120W Amber/White LED Light Bar Wiring?
Old 01-08-2015, 02:00 PM   #1
Reepur [OP] Reepur is offline
Reepur is on a distinguished road
Reepur's Tacoma Gallery
Question 120W Amber/White LED Light Bar Wiring?
Hey, I loooked and did not find and answer for this.
I have this
21.5Inch 120W Amber/White Led Spot Flood Light Bar
When wiring, the light has Red/Black/and Yellow wire coming from it, what is the yellow wire for?
I have a 40 amp relay wiring harness with just a red/black wire to the lights.
Old 01-08-2015, 02:04 PM   #2
That one guy
Aw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shed
Aw9d's Avatar
Aw9d's Tacoma Gallery
Does the switch light up?
Old 01-08-2015, 02:04 PM   #3
fergyz will become famous soon enough
Navy: PR
fergyz's Tacoma Gallery
Who makes the light bar?
Old 01-08-2015, 02:06 PM   #4
That one guy
Aw9d's Avatar
Most likely Yellow is the On/Off wire. Pics might help as well, or who made the light bar.
Old 01-08-2015, 02:08 PM   #5
Navy: PR
my guess is the yellow wire is to trigger the ambers. need to know who makes that bar and track down a wiring diagram.
Old 01-08-2015, 05:54 PM   #6
toendanger has much to be proud oftoendanger has much to be proud oftoendanger has much to be proud oftoendanger has much to be proud oftoendanger has much to be proud oftoendanger has much to be proud oftoendanger has much to be proud oftoendanger has much to be proud oftoendanger has much to be proud of
toendanger's Tacoma Gallery
Sweet someone got one of these bars. I found em a while back. Be sure to share a vid if you can and let us know how the output is as well. And of course how you wired them... Curious to see these in action!
Old 01-12-2015, 11:34 AM   #7
Figured it out, yellow wire is for amber. That is what i wanted it for and they are bright! I am not using the red wire but if you want to switch between white/amber it comes with a wiring harness that i did not use. There are no instructions for the harness and it is not using conventional red/black/white wiring. I will upload picks later.
here is what i got, 4 days free shipping
http://www.ebay.com/itm/360993470971
Old 01-13-2015, 12:17 AM   #8
DirtJumper14 has much to be proud ofDirtJumper14 has much to be proud ofDirtJumper14 has much to be proud ofDirtJumper14 has much to be proud ofDirtJumper14 has much to be proud ofDirtJumper14 has much to be proud ofDirtJumper14 has much to be proud ofDirtJumper14 has much to be proud ofDirtJumper14 has much to be proud ofDirtJumper14 has much to be proud of
DirtJumper14's Tacoma Gallery
Can you post some close up pictures of the led(s)/lens. Thanks
Old 01-16-2015, 01:18 PM   #10
Ok, now the lights do not work, if I check the voltage connected to light i get 3.4 volts,
If I disconnect the hot wire(yellow) and check voltage I get 12.6 volts. I checked ground and it is good. I am running harness with 30 amp relay. Would going to 40 amp relay help?
Any ideas? thanks.
Old 01-17-2015, 04:32 PM   #12
bry838 is one of the sharper tools in the shedbry838 is one of the sharper tools in the shedbry838 is one of the sharper tools in the shedbry838 is one of the sharper tools in the shedbry838 is one of the sharper tools in the shedbry838 is one of the sharper tools in the shedbry838 is one of the sharper tools in the shedbry838 is one of the sharper tools in the shedbry838 is one of the sharper tools in the shedbry838 is one of the sharper tools in the shedbry838 is one of the sharper tools in the shed
bry838's Avatar
bry838's Tacoma Gallery
I'm no wiring guru but I would guess all would be well if you connected all three wires. I would think yellow triggers the ambers(like you stated above) and red triggers the whites the of course black for ground. Then if it were hooked up to that dual trigger switch, maybe it might just make it happy. When you hooked it up the second time with the red, were the ambers still functioning? And now neither wire will produce light?
Old 01-18-2015, 10:31 AM   #13
Yesterday I replaced the relay (40 amp)thinking the one i had was defective. Still no light. I get up this morning to warm the truck up and tried it and it worked, good light.
Turned the switch off and back on and now no light again. I switched between amber (yellow wire) and white (red wire) and still no light.
Beginning to think the light is defective.
Old 01-19-2015, 12:54 PM   #14
Update, got it all working. I had to install the wiring harness designed for bi color, double row LED lightbars.
http://www.ledtrailerlights.com/Swit...hts_p_894.html
I am only interested in the Amber light so was trying to just wire that with an existing harness. Apparently, have to use a dual relay harness with a DTDP switch.
Glad i finally got it working... thanks for the replies!
Wiring Harness for LED light bar? burtonbrd31 2nd Gen. Tacomas 11 12-24-2014 11:57 PM
White LED DTRL / Amber LED Blinker Setup on 2nd Gen. protaco06 2nd Gen. Tacomas 5 07-20-2014 12:27 PM
WTB: Amber led light bar. Not covers. 669sprink 2nd Gen Tacoma Marketplace 6 05-01-2014 08:56 PM
Signal Mini AMBER LED Flashing Light Bar ( Nor Cal ) will ship sytfu510 Buy / Sell / Trade 20 10-29-2012 01:17 AM
LED / AMBER Light / HI-LIFT mount Rear Bed chase Bar................................ desert guy 2nd Gen Tacoma Marketplace 11 08-13-2012 09:56 PM
