silicone and go around the edges really well to seal them up or they will fog, and that is a PITA to correct after the fact.
Old 02-11-2013, 10:48 AM   #5
Penz83's Avatar
Thanks for the tip on sealing the lights, I would have never known... I think I will run a separate circuit and switch. Only thing left to figure out is how to mount them.
I also wonder If I can fit or modify the light housings to fit a brighter bulb?
Old 02-11-2013, 12:30 PM   #6
Longtime Toyman
Navy: DDG 996
I have 55W H10 yellow bulbs in mine instead of the stock 42W whites.
Old 02-11-2013, 12:35 PM   #7
GO TIGERS!
[QUOTE=Penz83;6421681]Thanks for the tip on sealing the lights, I would have never known... I think I will run a separate circuit and switch. Only thing left to figure out is how to mount them.
I also wonder If I can fit or modify the light housings to fit a brighter bulb?[/QUOTE]
Like this??
Old 02-11-2013, 01:36 PM   #8
Penz83's Avatar
Wow yeah what kind of bulbs are in there?
Old 02-12-2013, 02:40 AM   #10
GO TIGERS!
Originally Posted by ChamYota View Post
are those retrofitted Fogs?
Correct. Blazers from TRS. This was harder to do than the headlight retro, but I think they came out great, and absolutly worth it. Some people just cut out a hole in the back and stick the end through. I ended up putting the whole projector inside the housing. Then some plexi glass shrouds and presto:
Old 02-13-2013, 09:20 PM   #11
Penz83's Avatar
I got my headlight/fog kit today, lights look great can't wait to get them in. I didn't realize the kit came with a complete wiring harness including switch and relay! That will make wiring up my original fog lights behind my grill that much easier. Re use of stock fog lights-imageuploadedbytapatalk1360819150.635638.jpg
It has a fuse built into the harness so I'm assuming I can get the 12v at an open location near the battery?
Old 02-15-2013, 01:12 PM   #12
Penz83's Avatar
Would it be ok to stick whatever type bulb that will fit in the oem fog housings? Preferably something much brighter. Would heat be an issue?
Old 02-15-2013, 01:17 PM   #13
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
I don't mean to thread jack but how are your retros holding up? I finally got mine sealed and did the fog light anytime mod so they've been running almost constantly
Old 02-16-2013, 10:11 AM   #14
Longtime Toyman
Navy: DDG 996
H10s fit the housing & plug and are 55W in stead of 42W.
Old 02-16-2013, 07:19 PM   #15
Penz83's Avatar
My new fog housings use a 9005 bulb, I found some 100w bulbs, would that be too much for these housings?
Old 02-16-2013, 07:27 PM   #16
Pugga's Avatar
Definitely too much for the stock wiring, not sure about the housing itself. That's a lot of juice for a small, plastic housing.
Old 02-16-2013, 07:36 PM   #17
Penz83's Avatar
Yeah that's what I was thinking. What about 65w. I found some nokya 9005 65w in 3800k
Old 02-17-2013, 12:37 AM   #18
Longtime Toyman
Navy: DDG 996
My wiring could handle two 100W bulbs but I doubt the housings could.
How long do you run them for at a time?
I just got the 55Ws when a local TWer gave me his front bumper skin with fogs & rear bumper with receiver hitch. The longest mine have been on is 45 min, don't know how long he ran them for at a time.
Old 02-17-2013, 12:50 AM   #19
Rich91710's Avatar
Rich91710's Tacoma Gallery
Way too much.
Melt the housing, and would likely blow the circuit.
The fuse and wires were designed for 42 watts times 2.
55w is workable, but double that?
Nope.
Old 02-17-2013, 03:31 AM   #20
dont tread on me!
Kolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shed
Kolunatic's Avatar
Kolunatic's Tacoma Gallery
I got my headlight/fog kit today, lights look great can't wait to get them in. I didn't realize the kit came with a complete wiring harness including switch and relay! That will make wiring up my original fog lights behind my grill that much easier. Attachment 195770
That's cool. What brand of kit did ya get? I like that they gave ya everything ya need.
Fog lights for stock bumper kriskross 2nd Gen Tacoma Marketplace 17 11-28-2012 08:58 PM
Stock Fog Lights??? Gleason05 1st Gen. Tacomas 5 02-03-2012 08:54 AM
f/s:Stock fog lights Ridingontrd 2nd Gen Tacoma Marketplace 12 10-14-2011 07:43 AM
WTB Stock Fog Lights. BIGLuke Lighting 0 06-17-2009 01:04 PM
***Other than stock fog lights...*** kungfupanda Lighting 6 05-06-2009 02:42 PM
