2011 Tacoma SR5 Fog Light Installation.. Need some help Please.
Old 04-08-2013, 12:11 AM   #22
Rich91710's Avatar
Rich91710's Tacoma Gallery
Personally?
Keep the part that connects to the lights and bin the rest.
Buy the FJ switch and harness and build your own harness and you can have an illuminated switch WITH indicator light that fits the dash properly.
The full FJ kit is about $75 with harness... that'll get you the connector for the back of the 6-pin switch.
I've got a wiring diagram for that around somewhere... I'll find it tomorrow evening.
Old 04-08-2013, 12:17 AM   #23
barcapopo [OP] barcapopo is offline
barcapopo is on a distinguished road
barcapopo's Tacoma Gallery
Where do I get the FJ kit? Ebay? Got a link?
Originally Posted by Rich91710 View Post
Personally?
Old 04-08-2013, 12:23 AM   #24
Rich91710's Avatar
http://www.toyotatrdparts.com/Script...?idproduct=-59
You'll use the switch end connector and cut off the other connectors and DIY it into an OTC cube relay.
Old 04-08-2013, 09:00 AM   #25
It burns when I pee....
ABA180 is one of the sharper tools in the shedABA180 is one of the sharper tools in the shedABA180 is one of the sharper tools in the shedABA180 is one of the sharper tools in the shedABA180 is one of the sharper tools in the shedABA180 is one of the sharper tools in the shedABA180 is one of the sharper tools in the shedABA180 is one of the sharper tools in the shedABA180 is one of the sharper tools in the shedABA180 is one of the sharper tools in the shedABA180 is one of the sharper tools in the shed
ABA180's Avatar
ABA180's Tacoma Gallery
It just might work Rich. Not sure about his, but the one that came with my aftermarket did the job right and looks OEM enough in terms of fit.
Old 04-08-2013, 09:01 AM   #26
ABA180's Avatar
Originally Posted by barcapopo View Post
Hmm that seems like a good idea. By connecting to parking light they will still be on all the time, but when in park they shut off? I think i need to know how to do that
I don't have daytime running lights on mine, so if you do it might be different.
On mine I need the parking lights on to turn my fogs on. Doesn't matter if the low or high beams are on they never change.
Old 04-08-2013, 09:07 AM   #27
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
No, I tapped into the parking light wire which is the corner marker light on the headlights. It means your fog lights can be turned on whenever your parking lights are on, the first position on your light switch.
Old 04-08-2013, 07:06 PM   #28
Rich91710's Avatar
His kit (and switch) look just like the one that I got.
Doesn't fit the opening worth a crap... huge gap at the top/bottom.
Looks bad, and doesn't hold tight.
Old 04-08-2013, 07:08 PM   #29
Rich91710's Avatar
Ditto.
Corner parking lights are on with the headlights/taillights.
The DRL are only on when the headlights are OFF, or with the turn signals. You don't want to use the DRL unless you want to use the fogs in the daytime and as a redundant turn signal.
Old 04-08-2013, 07:10 PM   #30
Rich91710's Avatar
Old 04-13-2013, 09:30 PM   #31
FOX HOUND
Aeon is on a distinguished road
Aeon's Avatar
Aeon's Tacoma Gallery
barcapopo
click here
http://www.tacomaworld.com/forum/2nd...0-tacomas.html
and
http://www.yourtacoma.com/faq/index....d=3&artlang=en
OEM fog light installation-2010 Tacoma Silvert 2nd Gen. Tacomas 6 06-21-2014 04:14 PM
Fog light installation RollTacomaRoll 2nd Gen. Tacomas 7 05-27-2012 12:27 AM
Fog light installation help? jayhud11 1st Gen. Tacomas 0 01-25-2012 03:24 PM
Aftermarket Fog Light Harness for 2005 - 2011 Tacoma Tunngavik Buy / Sell / Trade 9 01-12-2011 08:56 AM
Fog light mod 2011 Tacoma Steig 2nd Gen. Tacomas 13 09-28-2010 01:01 AM
