Headlight After Retrofit Has Hole In Back...Concern?
Discussion in 'Lighting' started by iJDub, Jan 6, 2014.
  1. Jan 6, 2014 at 4:39 PM
    iJDub
    iJDub [OP] Well-Known Member
    So after doing the retrofit there's now basically a small hole that isn't filled that could let moisture in. Should I be concerned or fill with silicone?ujege8e3_76b91cfa5c70663497eef9fc27643530dc7cc632.jpg
  2. Jan 6, 2014 at 4:44 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Where's the hole?
  3. Jan 6, 2014 at 4:48 PM
    iJDub
    It's where the wires for the bulb go in. Basically the black boot no longer fits snugly around they base of the bulb.
  4. Jan 6, 2014 at 5:12 PM
    dexterdog
    Oly WA
    2012 F150
    Did you do the H1 retro? I would try to get that grommet that is on the wires to work with the boot to seal the hole.
  5. Jan 6, 2014 at 5:35 PM
    iJDub
    Yes I did. It won't fit.
  6. Jan 6, 2014 at 5:42 PM
    trdspectacoma
    trdspectacoma Well-Known Member
    B.I Hawaii
    13 dCab preRunner
    you might need to trim the stock boot to fit the grommet. that is what happened on my old retro
  7. Jan 6, 2014 at 7:22 PM
    dexterdog
    Oly WA
    2012 F150
    I was thinking more along the lines of silicone attaching the grommet to the rubber boot.
  8. Jan 6, 2014 at 9:07 PM
    trdspectacoma
    B.I Hawaii
    13 dCab preRunner
    You could do that also.
  9. Jan 20, 2014 at 8:44 AM
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    I left mine the way it is. it fogged up the first week of rain (usually gone in an hour) and never came back.
  10. Jan 20, 2014 at 10:05 AM
    InSight Retrofits
    InSight Retrofits Closed
    Mine was fogging up, I actually used aluminum tape and covered the whole bulb area and put the boot on over the bulbs and aluminum tape.
    Fogged up at first and I was like ugh come on. Then after a few days it never fogged again and hasn't in over a month.
  11. Jan 27, 2014 at 2:28 PM
    TRSAndrew
    TRSAndrew Well-Known Member Vendor
    ATL
    22 T4R Sport 6V7
  12. Jan 27, 2014 at 2:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Try harder :D
    I put some silicone on that rubber washer looking thing and stuck it to the rubber boot and it worked fine.
