Hella 500's in front of grill with no light bar
Discussion in 'Lighting' started by Sig45, Feb 15, 2015.
  1. Feb 15, 2015 at 7:09 AM
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    2011 Tacoma TRD OR 4x4 & 2021 Tundra SR5 DC 4x4
    AVS in-channel window visors Husky Mud Guards Husky Liners X-act Contour Floor Liners Cooper Discoverer AT3 LT- 265/75/16 C Toyota 16" Black TRD Trail Team Edition Wheels Truxedo Lo Pro Tonneau Cover OEM Bed mat OEM Running Boards Marathon custom fit seat covers Front window tint Rear Leaf Spring 4 Pack - TSB Front - 5100's with stock springs set at .85" Rear - 4600's
    So I've got some Hella 500 black magics I'm wanting to mount just above my bumper. I had picked up a Defiant 3 Tab light bar, but the thing is huge and now I'm not wanting to mount it (it's listed on the 2nd Gen marketplace forum).
    I don't think mounting to the bumper is the best solution. Has anyone fabbed up some brackets that mount behind the grill with tabs that protrude through the grill (towards the bottom), so the lights can be mounted to those tabs. I thought I saw a thread on this, but I'm not finding it with the search feature.
    Appreciate any other non light bar mounting options in front of the grill.
  2. Feb 17, 2015 at 7:01 AM
    Sig45
    Mark
    Maine
  3. Feb 18, 2015 at 8:59 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    '24 4R ORP
    I initially was going to fab up some brackets that bolted to the radiator supports and extended through the bottom slots of the grille, basically having just a small bit of metal and the mounting hole exposed to the front of the truck.
    I could not get it to look "right", symmetrical, or clean. Granted, I was using angle iron and a hammer and vise to make this, so YMMV if you have actual tools and abilities.
    My solution was to install a small light bar (N Fab) which, of you care to see pics of with Hellas, is visible in my link below, 2nd to last page.
  4. Feb 18, 2015 at 2:49 PM
    Sig45
    Mark
    Maine
    I have the honeycomb grill, but I think they are big enough for at least a 1.5" flat sturdy tab. I'm thinking if I can position a horizontal piece of angle iron (or steel or aluminum) at the correct level, I can easily attach those tabs so they come out just where I want (right along the bottom of the grill). Seems like this is what was done in the thread I referenced.
  5. Feb 18, 2015 at 2:55 PM
    Sig45
    Mark
    Maine
    Are those spacers (white) that you have between the mounting bracket and the light bar? My Hellas seemed to fit tight on the light bar I have (but don't want...but may install to see how it looks mounted) with not much room for downward adjustment.
  6. Feb 18, 2015 at 8:42 PM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    '24 4R ORP
    Yeah, hard nylon spacers from Lowe's. I had white ones in my bin, otherwise I would have gotten black.
  7. Feb 19, 2015 at 3:56 AM
    euroshowoff
    euroshowoff Well-Known Member
    Stafford, VA
    15 Superwhite DCSB 4x4 V6
    Toytec lift, Trailgear sliders, CBI ditch light brackets, Trailtoys LED ditch lights, Trailtoys LED reverse pods, Custom Roll-Bar, TRD skid plate, TRD sport grill, TRD custom bedsides, Custom BlueSea wiring block, OTTRAW Rockers, Pro Comp 7036, BFGoodrich KO2s, Bestop soft topper,VIAIR 88p
    Nylon spacers that I painted black. Lowes had a variety of sizes, these were the perfect fit for mine
  8. Feb 19, 2015 at 4:39 AM
    Sig45
    Mark
    Maine
    Never thought of nylon spacers.....was planning on painting & stacking a couple of thick washers to gain a little height as all I need is about 3/8".
    I check those out for sure....thanks!
