SeeLite Light Bar Install/Review *PICS*
Old 08-05-2013, 02:14 AM   #1
Benson X [OP] Benson X is offline
...and we're back!
Benson X is one of the sharper tools in the shedBenson X is one of the sharper tools in the shedBenson X is one of the sharper tools in the shedBenson X is one of the sharper tools in the shedBenson X is one of the sharper tools in the shedBenson X is one of the sharper tools in the shedBenson X is one of the sharper tools in the shedBenson X is one of the sharper tools in the shedBenson X is one of the sharper tools in the shedBenson X is one of the sharper tools in the shedBenson X is one of the sharper tools in the shed
Benson X's Avatar
Benson X's Tacoma Gallery
*Just a heads-up - If you haven't seen my write-ups before, they tend to be long, very detailed, and there are a lot of words. Comments, PMs, questions, and criticism are welcomed; stupid remarks like TMWDR or TL;DR will be responded to with another stupid acronym - GTFO! I take no responsibility for any damage or injury from anyone attempting this mod. Do so at your own risk. *
Here's a little bit about SeeLite:
SeeLite specializes in custom LED lighting, with their primary focus on hunting and fishing boats: bow-fishing, night-fishing, duck lighting, warm lighting, trouble lighting etc. After talking with Josh, and seeing their FB page, it was obvious that they are dedicated to their craft and have done some impressive builds that really show they take pride int what they do. They have garnered some good praise, and have created quite the following in their regional fishing and hunting community; along with sponsoring some big names with their custom-outfitted applications.
They want to further increase their footprint in the off-road community as well, and Josh is a fellow Toyota enthusiast / modder. Knowing how competitive the LED industry is right now, he's doing a great job and I hope that he succeeds. I also hope that he can put together a special offer or Group-Buy for TW.
On to the Write-Up!!!
The light-bar itself seems to be well-constructed and pretty much idiot-proof. The model I got is this one, customized with the SeeLite logo stenciled on the top:
Here are some specs.
. LED Power: 30W
. Operating Voltage: 10-30 vDC
. Waterproof rating: IP 67
. (6) 5W High Intensity CREE LEDS
. Current draw:12V 2.40A,24V 1.12A
. Color Temperature: 6000K
. Material: Die-cast aluminum housing
. Lens material:PC
. Mounting Bracket:zinc alloy
. Beam: Flood Spot Beam
. 30000 hours above life time
. Dimensions:10.5 inch
. Certificates:CE, RoHs, IP67
I had an idea months ago (prior to Rigid's design ) to mount a 10"SR in my grille, underneath the Toyota emblem. I had taken some measurements, and knew that it was possible. I also saw rkfoote's write-up on how to mount a similar 10" light-bar in the hood skewp, which also had me intrigued. After getting the dimensions, I realized the SeeLite light-bar would be too tall to mount in the scoop, so I planned to install it in the grille. The light-bar I received did not include a wiring harness (sold separately), but I easily made my own.
PARTS USED:
TOOLS USED:
  • Dremel (or equivalent)
  • Bastard file
  • Small files
  • Fine tooth hacksaw blade
  • Wire strippers and crimpers
  • Tape measure
  • Painter's tape
  • Electrical Tape
  • Small & large flat-head screwdrivers
  • Center punch
  • Sharpie
  • Soldering iron (optional)
  • 10 & 12mm wrenches
  • 10mm socket and driver
  • LIGHT!!!
  • 6-pack of your favorite frosty beverage
Step 1: Cutting & Mounting
The first thing I did when I got the light-bar was connect it to the switch for a test-run. Everything worked as it should, and I let it run it for 1-hour to make sure it wouldn't radiate too much heat. It got warm to the touch, but not hot enough to melt the plastic on my grille.
Next I proceeded to cut the shit out of my grille. I measured the length of the light-bar, and when centered under the Toyota emblem, it lined up almost perfectly with the honeycomb edges on the '11 grilles. I masked each cut-line with painter's tape, and used the hacksaw blade to cut out a rectangle shape for the light-bar. I also had to trim upwards, in order to leave the plastic lip on the bottom of the grille in-tact, since that was my mounting/fastening area. I had to do A LOT of minor trimming and filing on each side and above to make it fit. I didn't take pictures of the process, and it turned out great for what it is, but not as perfect as I'd like it to be.
Once I persuaded the light-bar to fit snugly, I had to figure out how to mount it. The hardware that was included was awesome, and I regret not taking pictures of it prior to the install.
The mounting kit consisted of (2) oval-shaped nuts that slide into a channel on the back of the light-bar. (2) mounting feet fit into the back of the light bar, and bolt into the "slide-nuts" with supplied allen-head bolts and allen wrench. The feet mount to a flat surface with (2) supplied allen-head bolts, but these were too tall for my chosen area, so I substituted some 1.5" 1/4 bolts instead.
I had to get creative with the mounting, since the feet barely fit, and left a large gap for me to fill. I used my center-punch to mark my holes, and Dremeled 2 holes in the bottom plastic lip on the grille.
I had to use washers and neoprene washers on each side to fill the gap and to make sure it wouldn't crack the plastic I was bolting to.
Step 2: Wiring !Disconnect the battery!
The light-bar had about a 14" lead with a specialized plug on the end of it. Since it didn't include a wiring harness, and I didn't want to drop $30+ on one, I had to build one myself. I am not an electronic guru, so I had not idea what type of plug it was, but after searching around for a bit I found it was a standard Deutsch 2-pin plug. I ordered one for $3 on eBay.
I ran a length of POS and NEG wire from the Deutsch plug to the battery, and clipped them off.
Since I have the Redline hood struts, I decided to make use off my old hood-prop retainer clip, and ran my wire leads through it, and underneath the radiator support. I reinforced both sides of the lead with electrical tape, so it couldn't get tugged in or out of the hole. Then I wrapped the end in plastic conduit and electrical tape.
Then I zip-tied the light-bar lead to the grille itself. I Dremeled out a notch for the cable to fit in, and drilled some holes along the bottom and side, to secure it with zip-ties.
After the Deutsch plugs were wired and ready to go, I moved into the cab to start wiring in the switch.
I was very minimalistic with the switch. I was originally going to get a fancy OTRATTW switch and add a relay and all that jazz - but after thinking about it, I chose the easiest and most-basic circuit with the least amount of wiring.
The light-bar only draws 2.5 amps so there was no need for a relay. I wanted to have it on-demand anytime, so a fused direct-power source made sense, and eliminated the need for an ignition powered tie-in. I didn't need an illuminated switch, since I would sure as hell know if the light was ON or OFF, so that cut down on the wiring as well, and also the need to potentially connect to a dimmer source.
I went to my favorite local electronics store, and found a simple SPST On-Off rocker switch (NTE 54-225w) that would fit perfectly in the last "switch blank" I had left (with some trimming of course).
I pushed a doubled-over length of wire through the firewall grommet (always a fun task ) and terminated each end with a 1/4" Quick Connect terminal. I heat-shrinked the terminals, and secured them to nearby wiring-harnesses with zip-ties and connected them to the switch.
All that was left was to connect the switch to the battery and the light bar, and add a ground connection. I crimped on a 1/4 ring terminal to my 5-Amp inline fuse, and connected it to the switch lead. I then connected the second switch lead to the POS lead from the light-bar. I crimped on another 1/4" ring terminal to the NEG lead from the light-bar, and connected it to the battery's ground point.
I tucked everything up using more zip-ties and re-connected the battery.
Ahhh!!! Let there be light and have a beer while basking in the basking in the 3000 lumens of bright-ass white light!
Step 3: Testing
This isn't a 50" light-bar or a Rigid SR-Combo, and it isn't trying to be. It's a modest 10" light-bar with (6) LEDs. Based on that, some would think I invested too much time/effort into making it work how I did - but that's what I wanted to do, and don't regret it at all. I am seriously impressed with the light-output from this little guy.
I took the following series of photos in succession, in an attempt to show all the different variances and light-outputs of the different combinations of fogs, lows, high, and the light-bar.
I placed reflective targets at 2 different distances away from my truck. You can also see the reflective tape on a semi over 1000ft. away, and another road sign in the distance.
Target #1 = 175ft. away
Target #2 = 350ft. away
Step 4: Summary
When I was retrieving my targets, I left only the light-bar on and it completely illuminated the area (even @ 350ft.) as if I had a flashlight with me. I was pretty impressed by that.
I think this thing puts out an impressive amount of light for the size, especially when combined with the other lights. It will be extremely useful when offroading, and should illuminate the area directly in front of the winch nicely. It will also increase my truck's visibility in the event I am on a mission for SAR, thus making it easier for the subject to spot me.
I want to make a cover for, so I ordered a few 2"x1/8"x1/8" Neodymium magnets that "should" fit in the channels of the light-bar's face perfectly. I plan to epoxy (or something) them in each channel, and make a mating metal cover to pop-on the front. The magnets have a 7.4lb pull each, so with 4-6 of them, it should be strong enough to securely hold a piece of metal on there. I may route some recessed "pockets" on the back side of the cover too, that will fit around the magnets in order to prevent it from slide or shifting around.
All in all, I am really happy with how it turned out. It works, it looks good, it's a clean install, and it's more light than I had before
Thanks again to Josh and the SeeLite crew for the opportunity, and I hope you guys put something together for TW!
Old 08-05-2013, 02:24 AM   #2
shit happens then you die
jobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shed
jobrien's Avatar
EMS:
jobrien's Tacoma Gallery
nice write up excessively long and detail oriented (not a bad tbing)
Old 08-05-2013, 03:38 AM   #4
Does not suffer fools lightly
linzy77 has much to be proud oflinzy77 has much to be proud oflinzy77 has much to be proud oflinzy77 has much to be proud oflinzy77 has much to be proud oflinzy77 has much to be proud oflinzy77 has much to be proud oflinzy77 has much to be proud oflinzy77 has much to be proud oflinzy77 has much to be proud of
linzy77's Avatar
linzy77's Tacoma Gallery
Nice writeup They look like quality lights. I going to have to give them a look now.
Old 08-05-2013, 09:03 AM   #5
...and we're back!
Benson X's Avatar
Originally Posted by jobrien View Post
nice write up excessively long and detail oriented (not a bad thing)
Thanks man
Originally Posted by Konaborne View Post
super clean
nice writeup!
Thanks pineapple-guy
The install is clean; my truck is filthy
Check em out man. I'm pleased with the 10", so I bet the bigger ones are just as good
Old 08-05-2013, 10:40 AM   #6
NorthWest Member
J88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shed
J88logue's Avatar
Gender: Tranny
J88logue's Tacoma Gallery
Holy hell that's one specific/detailed write up - all were missing is what you had for dinner. Well done
Old 08-05-2013, 10:45 AM   #8
ColtsTRD's Avatar
ColtsTRD's Tacoma Gallery
Well done bud!
Old 08-05-2013, 11:18 AM   #10
Nuggety
Chickenmunga is one of the sharper tools in the shedChickenmunga is one of the sharper tools in the shedChickenmunga is one of the sharper tools in the shedChickenmunga is one of the sharper tools in the shedChickenmunga is one of the sharper tools in the shedChickenmunga is one of the sharper tools in the shedChickenmunga is one of the sharper tools in the shedChickenmunga is one of the sharper tools in the shedChickenmunga is one of the sharper tools in the shedChickenmunga is one of the sharper tools in the shedChickenmunga is one of the sharper tools in the shed
Chickenmunga's Avatar
Chickenmunga's Tacoma Gallery
There's rare earth magnets you can get from Radio Shack that are about the diameter of a tic-tac. Use that and some adhesive, such as LocTite, to make your cover (make sure they are the right height, may need to stack plastic washers or something). Instead of plastic, opt for aluminum with an anodized logo. I have a name of a shop that could do the work.
Old 08-05-2013, 11:41 AM   #11
...and we're back!
Benson X's Avatar
Thanks Mike!
I already ordered the magnets from an online source. The light-bar housing is aluminum, so unfortunately it is not magnetic, so I will have to use some sort of bonding agent to secure the magnets in each channel. They should fit each recess perfect according to my measurements (2"L x 1/8"H x 1/8"D), and once mounted they should leave a slight lip that protrudes beyond the light-bar face. I plan to use a piece of light metal for the cover (cut to fit) and make the recessed pockets in the back-side, so the magnets will fit up in there and keep it flush with the light-bar.
I "might" get creative with a design on the cover too, since it will be a plain metal face. Stencil-work, decal, cutout design, painted engraved design.
Old 08-22-2013, 09:31 PM   #12
...and we're back!
Benson X's Avatar
Made the cover for it last weekend. What could've been a 5 minute job with the right tools took me about 3 hours with a dremel.
WAY too much work for what it is, and it is nowhere near "perfect". But it works
2" x 1/4" x 1/4" neodymium magnets epoxied in the channel:
Piece of 3/16" scrap leftover from my skids (that's why there's a hole). I tried to route-out "pockets" with my dremel:
The magnets are as strong as hell!!!
Old 09-13-2013, 10:36 AM   #13
B.S. Goodwrench
KWMF is one of the sharper tools in the shedKWMF is one of the sharper tools in the shedKWMF is one of the sharper tools in the shedKWMF is one of the sharper tools in the shedKWMF is one of the sharper tools in the shedKWMF is one of the sharper tools in the shedKWMF is one of the sharper tools in the shedKWMF is one of the sharper tools in the shedKWMF is one of the sharper tools in the shedKWMF is one of the sharper tools in the shedKWMF is one of the sharper tools in the shed
KWMF's Avatar
KWMF's Tacoma Gallery
Dude, you rock with an impressive write up,
Love the details....
I want a 30" bar for my lower grill opening but can't come close to affording the Rigid model, although I want their mounting kit,
I may put some smaller ones in my upper grill using your info.
Thanks again.
Old 09-13-2013, 01:42 PM   #14
...and we're back!
Benson X's Avatar
Thanks again.
No problem Zack! Glad you found it useful. I originally wanted a Rigid 10"SR Hybrid, but yes, they are spendy!!! I have been damn happy with the SeeLite though, it puts off a lot of light for being so small.
I bet (2) of them in the grille would provide a pretty good throw, and about 5500 lumens.
Old 12-22-2013, 05:28 AM   #15
Saw things so much clearer once you... were in my
RearViewMirror is one of the sharper tools in the shedRearViewMirror is one of the sharper tools in the shedRearViewMirror is one of the sharper tools in the shedRearViewMirror is one of the sharper tools in the shedRearViewMirror is one of the sharper tools in the shedRearViewMirror is one of the sharper tools in the shedRearViewMirror is one of the sharper tools in the shedRearViewMirror is one of the sharper tools in the shedRearViewMirror is one of the sharper tools in the shedRearViewMirror is one of the sharper tools in the shedRearViewMirror is one of the sharper tools in the shed
RearViewMirror's Avatar
Firefighter: IAFF Local 34 Professional Firefighters
RearViewMirror's Tacoma Gallery
Great write up man
But I've got to ask... Why did you put that cover over it??? I don't mean to be critical but that took away from the looks of it. Unless I missed something in your write up I didn't see a reason for the cover other than you just wanted it?
I've got a 40" bar on mine and quite honestly the last thing I'm worried about is breaking the lens.
Old 12-22-2013, 09:07 AM   #16
Badger of Death
DoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shed
DoorDing's Avatar
DoorDing's Tacoma Gallery
Maybe worried about pitting the lens?
If I had an LED bar, I'd get some 3M film from a body shop supplier and cover the lens to protect it from road debris. It couldn't be an easier shape to cover, and the film isn't that expensive.
And then I'd 303 everything.
Old 12-22-2013, 09:09 AM   #17
Touché
Old 12-22-2013, 09:13 AM   #18
poundin tacos is one of the sharper tools in the shedpoundin tacos is one of the sharper tools in the shedpoundin tacos is one of the sharper tools in the shedpoundin tacos is one of the sharper tools in the shedpoundin tacos is one of the sharper tools in the shedpoundin tacos is one of the sharper tools in the shedpoundin tacos is one of the sharper tools in the shedpoundin tacos is one of the sharper tools in the shedpoundin tacos is one of the sharper tools in the shedpoundin tacos is one of the sharper tools in the shedpoundin tacos is one of the sharper tools in the shed
poundin tacos's Avatar
poundin tacos's Tacoma Gallery
Did not reed. Only look at pikturs.
Old 12-22-2013, 05:25 PM   #20
Badger of Death
DoorDing's Avatar
Looks great, and at some point, I'll have to measure my 2012 grill to see how it'd work.
Write up/ Review BAMF Light Bar 2012 version. mclovin Bay Area Metal Fabrication 16 12-06-2014 11:03 AM
Extang (soft) Tri Fold Tonneau Install PICS (and quick review) acozzens Product Reviews 6 11-05-2014 03:15 PM
2012 Avid Light Bar Review and Installation bubbagumps Avid Off Road 35 09-01-2014 06:02 AM
SeeLite want's to give away a 10" LED light bar! 4Wheelin4Banger Deals & Coupons 21 07-11-2013 04:42 PM
Spider light review (beware, lots of pics) TacoRich Product Reviews 0 08-19-2010 11:58 PM
