Tips for correcting slant?
Old 02-23-2013, 06:54 PM   #1
Kavik [OP] Kavik is offline
Kavik
Kavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shed
Kavik's Tacoma Gallery
Finished up my mini H1 retrofit tonight and thought I had them level, I even took them out and put them on the truck to make sure, but somewhere between then and re-sealing them, my passenger side has a slight slant to it. Does anybody have any tips as to how to correct this?
Old 02-23-2013, 07:39 PM   #2
Rich91710's Avatar
Rich91710's Tacoma Gallery
H1 is going to be tough.
On the D2S, you might be able to loosen the mounting ring and retighten, but with the H1 using the clip mount, and unclipping drops the projector into the housing, I think you are attached to another object by an inclined plane, wrapped helically around an axis
Old 02-23-2013, 07:46 PM   #3
Kavik
So I guess my best bet would be to loosen the lock nut and try to position the projector from the back and then re-tighten until said slant is gone?
Old 02-23-2013, 08:11 PM   #4
Rich91710's Avatar
Give it a try. I would suspect that it got bumped during tightening of the locknut.
Old 02-23-2013, 08:20 PM   #5
Kavik
I will have to do it on my day off soon and see if that works.
Old 02-26-2013, 07:32 AM   #7
pringles808 is on a distinguished road
pringles808's Avatar
Law Enforcement:
pringles808's Tacoma Gallery
i have the same problem with mine. ive read on some of the retrofit forums that you can try removing the bulb then sticking a large flat head screw driving and turning the projector without having to remove the headlight.
i've had my slant for over 4 months now and havent found the time to fix it.
Old 02-26-2013, 08:27 AM   #8
Kavik
I fixed mine by just loosening the lock nut and slowly turning it till I was able to level it out. It took 3 or 4 times because I had to put them on my truck every time to test them. But now they are perfect
Need help correcting my current suspension set up. yoTaco98 Suspension 40 05-30-2012 01:22 PM
1936 Pontiac 4-door slant back for resto kolie Buy / Sell / Trade - Other 7 07-05-2011 05:13 AM
Where can I find a Slant Back Camper Shell? UrbanLegend Buy / Sell / Trade 0 01-11-2010 02:16 PM
My slant on the Fogs on mod AZFizik 2nd Gen. Tacomas 55 06-26-2009 05:26 PM
Formula for correcting odometer error? JBeasty Technical Chat 3 05-12-2008 06:08 PM
