Fog Light Switch
Old 02-07-2011, 08:41 PM   #21
2007TacBorla4X4 has a spectacular aura about2007TacBorla4X4 has a spectacular aura about2007TacBorla4X4 has a spectacular aura about
2007TacBorla4X4's Tacoma Gallery
Fog lights switch
Go look at my picks, they are from Painless , & a dremmell....LOL
Old 04-10-2013, 05:36 AM   #22
BBJ285 is on a distinguished road
BBJ285's Avatar
Firefighter: Volunteer
BBJ285's Tacoma Gallery
light in switch not working...
I realize this is an old thread...I wired my light to the Toyota switch and the light doesn't come on when the switch is turned on. I have power to the switch, power to the light and a ground, when I disconect the ground...the lights still work, just the light(on the switch) doesn't come on. I know it's petty since the lights i'm running are working, I'd just like the litch to come on too. Any input???
Old 04-10-2013, 07:09 PM   #23
Fish Head is on a distinguished road
Fish Head's Avatar
Fish Head's Tacoma Gallery
http://www.tacomaworld.com/forum/2nd...tml#post915862
See post from Plain Jane Taco regarding wiring at the above link.
I cannot recall exactly how I did mine but I likely followed what was posted here. Mine do not illuminate the little headlight icon at all, but the orange indicator light is illuminated ONLY when the aux lights are switched to the "on" position.
Hope this helps.
Old 04-13-2013, 06:11 AM   #25
BBJ285's Avatar
Looks like the bulb in the switch is bad, I wired a second set the same way and the light on the switch works...
Old 04-15-2013, 09:19 AM   #26
Motorshooter
Motorshooter is a glorious beacon of lightMotorshooter is a glorious beacon of lightMotorshooter is a glorious beacon of lightMotorshooter is a glorious beacon of lightMotorshooter is a glorious beacon of lightMotorshooter is a glorious beacon of light
Motorshooter's Avatar
Navy: IC2 SS
Motorshooter's Tacoma Gallery
Originally Posted by 95SLE View Post
You might want to look at one of these.
http://www.oznium.com/gsw-45-led
X2
Old 04-20-2013, 02:28 PM   #28
Burnsy444 has much to be proud ofBurnsy444 has much to be proud ofBurnsy444 has much to be proud ofBurnsy444 has much to be proud ofBurnsy444 has much to be proud ofBurnsy444 has much to be proud ofBurnsy444 has much to be proud ofBurnsy444 has much to be proud ofBurnsy444 has much to be proud of
Navy: Aviation Electronics Technician
Burnsy444's Tacoma Gallery
custom switches
Found these novelty switches and just installed them with 4 Hella Black Magics on the Zombie apocalypse and 2 Hella Floods on the landing Lights one!
Old 02-21-2014, 11:59 AM   #29
Bosshoag is on a distinguished road
Bosshoag's Avatar
Bosshoag's Tacoma Gallery
Originally Posted by Fish Head View Post
Quick question now that my hands are scratched to crap from burrowing around blindly up in behind my dash - how does one access the area behind the upper 3 switches ? The lower 3 is a simple remove the tray and pop 'em out from behind.........the upper 3 are shielded from below it seems.
I'm wanting to move (re locate) the factory alarm light/sensor from the lower middle slot to the upper middle slot, leaving the lower 3 for the new auxillary lighting switches.
Any way to do this simply without yarding half the dash out ?? I've looked around a bit for links but haven't hit on the right one yet.
Some one else asked you if you'd received anything about this and you said "you've got mail" can you send that my way too? My foglights work but when I let out the button they turn off. as long as i hold the button in they work. i assume the button is failing and i need to take it out and mess with it. thx
Old 02-22-2014, 03:41 AM   #31
Switches
Check these out! I have two of them in my truck and I love em!!
http://www.otrattw.com/
Old 02-22-2014, 10:05 PM   #32
Bosshoag's Avatar
So Since my fogs work when i hold in the switch but stop when I let it out, i reckon the issue must be with the switch. i've removed it. anyone know anything about taking these switches apart or how they work?
Old 03-10-2015, 06:41 PM   #33
ARTaco06 is on a distinguished road
ARTaco06's Avatar
ARTaco06's Tacoma Gallery
Originally Posted by krob32 View Post
OTRATTW Switches. I called and told him what I wanted on the switch and how it should work. He did the rest. Went amber when truck lights are on and green slit when activated so lights aren't accidently left on.
how did u remove the factory fog light switch I'm trying to do the otrattw switch but the factory one won't come out
Old 03-10-2015, 06:43 PM   #34
ARTaco06's Avatar
lol never mind just took a little perseverance
Old 03-11-2015, 10:00 PM   #35
ARTaco06's Avatar
the lower led is working but the upper led isn't it looks like I need to land a wire on the other pin but there's only four wires in the factory harness any ideas?
Old 03-26-2015, 11:27 AM   #36
lennyk is on a distinguished road
lennyk's Avatar
lennyk's Tacoma Gallery
Very helpful - THANKS
Is my fog light switch supposed to light up? ShaLor 2nd Gen. Tacomas 44 06-05-2012 06:37 AM
Fog Light Switch MXscott14 2nd Gen. Tacomas 2 01-10-2012 04:18 PM
Fog Lights, Fog light switch, cb antenna dbronzo 2nd Gen Tacoma Marketplace 35 11-25-2011 08:34 PM
fog light switch David Tarantino Lighting 3 08-17-2010 11:01 AM
Fog light switch RMHunter Lighting 4 03-17-2008 07:37 PM
