LED Exterior and Interior lights
Old 07-31-2013, 03:55 AM   #2
TCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shed
TCprerunner's Avatar
TCprerunner's Tacoma Gallery
Search led there is a thread by csjumper that he sells everything you need
Old 08-10-2013, 01:41 PM   #4
HiFinest Shiggz is on a distinguished road
HiFinest Shiggz's Tacoma Gallery
Superbrightleds.com, just bought and installed map,dome,license plate & reverse lights
Old 08-11-2013, 06:52 AM   #6
Tito2287 is one of the sharper tools in the shedTito2287 is one of the sharper tools in the shedTito2287 is one of the sharper tools in the shedTito2287 is one of the sharper tools in the shedTito2287 is one of the sharper tools in the shedTito2287 is one of the sharper tools in the shedTito2287 is one of the sharper tools in the shedTito2287 is one of the sharper tools in the shedTito2287 is one of the sharper tools in the shedTito2287 is one of the sharper tools in the shedTito2287 is one of the sharper tools in the shed
Tito2287's Avatar
Tito2287's Tacoma Gallery
Originally Posted by Naholo808 View Post
Aloha everybody, new to the forums here. Does anybody know where i can buy LED lights for my interior (MAP and Dome), reverse and license plate?
Go to superbrightleds.com but beware, if you do a search for your vehicle it'll give you different bulb options but none of the listed dome lights will actually fit. They're to short. It recommends the 3022x4 but this is the one you want http://www.superbrightleds.com/morei...d-festoon/235/
For license plate lights I went with
http://www.superbrightleds.com/morei...edge-base/204/
Old 08-12-2013, 01:06 AM   #7
Naholo808 [OP] Naholo808 is offline
Naholo808 has much to be proud ofNaholo808 has much to be proud ofNaholo808 has much to be proud ofNaholo808 has much to be proud ofNaholo808 has much to be proud ofNaholo808 has much to be proud ofNaholo808 has much to be proud ofNaholo808 has much to be proud ofNaholo808 has much to be proud ofNaholo808 has much to be proud of
Naholo808's Avatar
Naholo808's Tacoma Gallery
Yeah, I was wondering why it only shows the same bulbs every time I search. Thank you for the tip!!!
Old 08-12-2013, 06:20 PM   #8
Liam TRD is a jewel in the roughLiam TRD is a jewel in the roughLiam TRD is a jewel in the rough
Liam TRD's Tacoma Gallery
This may be a dumb question, but how many do I need to do my may lights and dome light? I am assuming just two for the liscense plate. thanks..
Old 08-12-2013, 06:24 PM   #9
You need 1 bulb for each map light and one festoon style led for the dome light.
Old 08-12-2013, 06:42 PM   #10
Naholo808's Avatar
Map lights: be cafeful when taking out your lenses. Dont pry to hard on the corners because you will either damage the lense or the surface around it. If you have big fingers, you will definitely have a hard time taking out the bulbs. What i did was i simply got some tape, wrapped the bulbs and gently pulled to release.
Aloha
Old 08-12-2013, 06:59 PM   #11
DR007 is one of the sharper tools in the shedDR007 is one of the sharper tools in the shedDR007 is one of the sharper tools in the shedDR007 is one of the sharper tools in the shedDR007 is one of the sharper tools in the shedDR007 is one of the sharper tools in the shedDR007 is one of the sharper tools in the shedDR007 is one of the sharper tools in the shedDR007 is one of the sharper tools in the shedDR007 is one of the sharper tools in the shedDR007 is one of the sharper tools in the shed
DR007's Avatar
DR007's Tacoma Gallery
Aloha
I second that. I used my pocket knife to pry on the corner but its sketchy because its easy to scratch. Did it multiple times and no blimishes.
Old 08-12-2013, 09:40 PM   #12
Naholo808's Avatar
Cool. When I took off the cover I had to think to myself, "how in the world do I pull out the bulb?" I googled around and found a video on YouTube and some guy used paint tape to grip the bulb. Guy on the video said some guys who use tape still had problems. For me It worked like a champ.
Old 08-19-2013, 09:13 AM   #13
belone12 is one of the sharper tools in the shedbelone12 is one of the sharper tools in the shedbelone12 is one of the sharper tools in the shedbelone12 is one of the sharper tools in the shedbelone12 is one of the sharper tools in the shedbelone12 is one of the sharper tools in the shedbelone12 is one of the sharper tools in the shedbelone12 is one of the sharper tools in the shedbelone12 is one of the sharper tools in the shedbelone12 is one of the sharper tools in the shedbelone12 is one of the sharper tools in the shed
belone12's Avatar
belone12's Tacoma Gallery
Just curious, what colors did you guys go with? trying to decide between atural white or cool white for the maps/dome....
Old 08-19-2013, 09:19 AM   #14
ross123 has a brilliant futureross123 has a brilliant futureross123 has a brilliant futureross123 has a brilliant futureross123 has a brilliant futureross123 has a brilliant futureross123 has a brilliant futureross123 has a brilliant futureross123 has a brilliant futureross123 has a brilliant futureross123 has a brilliant future
Army:
ross123's Tacoma Gallery
I just did my whole interior and license plate for 9 bucks from amazon.
Old 08-19-2013, 09:32 AM   #16
belone12's Avatar
I went with cool white.
This is old vs new
That looks great! Are the maps blinding if you need to throw them on while driving or not so bad?
Old 08-24-2013, 01:56 PM   #20
Newlife is one of the sharper tools in the shedNewlife is one of the sharper tools in the shedNewlife is one of the sharper tools in the shedNewlife is one of the sharper tools in the shedNewlife is one of the sharper tools in the shedNewlife is one of the sharper tools in the shedNewlife is one of the sharper tools in the shedNewlife is one of the sharper tools in the shedNewlife is one of the sharper tools in the shedNewlife is one of the sharper tools in the shedNewlife is one of the sharper tools in the shed
Newlife's Avatar
Newlife's Tacoma Gallery
I need a link. I saw the link to the dome light. Just not the others. Wanna make sure I get the right bulb first time around. Also needing parking light bulbs for top corners
LEDs (Lights) Made Easy: Interior & Exterior mceagle555 Lighting 87 11-08-2014 11:25 PM
LED Lighting Strips (Interior/Exterior) Drunknsloth Group Buys 254 10-07-2012 08:56 PM
LED Grill Accent or LED Interior lights Logan22 Lighting 7 06-17-2012 12:27 PM
Interior/Exterior LED lights stevomac59 Lighting 12 07-30-2011 04:09 AM
LED Lighting Strips For Interior or Exterior Drunknsloth Lighting 90 04-26-2011 01:32 PM
