2013 Toyota Tacoma Base Model Fog Light Mod, No mini fuse box for relay?
Old 02-23-2015, 07:37 AM   #1
moe2o4 [OP] moe2o4 is offline
moe2o4 is on a distinguished road
moe2o4's Tacoma Gallery
Hi guys i just purchased a fog light kit off of ebay for my 2013 Toyota Tacoma Base Model 2.7L. I been searching around on the forums and found everyone doing the mod for the fog lights but i dont have the little box behind the big fuse box under the hood that contains the relay for the fog lights.
This is the kit i purchased the other day:
http://www.ebay.com/itm/271159382720...%3AMEBIDX%3AIT
Has anyone done a fog light mod on a base model 2013 without the small box with the relay behind the main fuse box under the hood and if so how is it done? Cause with this kit it looks like it comes with its own relay and you maybe power it off the battery so you could use them anytime, that's what im thinking?
Old 02-23-2015, 12:24 PM   #2
Curmudgeonly
MeefZah is one of the sharper tools in the shedMeefZah is one of the sharper tools in the shedMeefZah is one of the sharper tools in the shedMeefZah is one of the sharper tools in the shedMeefZah is one of the sharper tools in the shedMeefZah is one of the sharper tools in the shedMeefZah is one of the sharper tools in the shedMeefZah is one of the sharper tools in the shedMeefZah is one of the sharper tools in the shedMeefZah is one of the sharper tools in the shedMeefZah is one of the sharper tools in the shed
MeefZah's Avatar
MeefZah's Tacoma Gallery
You will have to wire them yourself.
Depending on how you want the lights to be activated, would depend on how you wire the trigger. For example, if you want them to be able to be turned on at any time, wire the trigger through the included switch and directly to battery. You want them to come on with your high beams, wire the trigger through the switch to the high beam + wire. Low beams? Trigger through the switch to the low beam +. Marker lights? Trigger through the switch to the marker light + wire. This will involve some simple splicing into factory wiring unless you either go directly to battery or you opt to use a "headlight extension" lead and splice into that (so you are not cutting into the factory wiring but are cutting into a more disposable / replaceable component.
The terminals of the relay would be consistent regardless of how you want the lights to be activated. Follow the instructions for them. One to negative, one to + battery through a 20A fuse, one to the fog light power, and then of course the "trigger" as described above.
It's not hard to install them, it's just tedious to do it neatly.
Old 02-24-2015, 05:02 AM   #3
Thanks man, Ill probably just wire them up straight to the battery so i can turn them on whenever i want and just run that wire inside for the switch on the dash.
2013 Toyota Tacoma Access Cab 5 Speed Base Model Wired for fog lights? moe2o4 Lighting 7 03-15-2015 07:24 AM
base model, oem fog light switch danteisme 2nd Gen. Tacomas 0 11-06-2012 08:14 PM
Fog light install 2011 base model bluepacific Lighting 6 10-29-2011 06:27 PM
WTB - Base Model Fog Light Covers StormTrooper 2nd Gen Tacoma Marketplace 8 02-09-2011 01:36 PM
Fog light Relay in Fuse box, No Taps, No Box Relays! krlang Lighting 7 07-21-2009 05:37 PM
