Knockout Blanks...?
Discussion in 'Lighting' started by AWF ROWD, May 28, 2014.
  1. May 28, 2014 at 4:24 PM
    AWF ROWD
    AWF ROWD [OP] ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Pulled this Blank and found a black wire attached to it...looks like a dummy wire but I'm not sure.....anybody before i get the wire cutters out...?:notsure:
  2. May 28, 2014 at 4:26 PM
    PPansini10
    PPansini10 Well-Known Member
    Paul
    NJ
    09' DCSB 4x4 TRD Sport
    Whats on the front of the blank? Mine were completely smooth like the bottom one
  3. May 28, 2014 at 4:27 PM
    Large
    Large Red
    Just cut it off, what's the worst that could happen :drevil:
  4. May 28, 2014 at 4:28 PM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Looks like two round washers with a hole in the middle...maybe for a toggle switch...??? No clue....
  5. May 28, 2014 at 4:42 PM
    PPansini10
    Paul
    NJ
    Unless someone before you had something there and took it off i have no clue.. i took mine out and had to wires connected but like i said mine looked liked the one at the bottom of the picture
  6. May 28, 2014 at 4:58 PM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Bought it new...
  7. May 28, 2014 at 5:13 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Some type of sensor?
  8. May 28, 2014 at 6:38 PM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Sounds feasible.....somebody gotta know ...??!
  9. May 29, 2014 at 11:30 AM
    hippykiller
    hippykiller Active Member
    Trav!
    Fort McMurray
    Nicest truck in Fort McMurray
    OME front and rear, ARB front, All Pro rear, Warn M8, True Flow cold air, Magnaflow exhaust
    Did you buy the truck new or used?
  10. May 29, 2014 at 11:37 AM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Brand Nu....
  11. May 29, 2014 at 11:41 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    microphone for handsfree maybe?
  12. May 29, 2014 at 11:49 AM
    12TRDTacoma
    12TRDTacoma Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    12 TRD Sport DCLB 4x4 Supercharged
    Boosted
    Some kind of light for an aftermarket alarm or maybe a switch which they didn't end up utilizing when they had some kind of aftermarket work at the dealer being done to it. Mine is totally blank.
  13. May 29, 2014 at 11:53 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    CBI bed rack and sliders, Backwoods Adventure Mods front and rear bumpers, etc. And some stickers.
    I would go with this explanation. That is not a normal blank. Any dealer-installed options? Did you follow the wire to see where it leads? I would suspect it isn't part of the standard harness, although it may be tapped into it for something. It does look like a toggle might have been there.
  14. May 29, 2014 at 12:03 PM
    medic2230
    Murph
    Bama! Roll Tide
    Glass breakage microphone for factory alarm?
  15. May 29, 2014 at 12:14 PM
    hippykiller
    Trav!
    Fort McMurray
    Can you maybe remove the circular deal from the front of the blank, unscrew or unclip it from the larger plastic piece? Then just leave it hanging inside in case it is important?
  16. May 29, 2014 at 12:18 PM
    CaptJustin
    CaptJustin Member
    Justin
    Ft Lauderdale
    4X4 TACO
    Original Owner: :3" Pro-comp level: :HID: :AllPro Pack Rack: :OKLED CREE Lights:
    Doesn't quite resemble the other blanks man! Mind if I ask how you knocked that blank out?
  17. May 29, 2014 at 1:10 PM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Small flat blade screwdriver...
  18. May 29, 2014 at 1:14 PM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    I like this idea...I did have a custom Viper remote start/alarm system installed after I bought the truck...time to Google...!:D
    EDIT : This is what comes with my Viper system..The round end of the wire is the microphone thats wired into a shock sensor microprocessor under the dash..!!!
  19. May 29, 2014 at 1:39 PM
    Snookie
    Snookie Monkey Tamer
    Snookie
    Lizard Creek Louisiana
    14 Texas Edition 4X4
    Not trying to hi-jack this thread, I don't know what that middle blank is however; I was just about to post a question very similar so here goes:}
    I have a 2014 Toyota Tacoma double cab Texas Edition that came with NO Fog-lights installed, looks like it's prewired though found the plug I think on each side just above the place where the fog light blanks are...
    now my question...I poped all three blanks out (see picture) seems like first blank is for Fog Light switch correct? (4 wires) middle unlike the OP is blank and the third blank has some sort of wire plug going into it so What is the third blanK/wires for?
    Also, since I assume the fog lights are prewired I can simply buy the lights, i'd like, relay, and switch and it should be good to go? Or is the relay already installed also?
    Thanks in advance
    screenshot windows 7
  20. May 29, 2014 at 1:41 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    That doesnt look factory to me....
